It is currently May Fri 24, 2013 9:40 pm
Post New Topic Post Reply  [ 41 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Early Lloyd's TR-88H project - a neat radio !
PostPosted: Apr Sun 01, 2012 10:42 pm
Look at this one on ebay. Nanaola 6TP-902.
http://www.ebay.com/itm/Vintage-Nanaola ... 3a694234ec
We found another brand.
PostPosted: Apr Sun 01, 2012 11:26 pm
It uses 4 C batteries, and is untested.
Translation; either too cheap to have 4 C cells on hand, or tried it and it doesn't work.
PostPosted: Apr Mon 02, 2012 1:41 am
Thanks Jay---have plenty of volume & sound basically good, by "muddy" I mean a little "bassy garble"... Hard to describe---just not "clean"... Have to sample audio from detector onward with tracer when the "right" time comes around... Wonder if bias okay in P-P output---possible slight crossover distortion ? The radio does have an unusually low "noise floor" between stations---really quiet compared to most... And I agree about those 3-gang tuning caps---they peak my interest, also, as the tuned RF amp stage equipped sets are collection focus... Any more of them in your collection ? Sure enjoy seeing pics & reading about other's "projects"... Have seen pics of the Nanaola---its on the list... Wonder if it was was a "normal" U.S. import ? And I am also grateful for Steve's schematic posting---not much info on these sets on-line... A battery tube shouldn't be too hard to make---even thin cardboard rolled around batteries & glued should help...
And Fifties---think some might purposely not test so they don't have to admit they're non-working...
PostPosted: Apr Mon 02, 2012 5:52 am
I would check the base bias resistors in the audio section as a cause of distortion. Check the speaker also, by plugging in another through the earphone jack.
AFA sellers testing, as I said, either too cheap to have a few flashlight batteries around, or they know it doesn't work. With a battery only tube set, OTOH, it's understandable that they wouldn't normally have a 45 or 67.5 volt battery in the house.
PostPosted: Apr Sun 22, 2012 5:28 am
Found source of that slight audio distortion---weak batteries !!! Even though it played loud...
Sampled audio from detector at volume control with external amp & it was okay---at minimum... When turned up, noticed that distortion on both radio & amp---so monitored battery voltage & noticed it decreased when volume increased to point of noticeable distortion... Replaced batteries & now okay ! Glad it was that simple, but sure gave that "dumb" feeling !
Also have found a couple more names applied to "variants" of this chassis---Granada & Air Chief...
PostPosted: Apr Sun 22, 2012 8:49 am
You can add ORITONE to the list of models. This is the case of the TR88X. The rest of it may be yet
found.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Apr Mon 30, 2012 2:56 am
Another version discovered---Corvette ! Just saw it in an Ebay Canadian listing...
10 variants on my list so far...
PostPosted: May Sat 05, 2012 5:09 pm
And just saw another, Pilot TR-800, an Ebay listing from Israel...
They got a lot of "mileage" from that chassis !
PostPosted: May Sun 13, 2012 3:47 am
I believe Nanaou Radio Electrics first designed this radio as "NANAOLA" brand.
Nanaou had entered the subsidiary of Toshiba in 1957. That's why the radio uses many TOSHIBA transistors I think.
File comment: inside the NANAOLA
File comment: NANAOLA
File comment: another NANAOLA
File comment: TOSHIBA
File comment: AFCO
File comment: YORK
File comment: unknown
PostPosted: May Sun 13, 2012 5:22 am
Hello Mr. Ohta,
Thank you very much for the history info & pics ! That sure helps solve the "origin" mystery...
Was surprised to see that one model actually had a Toshiba "badge" !
Do you know what year the first of the Nanaola versions of this design were introduced ?
Thanks again...
PostPosted: May Sun 13, 2012 5:37 am
Hello, xrhonda91,
I'm not sure exactly but I think it's early 1960s. :D
Jinkei
PostPosted: May Fri 18, 2012 3:53 am
Well---Radio Shack also got into this game... Just saw a leather encased "Realistic TRF" version with this chassis on Ebay---was a "BIN" and went quick...
PostPosted: Aug Mon 20, 2012 2:01 am
In this thread, no one posted a instruction sheet for one of this series. Today, while digging
out some data in another forum I came across the Selfix TR802 sheet in my files from back then.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Aug Mon 20, 2012 2:32 am
Thanks Steve !
Neat to see that manual---like the "stow away" instructions...
Do you have a higher-res file that you could e-mail if I'd PM my address ?
PostPosted: Aug Mon 20, 2012 5:28 am
I would be happy to.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Aug Wed 22, 2012 3:37 pm
Here's another version of the radio I picked up from an old closed hardware store in Great Falls, MT..It was still in the box with the original batteries. Its marketed under the Honeytone brand. No scratches, everything there as original. The only problem was the handle was cracked, I've noticed others had that problem. I glued it back together without any problems. It is sensitive and plays really loud..I can post a pic if anyone wants to see it...Alan
forgot to mention the model 8tp-902
All tyranny needs to gain a foothold is for people of good conscience to remain silent.
TJ
PostPosted: Aug Thu 23, 2012 2:03 am
Hey Alan---sure interested in seeing pic(s) ! Please post...
PostPosted: Aug Thu 23, 2012 2:20 am
Since I've started indexing the Sam's TSM series, I've found lots of times where this radio
has been marketed under various trade names. Essentially, I have TSM-20 thru 58 completed.
When I get to #75 or so, I'll try to post the duplicates of this radio. Someone be sure to remind me.
~ Mitch ~
PostPosted: Aug Thu 23, 2012 2:48 am
Ok here it is, along with Nos toshiba c-cells. just follow the link I hope..Alan
if the link does not work for you I can put it in flickr also.
https://picasaweb.google.com/1043102008 ... 3284732162
here is flickr: http://www.flickr.com/photos/ke4nu_7/78 ... hotostream
TJ
PostPosted: Aug Thu 23, 2012 2:56 am
Sure would like to have the service info on this radio...even though it plays fine, ya never know...Alan
TJ
Post New Topic Post Reply  [ 41 posts ]  Moderator: Dave Doughty Go to page Previous  1, 2, 3  Next
Users browsing this forum: fifties, psbot [Picsearch] and 1 guest
