I am restoring a Knight Kit Star Roamer. It uses a unique 4-in-1 electrolytic capacitor (brand name Lil J) that has values of 30-30-30-50 mf. Before I replace it with 4 individual electrolytic caps, is anyone aware of a modern 4-in-1 replacement for this? I've done a bit of web research and it appears that 4-in-1 electrolytics are no longer made.
CE Manufacturing makes new twist lock multi-section capacitors using the original machinery (expensive). I see that Antique Electronic Supply sells them, but I do not see the value you need. I would simply open it up and restuff it using 33 and 47mfd 160 volt radial lead electrolytics. If there is not room for all 4, one or more can be tacked in somewhere. There are methods for restuffing documented on the forum. Search using GOOGLE, site:antiqueradios.com
Joined: Oct Wed 14, 2009 6:36 am Posts: 3017 Location: New York USA
If that is a cardboard cylinder with wires, AES has the triple capacitor, and the fourth capacitor may be a small cathode bypass that can be hidden by the output tube, no one will notice. Don
