It is currently May Sat 18, 2013 5:55 pm
Forum rules
 Post subject: WTB Philco 48-482 Output transformerEDIT: Found one
PostPosted: May Thu 03, 2012 8:24 pm
EDIT: Found one
 Post subject: Re: WTB Philco 48-482 Output transformer
PostPosted: May Fri 04, 2012 1:22 am
6V6 output transformer will be about 5K to 6K primary, 3-4 Ohms secondary. What's the mounting hole spacing?
PostPosted: May Fri 04, 2012 3:15 pm
Tom,
Thanks for the reply. I'm a newbie at this and have been working on this ( off and on) for quite awhile. After replacing the e-caps it still wouldn't play. My tube tester didn't have the settings for the tubes so I bought a full set (from a seller recommended by badrestorer). I heard music from it for maybe the 1st time in what, 60 years? WHAT A COOL HOBBY!! Alas, after about 10 minutes it quit. Test determined that output tran read infinity ohms.
Now, to answer you question, the mount measures 2.5 inches center-center. By the way, it has a lead from the secondary going to the volume control, is that critical??
Before I end this let me just say THANK YOU to all of the posters who take the time to help us newbies, I have learned so much from this forum.
Regards to all!
Stan
PostPosted: May Fri 04, 2012 4:55 pm
This radio will need all of it's paper caps replaced, too. Leaky caps in the audio section probably took out the original transformer. Yes, the lead from the secondary needs to be there as it is part of the negative feedback and bass control circuit. Also critical is how the leads from the transformer are hooked up. If wired wrong, positive feedback will result but that's easily solved by reversing the leads of either the primary or the secondary.
I'll look for a replacement transformer for you.
PostPosted: May Fri 04, 2012 6:06 pm
Dave,
Tks for the reply. No doubt, you are correct that I foolishly took out the transformer myself. If I understand what you said about the secondary lead (neg. feedback), I guess that rules out a universal transformer (such as the AES P-T291)??
At anyrate your help in finding a replacement is very much appreciated. Meanwhile, doesn't seem to be a shortage of paper caps to keep me busy. ;)
Thanks again,
Stan
PostPosted: May Sat 05, 2012 3:27 am
That AES transformer should work fine. As mentioned, it might be necessary to swap the primary or secondary leads. If Dave doesn't turn something up, I probably can. In case you don't have it, the 20-page Philco service bulletin ins on my web page: http://www.audiophool.cjb.net/Misc/philco_48-482.djvu (You'll need the DjVu plug-in or similar to view or print it).
PostPosted: May Sat 05, 2012 12:26 pm
The AES transformer is push-pull. I wonder if it can accept the unbalanced load of a single-ended circuit or if "universal" transformers are designed for this.
I did find a suitable transformer but, in discussing this via PM with Stan, it seems his transformer has a tapped secondary for the feedback loop. Perhaps there was a circuit revision?
Thanks for the link to the clean copy of the service bulletin!
EDIT: Stan checked again....no tapped secondary.
Post New Topic Post Reply  [ 7 posts ]  Moderators: John Bartley, Philco Fan
Users browsing this forum: cl350rr, dschulma, Tkilboy and 5 guests
