It is currently May Sat 25, 2013 2:22 pm
 Post subject: Philco 50 t 1403 - triple image ?
PostPosted: May Tue 08, 2012 12:38 pm
I thought I had a good idea where to look to solve this problem but it is proving to be even more of a challenge - Started this set a while back - all caps changed, tubes good, resisters checked for values - all seems ok but I have a triple picture. The first 3 seconds after a the crt comes to life gives a resonable picture but then it falls apart..... sound is fine - Im thinking there must still be a resistor somewhere that is not cooperating, one that is really close to its needed value but off enough to cause a problem - checked over the sync section for these buggers - any ideas guys???? Thanks in advance
Mr."G" :roll:
 Post subject: Re: Philco 50 t 1403 - triple image ?
PostPosted: May Tue 08, 2012 1:12 pm
I would suggest double checking your work and look at the values of caps replaced in the horizontal section.
After that, look around the H hold coil for opens or other problems.
PostPosted: May Tue 08, 2012 2:36 pm
Have you tried adjusting the Horizontal frequency coil yet?
This is either B4 or B10 on the Sams depending on which circuit your set uses.
These often need retouched after a recap, also check the value of the Caps you used around this coil.
PostPosted: May Tue 08, 2012 2:38 pm
How about mica caps in horizontal oscilator?
Bill Cahill
PostPosted: May Tue 08, 2012 4:52 pm
I'll check out B4 next I guess - mica caps have been checked and replaced as called for - I was very careful about capacitor values - Im very sure they're right - That couple of seconds of good play, then the picture going bad makes me wonder - that maybe something somewhere is going bad - Thanks for all the hints!!!!!!
Mr."G" :lol:
PostPosted: May Tue 08, 2012 6:15 pm
sub the horz osc tube.
Post New Topic Post Reply  [ 6 posts ]  Moderators: Mr. Detrola, 7jp4-guy
