Page 1 of 1
[ 15 posts ] |
| Author |
cwmoser
Post subject: Crinkled finish on Philco 41-280 ... Posted: Apr Mon 09, 2012 1:50 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3363 Location: Advance, NC USA
My Philco 41-280 radio has, for a better word, a crinkled finish: Attachment:
The finish looks dried out. What do you suggest to improve the appearance? I've recapped this radio and replaced the Escutcheon, buttons, and knobs - they were melted as it had been stored in a hot attic by the previous owner. Most of the rest of the cabinet looks pretty good. Carl
| Top |
Tlc
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Apr Tue 10, 2012 1:36 am |
| Member |
Joined: Oct Fri 21, 2011 11:11 pm Posts: 1008 Location: Rochester NY
I use refinisher with steel wool. Melts off the laquer, leaves the stain. Reapply laquer with desired sheen.
This assumes you like the colors/shades and not major wood repairs.
My 2c
Tim
| Top |
K4YDO
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Apr Tue 10, 2012 4:21 am |
Joined: Nov Mon 28, 2011 2:55 am Posts: 134 Location: Florence, SC 29506
Looks like you are making good progress.I started on a 285 yesterday. It's pretty bad.....see photo. Where did you get your parts? I can probably repair everything but the dial plate. The escutcheon shrunk and will have to be modified to get it to fit the knobs. Sure would like to find a dial plate, if not more !! Ed Attachment:
| Top |
cwmoser
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Apr Tue 10, 2012 1:03 pm |
| Member |
Tlc wrote: I use refinisher with steel wool. Melts off the laquer, leaves the stain. Reapply laquer with desired sheen.
My 2c
Tim Tim, Howards Refinisher??? Thanks Carl
| Top |
cwmoser
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Apr Tue 10, 2012 1:09 pm |
| Member |
Those old Philcos don't get much respect, but I find them to be great performers, have a lot of quality, and they look good. My 41-280 is the best AM and SW performer in my collection. My Escutcheon and pushbuttons looked like your radio - all distorted and melted. I got my Escutcheon and the pushbuttons at the Radio conference in Charlotte (CC-AWA). I think the vendor was Old Radio Parts -- http://www.OldRadioParts.netYou will have to re-use your brass strip. For the push buttons, I selected 7 brown ones and a red one - for the ON/OFF function. The Escutcheon and pushbuttons are reproductions that are nicely made. Replacing the Escutcheon and pushbuttons made a dramatic improvement in looks. Glass dial plates for these Philcos are available too. Don't recall where I saw them - anyone else have sources? Carl K4YDO wrote: Looks like you are making good progress.I started on a 285 yesterday. It's pretty bad.....see photo. Where did you get your parts? I can probably repair everything but the dial plate. The escutcheon shrunk and will have to be modified to get it to fit the knobs. Sure would like to find a dial plate, if not more !! Ed Attachment: Philco2 (Small).JPG
| Top |
Peter
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Apr Tue 10, 2012 1:19 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7205 Location: Indy
| Top |
Tlc
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Apr Tue 10, 2012 1:32 pm |
| Member |
cwmoser wrote: Tlc wrote: I use refinisher with steel wool. Melts off the laquer, leaves the stain. Reapply laquer with desired sheen.
My 2c
Tim Tim, Howards Refinisher??? Thanks Carl No, Formbys makes a "refinisher" that removes old top-coat. There are other brands too. This will leave the stain. You will use a lot of rags but it's effective. http://www.formbys.com/products/refinisher/Tim
| Top |
K4YDO
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Apr Tue 10, 2012 1:36 pm |
Peter wrote: I believe your dial glass is sold in reproduction by Radio Daze. Please check the link below: http://www.radiodaze.com/category/338.aspxPeter Thank you. Radio Daze has the dial listed. I'll check oldradioparts.org for the escutcheon also. My work is cut out for me !! Ed
| Top |
K4YDO
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: May Thu 03, 2012 1:11 pm |
K4YDO wrote: Peter wrote: I believe your dial glass is sold in reproduction by Radio Daze. Please check the link below: http://www.radiodaze.com/category/338.aspxPeter Thank you. Radio Daze has the dial listed. I'll check oldradioparts.org for the escutcheon also. My work is cut out for me !! Ed Update Here is the finished product. Mark O. had everything I needed. Thanks for the information. Ed Attachment:
| Top |
Geoff
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: May Thu 03, 2012 3:09 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1298 Location: Riverside, CA
K4YDO wrote: K4YDO wrote: Peter wrote: I believe your dial glass is sold in reproduction by Radio Daze. Please check the link below: http://www.radiodaze.com/category/338.aspxPeter Thank you. Radio Daze has the dial listed. I'll check oldradioparts.org for the escutcheon also. My work is cut out for me !! Ed Update Here is the finished product. Mark O. had everything I needed. Thanks for the information. Ed Attachment: Philco 1941 Dial (Small).JPG Attachment: Philco 1941 (Small).JPG Wow, looks very nice. Did you totally strip and refinish?
| Top |
Geoff
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: May Thu 03, 2012 3:12 pm |
| Member |
cwmoser wrote: The finish looks dried out. What do you suggest to improve the appearance?l Check out this thread: viewtopic.php?f=7&t=191049This technique may work for you. - Geoff
| Top |
Jeff_Neese
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: May Sat 05, 2012 1:35 pm |
Joined: Mar Sat 19, 2011 4:15 pm Posts: 362 Location: Chelsea, Michigan
My 2c
Tim The wood may not be stained underneath - the color was probably done with toning lacquer which, when removed, would remove the color as well.
| Top |
Tlc
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: May Sat 05, 2012 2:41 pm |
| Member |
If thats the case with the laquer cracking, so would be the stain and it would be time for new.
| Top |
Jeff_Neese
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: May Sat 05, 2012 9:07 pm |
After a thorough cleaning, spray another coat of lacquer. That will reflow the old layers to a certain extent, then spray with Mohawk Blush Remover/Retarder which will reflow even more. Works great - I've had some lizard-skin finishes that came out almost like new.
| Top |
Geoff
Post subject: Re: Crinkled finish on Philco 41-280 ... Posted: Jul Thu 12, 2012 12:14 am |
| Member |
Jeff_Neese wrote: After a thorough cleaning, spray another coat of lacquer. That will reflow the old layers to a certain extent, then spray with Mohawk Blush Remover/Retarder which will reflow even more. Works great - I've had some lizard-skin finishes that came out almost like new. Did you wait until the coat of lacquer fully dried before spraying the blush remover/retarder or while it was still wet? - Geoff
| Top |
Page 1 of 1
[ 15 posts ] |
Moderator: Peter |
Who is online |
Users browsing this forum: No registered users and 2 guests |
