| Author |
mg34.42
Post subject: pf to mf Posted: May Thu 17, 2012 1:46 am |
Joined: Apr Thu 26, 2012 2:18 am Posts: 77 Location: Tulsa, ok
ok if you have a value of .0005 how do you convert that to pf benny
| Top |
jkoebel
Post subject: Re: pf to mf Posted: May Thu 17, 2012 1:49 am |
Joined: Aug Thu 27, 2009 7:47 am Posts: 1830 Location: Seattle
Code: 0.0000uF | |||| | |||100s pF | ||1000s pF | |10000s pF | 100000s pF 1,000000s pF
That'd be 500 pF in your case. Multiply the value in uF by one million to calculate the value in pF.
| Top |
Burnt Fingers
Post subject: Re: pf to mf Posted: May Thu 17, 2012 1:53 am |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
It would also have been listed as 500 mmf before the US was forced to switch to kiss European butts.
| Top |
Jack Shirley
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:05 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8405 Location: SE USA
Move the decimal point 6 places to go between mf and pf.
_________________ The beatings will continue until the morale improves
| Top |
threeneurons
Post subject: Re: pf to mf Posted: May Thu 17, 2012 3:28 am |
| Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 1783 Location: Los Angeles
Burnt Fingers wrote: It would also have been listed as 500 mmf before the US was forced to switch to kiss European butts.
Carl Well, at least we don't use nf ... yet.
_________________ If the women don't find you handsome, they should at least find you handy ! - Red Green
| Top |
clueless
Post subject: Re: pf to mf Posted: May Thu 17, 2012 4:19 am |
Joined: Aug Mon 29, 2011 4:08 am Posts: 1294 Location: The High Plains, but not drifting.
threeneurons wrote: Burnt Fingers wrote: It would also have been listed as 500 mmf before the US was forced to switch to kiss European butts.
Carl Well, at least we don't use nf ... yet. Milli, micro, nano, pico (or m, u, n, p) - it's all perfectly straightforward, 3 orders of magnitude at a time, I don't see what the big deal is. Those old schematics where "M" means two different things on the same drawing and you have to stop, think and use some common sense, OTOH...
| Top |
FrankB
Post subject: Re: pf to mf Posted: May Thu 17, 2012 7:36 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2116 Location: Olympia WA USA
Most of the newer TV and home entertainment schematics (Especially Philips) use NF designators now.
_________________ FrankB WB7ELC Member: TCA "I know that all that is wrong with it is one little part".
| Top |
neutronic
Post subject: Re: pf to mf Posted: May Thu 17, 2012 10:27 am |
Joined: Oct Fri 16, 2009 11:10 pm Posts: 173 Location: Bergen The Netherlands
It´s not so difficult. The only problem is that people confuse capital ¨M¨ with ¨m¨ Thanks to Napoleon whole Europa has (except Gr.Britain) the decimal system.
I found this list on the Internet with a little help to remember:
Every Exta 10*18 Person Peta 10*15 That Tera 10*12 Gave Giga 10*9 Me Mega 10*6 Kisses Kilo 10*3 Has Hecto 10*2 Diarea Deca 10*1
diary deci 10*-1 cows centi 10*-2 make milli 10*-3 milk micro 10*-6 not nano 10*-9 pink pico 10*-12 fruit femto 10*-15 a*hole atto 10*-18
Regards Jard N.
| Top |
Ron Pond
Post subject: Re: pf to mf Posted: May Thu 17, 2012 12:04 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1567 Location: Armadale, WESTERN AUSTRALIA. Tel; 61-8-9399-4978
Carl Who forced the US to kiss Euro arses? Australia went down the same path 40 or so years ago, ostensibly because of their ( now tenous) ties with the UK and Europe, but what would have forced you guys to follow suit? Ron.
| Top |
Burnt Fingers
Post subject: Re: pf to mf Posted: May Thu 17, 2012 1:43 pm |
The bloody socialist academics and pseudo intellectuals at IEEE. There was a huge battle where I worked when the switch was made. At least we still have mph and real road signs Carl
| Top |
clueless
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:12 pm |
OTOH, the US adopted a decimal currency while the UK still used Pounds, Shillings and Pence (2 Farthings to a Ha'apenny, 4 Farthings or 2 Ha'apennies to a Penny, 3D to a Thruppenny Bit, 6D to a Sixpence or Tanner, 2 Tanners or 12D to a Shilling or Bob, 2 Bob to a Florin, 20 Shillings to a Pound, etc).
| Top |
DragonForce
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:13 pm |
Joined: Feb Sun 05, 2012 3:41 pm Posts: 315 Location: Bristol, SW England
neutronic wrote: It´s not so difficult. The only problem is that people confuse capital ¨M¨ with ¨m¨ Thanks to Napoleon whole Europa has (except Gr.Britain) the decimal system. Don't you believe it! We have a decimal system in place and have since the early 70's. Many of us of a certain age however, still use imperial, even if it is somewhat different to yours. Examle, a gallon is 8 pints here, only 6 in the US
_________________ I smell smoke.....
| Top |
DragonForce
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:17 pm |
Carl Its usually the other way around - the USA defining the use of the English language. We spell it "colour", you spell it without the u. We say "zed" not "zee" - do you guys have any idea how annoying it is to hear out schoolkids saying ex why and zee? I tell ya, tis a good job we're allies! BTW, I AM only teasing you guys
| Top |
Norm Leal
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:21 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28949 Location: Livermore, CA
Gallon is 8 pints in the US.
_________________ Norm
| Top |
DragonForce
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:23 pm |
Norm Leal wrote: Gallon is 8 pints in the US. Not according to wiki The imperial gallon The imperial (UK) gallon, defined as 4.54609 L, is used in some Commonwealth countries and was originally based on the volume of 10 pounds of water at 62 °F (17 °C). (A US liquid gallon of water weighs about 8.33 pounds at the same temperature.) The imperial fluid ounce is defined as 1⁄160 of an imperial gallon. The US liquid gallon This gallon is defined as 231 cubic inches,[2] and is equal to exactly 3.785411784 litres or about 0.13368 cubic feet. This is the most common definition of a gallon in the United States. The US fluid ounce is defined as 1⁄128 of a US liquid gallon.
| Top |
clueless
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:28 pm |
DragonForce wrote: Norm Leal wrote: Gallon is 8 pints in the US. Not according to wiki. Norm is right that there are 8 US pints in a US gallon, but a US pint is smaller than an Imperial pint. Plug 1 us pint in imperial pints into Google and you get "1 US pint = 0.83267384 Imperial pints" (so a US gallon is about 6.6 Imperial pints).
| Top |
DragonForce
Post subject: Re: pf to mf Posted: May Thu 17, 2012 2:29 pm |
at least we're both right in out own way then  which is a good thing is it not?
| Top |
Rich, W3HWJ
Post subject: Re: pf to mf Posted: May Thu 17, 2012 4:29 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 4797 Location: Santa Rosa, CA
Quote: The bloody socialist academics and pseudo intellectuals at IEEE. We're not all socialists; maybe pseudo intellectuals. I don't recall the IEEE ever being able to force anyone to do anything. Lots of discussion and debating, but decisions got made by the companies who elected to change their spec systems. I think it 's the influence of international trade, rather than an intellectual conspiracy. I didn't want to give up on "kcs." ! Rich Senior Life Member, IEEE Vice-Chairman IEEE Power Semiconductor Committee (1984-1992)
| Top |
threeneurons
Post subject: Re: pf to mf Posted: May Thu 17, 2012 6:36 pm |
| Member |
DragonForce wrote: Norm Leal wrote: Gallon is 8 pints in the US. Not according to wiki My fault. I drank 2 pints, when they were in the middle of writing that wiki article. ... Threw off their calibration.
| Top |
BigBandsMan
Post subject: Re: pf to mf Posted: May Thu 17, 2012 6:38 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6032 Location: Raleigh NC USA
"Which weighs more, a pound of gold or a pound of lead?" Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
Who is online |
Users browsing this forum: Google [Bot], threeneurons and 2 guests |
