Page 1 of 1
[ 4 posts ] |
| Author |
orbanp
Post subject: Gluing a plastic radio case Posted: May Sat 05, 2012 5:37 pm |
Hello Everyone,
Just wondering, what people use for gluing cracked plastic transistor radio cases? I glued such plastic before with ABS cement, with super glue, and with "5 minute" epoxy, with various degrees of success. Which one is preferred, which one is stronger? Anything else I should consider using or should avoid?
Thanks, Peter
| Top |
orbanp
Post subject: Re: Gluing a plastic radio case Posted: May Wed 09, 2012 1:13 pm |
| Top |
VEK
Post subject: Re: Gluing a plastic radio case Posted: May Thu 10, 2012 1:52 am |
Joined: Jun Fri 01, 2007 9:46 pm Posts: 157 Location: Chattanooga, TN
I've used "Testors Plastic Cement", it's thinner than water and wicks into the crack and "welds" the plastic together. Cures quickly - not instantly. It says "No. 3502" on the bottle (1 oz). I've had it for years so I don't know if its still available (google it). Contains MEK so it has that wonderful airplane dope aroma.
Vince
| Top |
orbanp
Post subject: Re: Gluing a plastic radio case Posted: May Thu 10, 2012 1:37 pm |
Hi Vince,
Thanks for the comment! I googled that Testors Plastic Cement, it is still available. My main problem with the ABC cement was that it was too thick. I will try this.
Thanks, Peter
| Top |
Page 1 of 1
[ 4 posts ] |
Moderator: Peter |
Who is online |
Users browsing this forum: No registered users and 1 guest |
