Page 1 of 1
[ 8 posts ] |
| Author |
DKinYORKpa
Post subject: ballast tube question Posted: May Sat 05, 2012 4:53 pm |
Joined: Jul Sun 08, 2007 9:40 pm Posts: 2499 Location: Muscletown, USA
On my Silvertone 6120, it appears that one side of the internal resistor is open. So, from pin 3 to pin 8, I have 117 ohms. From pin 7 to pin 8 or pin 3 to pin 7, there's zero ohms. Which explains why the 46 lamp blows when the radio is turned on at full voltage. If I slowly raise the voltage, I'm fine, although the brightness and location of the lamp makes seeing the eye tube difficult. Is there a solution for the ballast problem? http://www.nostalgiaair.org/Resources/377/M0017377.htm
| Top |
Lou deGonzague
Post subject: Re: ballast tube question Posted: May Sat 05, 2012 9:29 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7005 Location: Latham NY
You need to replace that ballast tube. One point of clarification is when you say zero ohms what you really mean is your meter reads infinity, just the opposite of zero ohms which is a dead short.
| Top |
DKinYORKpa
Post subject: Re: ballast tube question Posted: May Sat 05, 2012 9:39 pm |
Quote: what you really mean My DVOM does nothing. No short.
| Top |
Lou deGonzague
Post subject: Re: ballast tube question Posted: May Sat 05, 2012 11:42 pm |
Right, that section is what is called an open circuit, same as having nothing connected to your meter. I recently restored a radio with a bad ballast by using a 6.5 mfd poly cap and a 50 ohm resistor for the pilot light. This produces very little heat and a soft warm up for the radio.
| Top |
Jack Shirley
Post subject: Re: ballast tube question Posted: May Sun 06, 2012 12:40 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8420 Location: SE USA
There are workarounds but you might check with Gary Schneider at PTOP oldradioparts.com to see if he has any replacements in stock.
_________________ The beatings will continue until the morale improves
| Top |
Norm Leal
Post subject: Re: ballast tube question Posted: May Sun 06, 2012 12:59 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28977 Location: Livermore, CA
| Top |
DKinYORKpa
Post subject: Re: ballast tube question Posted: May Sun 06, 2012 1:45 am |
I already tried a (on hand) 50 ohm 10 watt power resistor in place of the open side of the ballast. The pilot light is dangerously bright at power up, though. But it didn't burn up. I also take it that a ballast tube gets quite hot? BTW, that tube place in Florida lists my tube, but it says to call for a price. I'll see Monday.
| Top |
Norm Leal
Post subject: Re: ballast tube question Posted: May Sun 06, 2012 3:17 am |
Even with the correct ballast your lamp will flash bright at turn on. Some get around this by adding Zener diodes across the lamp.
_________________ Norm
| Top |
Who is online |
Users browsing this forum: No registered users and 3 guests |
