It is currently May Fri 24, 2013 2:56 pm
 Post subject: What would you do? Emerson 814 Dial
PostPosted: May Sat 05, 2012 3:29 pm
Hello all,
I've got this dial:
Its supposed to look like the picture here:
http://www.radiomuseum.org/r/emerson_81 ... b_120.html
I don't expect I can make it look identical, but a suggestion or two to make it look better would be much appreciated.... I thought about filling it in w/ epoxy putty, but then I came to my senses and decided I didn't think it would be smooth enough to look much better.
Maybe carefully sandpaper the insides so they're smoother, and then gold paint?
Suggestions please?
David
 Post subject: Re: What would you do? Emerson 814 Dial
PostPosted: May Sat 05, 2012 7:43 pm
Could you get a brass disc of the appropriate size and glue it on?
Something like this?
http://www.etsy.com/listing/84877825/br ... mpaign=GPS
Peter
http://antiqueradioblogger.com/peter
PostPosted: May Sat 05, 2012 11:16 pm
That's a pretty good idea.... if I can find one big enough. the space for the ring is almost 2 3/4".
If I can't find a brass disc big enough, I suspect I can at least find a piece of plastic of an appropriate size, paint it gold, and glue that in place.
This is one of those days I wish I had a lathe....
Thanks for the idea...
David
PostPosted: May Sun 06, 2012 1:44 am
I need the same kind of thing for my RCA 561 that is missing the disc from in the center of the speaker on the cabinet.
I was thinking of paint too. Those discs look nice but they appear to be flat and as thick and heavy as a washer and I know on mine it is a slight cone shape so would not work unless I had a way to stamp it into a cone shape.
If I ever come up with anything better then paint I will post it, and please post your final decision and outcome too.
tom B.
Tom B.
PostPosted: May Sun 06, 2012 2:04 am
Mine has a slight "cone" to it as well. I figure even a flat disc over it would look better than nothing at all. (Even with the mismatches)
I'll let you know what I come up with. Maybe someone else has an idea still?
David
PostPosted: May Sun 06, 2012 2:17 am
The cone shape is tough. I figure you can find a piece of brass in the right size, at least. That would do until another knob (or another method) shows up. I think lots of jewelry makers use these discs, the etsy link above mentions contacting them for other sizes.
Peter
PostPosted: May Sun 06, 2012 7:45 am
Little FYI - those brass cones were probably spun rather than stamped.
PostPosted: May Sun 06, 2012 8:54 am
I do know a decent jewler that has made jewlery for my wife in the past.
I may just pay him a visit to see if he could do someithing cheaply enough.
Tom B.
Post New Topic Post Reply  [ 8 posts ]  Moderator: Peter
Users browsing this forum: bassplyer9, Ed Engelken, Majestic-12 [Bot] and 1 guest
