| Author |
threeneurons
Post subject: Re: How do you buy parts? Posted: May Thu 03, 2012 10:51 pm |
| Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 1780 Location: Los Angeles
Nick D. wrote: Mikeinkcmo wrote: Fourteen cents apiece is ridiculous!! Here we go again... $100 divided into 7,200 units... that's 0.014 (0.01389) DOLLARS each.... or 1.4 cents. Somebody needs learn'n in some advanced cipher'n, like gazintas. 100 gazinta 7200, 0.014 times http://uncyclopedia.wikia.com/wiki/User:Ogopogo/Jethro_Bodine
_________________ If the women don't find you handsome, they should at least find you handy ! - Red Green
| Top |
Nick D.
Post subject: Re: How do you buy parts? Posted: May Thu 03, 2012 10:58 pm |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6729 Location: "Amish Country", PA
threeneurons wrote: 100 gazinta 7200, 0.014 times
Naw, 100 gazinta 7200 72 times!!!
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
threeneurons
Post subject: Re: How do you buy parts? Posted: May Thu 03, 2012 11:29 pm |
| Member |
Nick D. wrote: [ Naw, 100 gazinta 7200 72 times!!!  I guess ya went past the 6th grade ... Some kinda jeenyus, or sum-then.
| Top |
neali
Post subject: Re: How do you buy parts? Posted: May Fri 04, 2012 4:58 am |
Joined: Mar Thu 31, 2011 4:52 am Posts: 1787 Location: Long Island
I like metal film one percent. Tolerance doesn't matter so much but metal film does not catch on fire. And I like sunspec for resistors. I bought an assortment of 1/2 1, 2, 3 and 5 watt for less than $150. I still need to but the occasional 25W Dale from mouser, but I rarely have to stop and order resistors.
Caps I get electrolytics from Mouser and Sal. Polyesters from mouser, Sal, Mark Oppat and just radios. Safety caps from Mouser and just radios and some cool combo electrolytics from Bob's capacitors.
Mark Oppat is the guy for almost everything else. Tubes, pots, you name it. If he doesn't have it, he can usually find it. Great guy. There are a couple of tube guys on the classified forum, genoo and alton that I had always got good testing well priced tubes from also.
Phono parts from Gary Stork at voiceofmusic.com. He is also a great guy and can figure out what you need when you don't even know.
There is a thread here that has links to all the great resources in the hobbyist community, though they will leave out Mouser and Digikey because they are monster companies not geared to the hobbyist. Maybe someone has a link.
| Top |
DragonForce
Post subject: Re: How do you buy parts? Posted: May Fri 04, 2012 5:34 am |
Joined: Feb Sun 05, 2012 3:41 pm Posts: 314 Location: Bristol, SW England
Deleted
_________________ I smell smoke.....
| Top |
obbm
Post subject: Re: How do you buy parts? Posted: May Fri 04, 2012 2:13 pm |
Joined: Jan Mon 04, 2010 2:25 am Posts: 810 Location: Finger Lakes of NY
I hadn't heard of Sal. I would like to check out his E-caps. Does he have a web site?
Bill
| Top |
palegreenthumb
Post subject: Re: How do you buy parts? Posted: May Mon 14, 2012 6:17 pm |
| Member |
Joined: Apr Sun 01, 2012 9:55 pm Posts: 1009 Location: Seattle area, WA
mbear2k wrote: (no affiliation) I've ordered a bunch of these over the past few years: Deluxe 1/2W, 1W, 2W Resistor Kit, 340 Pieces Total, Values from 10 Ohm to 10M. $7.95 http://www.elexp.com/srp_qtr1.htmElexp also sells 10 different colors of hookup wire in 25' spools for only $1.45/spool. They have a minimum $20 order, so snagging all 10 colors doesn't even get you up to the minimum. But throw in an $8 resistor kit, and now we're in business. Thanks for the recommendation! Rodney
| Top |
Peter Bertini
Post subject: Re: How do you buy parts? Posted: May Mon 14, 2012 6:38 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12202 Location: Somers, CT
Most early radios used resistors with 20% tolerance spreads.
So, if you end up with a drawer of 9100 ohm, or similar, resistors, they may be gathering dust for a long time.
Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
mbear2k
Post subject: Re: How do you buy parts? Posted: May Mon 14, 2012 9:56 pm |
| Member |
Joined: Nov Fri 06, 2009 1:04 am Posts: 1281 Location: Rochester, NY 14425
palegreenthumb wrote: mbear2k wrote: (no affiliation) I've ordered a bunch of these over the past few years: Deluxe 1/2W, 1W, 2W Resistor Kit, 340 Pieces Total, Values from 10 Ohm to 10M. $7.95 http://www.elexp.com/srp_qtr1.htmElexp also sells 10 different colors of hookup wire in 25' spools for only $1.45/spool. They have a minimum $20 order, so snagging all 10 colors doesn't even get you up to the minimum. But throw in an $8 resistor kit, and now we're in business. Thanks for the recommendation! Rodney In fact I bought my hookup wire from them too in a kit - one each, stranded and solid: http://www.elexp.com/cbl_ld25.htmNot quite as good a deal, but worked well for me.
| Top |
Tim Tress
Post subject: Re: How do you buy parts? Posted: May Tue 15, 2012 1:33 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5759 Location: Beaver Falls, PA. USA
| Top |
Who is online |
Users browsing this forum: Google Adsense [Bot], gvel, kuzzy, mikehall, neali, noisebox, radio-jim, Scott, simplex1040, Tlc, wazz, wwcarey and 9 guests |
