| Author |
akent36
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Fri 04, 2012 7:25 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 765 Location: Rockford IL USA
Also try Murphy's Oil Soap and Lemon Oil.
| Top |
Ron in Radio Heaven
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Fri 04, 2012 9:59 pm |
| Member |
Joined: May Wed 03, 2006 4:47 am Posts: 3236 Location: Radio Heaven, North Carolina, near Charlotte, 28106-3015
| Top |
W2CKL
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Fri 04, 2012 10:12 pm |
| Member |
Joined: Mar Fri 11, 2011 4:21 pm Posts: 684 Location: Hunter NY
I've used the Olde English Scratch cover in the past with good results, but never the GoJo trick....until I read this post. Great results, thanks for the tip. EDIT: The product I used was sold under the GOOP name, same results but a better (Orange) smell.
| Top |
philcolynn
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sat 05, 2012 5:34 am |
Joined: Feb Mon 27, 2012 5:56 am Posts: 787 Location: St. Cloud, Minnesota
I haven't had any luck finding it in our town! Was disappointed that Home Depot, Mills Fleet and Menards all had pumice but not non-pumice! I will try the little handyman stores next. Lynn
| Top |
N2BEW
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sat 05, 2012 6:13 am |
| Member |
Joined: Feb Fri 17, 2012 11:32 am Posts: 107 Location: Valatie, N.Y. USA
I'm new to restorations and haven’t done any cabinets yet, so I have a probably redundant question about the Go-jo. But, I have a Philco 610 that has a decent original finish I want to preserve, but clean. This sounds like the way to go but in some of the photos already posted of the Go-Jo treatment it is such a dramatic change I have to ask is it taking off any finish or just cleaning it? I don't want to change the existing finish or underlying stain. I do realize it will lighten it just from cleaning it to some degree, but there is such a dramatic lightning in some of the posted photos it almost looks to me like it took off some finish and lightened the staining? Thanks, Tom B.
_________________ Tom B.
| Top |
Tommgb
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sun 06, 2012 10:34 pm |
Joined: May Mon 30, 2011 10:12 pm Posts: 242 Location: Glendale, CA
Go-Jo can usually be found at auto parts stores. I've bought mine at Auto Zone and Pep Boys. You also might be able to find it in the auto parts section at department stores. It was mainly what mechanics used to clean the nasty grease off their hands. The cheapest I've ever paid was $1.00, but usually it's a bit more. Tom
_________________ "A challenge to be met, rather than an obstacle to avoid." - Mr. Data
| Top |
gramophoneshane
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Mon 07, 2012 6:24 am |
| Member |
Joined: Apr Sat 12, 2008 8:44 pm Posts: 1021 Location: Brisbane, Queensland, Australia
N2BEW wrote: I'm new to restorations and haven’t done any cabinets yet, so I have a probably redundant question about the Go-jo. But, I have a Philco 610 that has a decent original finish I want to preserve, but clean. This sounds like the way to go but in some of the photos already posted of the Go-Jo treatment it is such a dramatic change I have to ask is it taking off any finish or just cleaning it? I don't want to change the existing finish or underlying stain. I do realize it will lighten it just from cleaning it to some degree, but there is such a dramatic lightning in some of the posted photos it almost looks to me like it took off some finish and lightened the staining? Thanks, Tom B. I'm guessing mine is one of the photos you're refering to. This gramophone was covered in nicotine which had darkened to original finish on every surface of the exterior. The interior, like in the turntable compartment and the back of the doors, were still in great original condition and didn't even need cleaning. Being a fairly heavy smoker, I couldn't smell nicotine on the cabinet until I started cleaning it, but as soon as I applied the cleaner, the smell of nicotine nearly knocked my head off. After cleaning the exterior of the cabinet, it matched the good original interior finish really well, so no finish was removed or stain was lightened.
_________________ Shane
| Top |
dmikesell
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Mon 07, 2012 2:48 pm |
Joined: Feb Mon 01, 2010 3:07 pm Posts: 91 Location: Shenandoah Valley, VA
I've seen Goop at our local WalMart, in the automotive section. I'll have to give this a try soon.
| Top |
N2BEW
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Tue 08, 2012 11:54 am |
| Member |
Yes, That was one. It looks great, and I do see it cleaned it to look like what it is on the inside. I am going to get some Go-Jo and use the "treatment".
Thanks for the reply. Tom B.
| Top |
wrnewton
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sat 19, 2012 8:18 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5529 Location: Cleona, PA
Goop in the "hand lotion" shaped orange bottle is pumice-free, smells like oranges, and is great to use. Harbor Freight, some auto parts stores. When I find it I buy several bottles.
_________________ Reece
| Top |
BOB BONCHAK
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sun 20, 2012 2:17 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1287 Location: SOUTHLAKE, TX, USA
Pumice (followed by Rotenstone) is a recommended procedure for rubbing out( lacquer, et al) finishes. I've had great success with that two step procedure. So, why is the Go Jo (or Goop) without pumice recommended? Is it because the referenced procedure is designed to just clean, and not abrade/flatten the surface? Just thought I'd seek a clarification. BOB
| Top |
Ron in Radio Heaven
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sun 20, 2012 2:55 am |
| Member |
| Top |
BOB BONCHAK
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sun 20, 2012 3:19 am |
A friend, who reconditions used cars for resale, uses Go Jo (GOOP) for interior (dashboard's, etc) clean up. It works great fo that purpose. BOB
| Top |
Nelson in Winnipeg
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sun 20, 2012 6:48 am |
Joined: Feb Fri 05, 2010 6:14 am Posts: 913 Location: Winnipeg, Canada
Lynn et al... I finally found the white Gojo (actually my wife did) among the tools in Walmart here.
Question: Has anyone tried to refinish a cabinet after using Gojo on it? Any problems? Nelson
_________________ "Never get between electricity and where it wants to go." -Red Green
| Top |
Ron in Radio Heaven
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Sun 20, 2012 11:33 am |
| Member |
Nelson in Winnipeg wrote: Lynn et al... I finally found the white Gojo (actually my wife did) among the tools in Walmart here.
Question: Has anyone tried to refinish a cabinet after using Gojo on it? Any problems? Nelson If you do the full "treatment" ending up with coats of wax, you'll need to use mineral spirits to strip the wax off before you refinish. Goop or GoJo won't leave anything on the finish, it's just a cleaner that you wipe off with the dirt.
_________________ 73, Ron w4ron http://radioheaven.homestead.com/menu.html http://antiqueradiocharlotte.homestead.com
| Top |
13crhuber
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Mon 21, 2012 2:05 am |
| Member |
Joined: Mar Sat 03, 2012 4:32 am Posts: 130 Location: Minnesota
Nobodys tried to "guess that radio" yet? From what i can tell it is a Philco 40-216?
_________________ "Music these days-It's just noise"
| Top |
wrnewton
Post subject: Re: Amazing what a little Go-Jo can do! Posted: May Mon 21, 2012 11:46 pm |
The pumice in ordinary hand cleaner is too harsh for refinishing purposes. Pumice or rottenstone used in rubbing down lacquer is very fine powder.
| Top |
mescalero
Post subject: Re: Amazing what a little Go-Jo can do! Posted: Jun Sun 03, 2012 5:18 pm |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2802 Location: Dallas, TX - in the city but with bobcats and coyotes
wrnewton wrote: The pumice in ordinary hand cleaner is too harsh for refinishing purposes. Pumice or rottenstone used in rubbing down lacquer is very fine powder. +1! you can feel the grit in the hand cleaner. Not good for final polishing.
_________________ In a triode, no one can hear you screen.
| Top |
superzeeman
Post subject: Re: Amazing what a little Go-Jo can do! Posted: Jun Mon 04, 2012 8:10 pm |
| Member |
Joined: May Sun 13, 2012 2:30 pm Posts: 277 Location: Mapleton, Mn
I think I just made a huge newbie error. I have one of the "bullhorn" RCA with the faux wood grain. Plastic cabinet I beleive. I started using the goop/gojo non pumice and it removed the wood grain. After further research, I dont see you guys using it on plastic/bakelite cabs. :(
_________________ It's a dog eat dog world and I'm wearing Milk Bone underwear.
| Top |
Ron in Radio Heaven
Post subject: Re: Amazing what a little Go-Jo can do! Posted: Jun Mon 04, 2012 9:42 pm |
| Member |
| Top |
Users browsing this forum: compucat and 1 guest |
