It is currently May Thu 23, 2013 10:54 pm
 Post subject: Admiral Phonograph/Radio 6J2 Sluggish Turntable
PostPosted: May Fri 04, 2012 5:00 pm
Hoping someone can help. I have an Admiral Phonograph/Radio Model 6J2 that I've restored. The radio sounds fine and so does the the phonograph. The trouble is, if I don't use the phonograph for a few days it's sluggish when it starts. Sometimes it gets stuck and I have to push it by hand. When it does start, it turns slowly. After a few minutes it gets up to speed and then it will play and records fine. I can use it all day and it will play. It's only after I haven't use it in a while that this happens. Has anyone had this problem with this particular unit? Any suggestions?
Thanks.
You can see it at work here:
http://www.youtube.com/watch?v=OTo1wW1GclU
 Post subject: Re: Admiral Phonograph/Radio 6J2 Sluggish Turntable
PostPosted: May Fri 04, 2012 5:14 pm
Dried grease is the culprite here, you need to remove the turntable and remove any old grease, it will have gone to a tar like substance.
Then you need to reapply.
PostPosted: May Fri 04, 2012 5:37 pm
I restored this record player. I cleaned the motor and I put new grease. It still has the problem.
PostPosted: May Fri 04, 2012 5:48 pm
Did you check the rubber drive wheel, if this is hard it will need to be replaced, this could be a cause.
I still think you may have missed something when lubing it, ive done it myself.
PostPosted: May Fri 04, 2012 6:00 pm
The idler wheel has new rubber. It was done by West-Tech. Maybe I'm using the wrong grease.
PostPosted: May Fri 04, 2012 6:19 pm
I hope you didnt find my posts patronising it wasnt meant that way, you have done a fantastic job on that machine, i was just trying to help you with the common faults.
I dont know that turntable, im more of a BSR/GARRARD man but the principals are the same, i have relubed all my turntables and i had issues like you and hadnt greasedit properly.
I hope someone else chimes in with more help
PostPosted: May Fri 04, 2012 6:41 pm
What kind of grease did you use? And what kind of oil did you use for the motor?
LOVE & LIGHT!
*MaryAntoinette*
You can take the Girl out of Brooklyn...
PostPosted: May Fri 04, 2012 8:07 pm
Lithium grease and 3M oil. Thanks.
PostPosted: May Sat 05, 2012 12:12 am
Nice admiral you've got there!
I'm betting, if you take the motor apart again, soak the bearings then clean and re-lube the motor with turbine oil, your problem will go away.
PostPosted: May Fri 18, 2012 3:22 pm
Thanks Ken. I bought the oil you suggested and re-lubed the motor and it's been working well ever since. It also helped to put back the c-clamp I accidentally left off the idler wheel.
PostPosted: May Fri 18, 2012 3:28 pm
Im glad you got it sorted its a great looking machine.
Post New Topic Post Reply  [ 11 posts ]  Moderator: Larry Hillis
Users browsing this forum: Chas and 2 guests
