Page 1 of 1
[ 13 posts ] |
| Author |
VintageTunes
Post subject: Metal knob inserts - how and where? Posted: May Mon 07, 2012 3:21 pm |
| Member |
Joined: Nov Tue 06, 2007 4:21 pm Posts: 2136 Location: Twin Falls, Idaho 83301
I am looking for the full round inserts that go in wooden radios. They have a grub screw on the side and will fit a variety of applications. I am mainly interested in pre-made ones and have no desire to cobble something together and tap the side for my own set screw. If you know of any place that sells them, thats great too. I have looked and cannot find a distributor for this particular item. thanks ~jeff
_________________ TESLA !! (the man....not the band)
| Top |
Rich, W3HWJ
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Mon 07, 2012 4:08 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 4885 Location: Santa Rosa, CA
I have made these for myself using my little metal lathe. Mine are made from aluminum or brass and use a 6-32 grub screw.
The one you show has a ridged or "reeded" O.D. which is apparently press-fit into the wood. I can't do the ridges, but I do knurl the O.D. then use a dab of epoxy to hold them in place.
What is the O.D., the length, and the shaft diameter?
| Top |
joybird
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Mon 07, 2012 4:27 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4235 Location: Wilmington, NC 28412 USA
I have hunted for these for quite some time.
I did find a Vendor a while back , but cost was out of sight. Mn order something like 500.
What I have been doing is steal from a Knob that could be considered salvage. Need to find some donor knobs. I have even stole from the chicken head knobs. The Hong Kong ones with set screw sucks.
What I did buy was some Bronze bushings , but I had to tap the Screw hole myself.
Hope some turn up or a source that is fair priced.
Bob T
| Top |
mrx
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Mon 07, 2012 11:51 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1921 Location: Massachusetts
| Top |
Ken G
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 1:06 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14637 Location: ID 83301
Langdons here in town says he can get them for 50c each .
| Top |
joybird
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 11:37 am |
| Member |
Ken G wrote: Langdons here in town says he can get them for 50c each . Put me down for 50 of them . How can we order ? Bob T
| Top |
k9uwa
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 12:58 pm |
Joined: Jun Wed 14, 2006 11:49 pm Posts: 4113 Location: Leo, IN
joybird wrote: Ken G wrote: Langdons here in town says he can get them for 50c each . Put me down for 50 of them . How can we order ? Bob T Hi Ken Put me down for 50 of them also. John k9uwa
| Top |
Dick Parks
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 2:40 pm |
| Member |
Joined: Jan Wed 13, 2010 5:11 pm Posts: 220 Location: Oakton, VA
Grainger sells these in brass and aluminum for pretty cheap.
_________________ Nothing is easy - everything is hard.
| Top |
k9uwa
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 3:58 pm |
Dick Parks wrote: Grainger sells these in brass and aluminum for pretty cheap. Dick perhaps you can find them in Grainger's catalog? Link and part numbers? thanks John k9uwa
| Top |
Rich, W3HWJ
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 4:25 pm |
You can get shaft collars from Grainger http://www.grainger.com/Grainger/DAYTON ... Pid=searchHowever: The OD may not match an existing knob and trying to expand the knob opening could be difficult. The shaft couplings have smooth finish on the OD. One should be able to rough this up with coarse sandpaper and then epoxy the coupling to the knob. Rich
| Top |
Bugman
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 8:05 pm |
Joined: Mar Sat 14, 2009 5:56 pm Posts: 2050 Location: RI, 02885
Use the set-screw to assist in keeping them from rotating in the wood. Cut the set-screws a little long so they remain extended in the wood when screwed down.
| Top |
Dick Parks
Post subject: Re: WTB: metal inserts for wooden radio knobs w/grub screw Posted: May Tue 08, 2012 9:21 pm |
| Member |
Zackly right! Here's how I made mine:
| Attachments: |
| Top |
baspas
Post subject: Re: Metal knob inserts - how and where? Posted: May Tue 29, 2012 12:47 am |
Joined: Dec Wed 16, 2009 4:18 am Posts: 61 Location: N.E. Ohio
If you have access to a lathe you can use old faucet shafts, they’re brass and they have the ridges. All you need do is drill through then cross drill and tap. You may not get the wall thickness from a standard faucet but you should be able to find something.
| Top |
Page 1 of 1
[ 13 posts ] |
Moderator: Peter |
Users browsing this forum: Google Adsense [Bot] and 2 guests |
