Page 1 of 1
[ 2 posts ] |
| Author |
7jp4-guy
Post subject: Hickok test Data for Raytheon Type B-H Tube Posted: May Sun 20, 2012 10:36 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1849 Location: Cambridge, Massachusetts, USA
Does anyone have test data for a Raytheon Type B-H tube? Data for Hickok 6000, 800, or 752 would be acceptable.
Thanks! Matthew
_________________ If it ain't broken, you’re not trying hard enough...
| Top |
Norm Leal
Post subject: Re: Hickok test Data for Raytheon Type B-H Tube Posted: May Sun 20, 2012 11:47 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28953 Location: Livermore, CA
Matthew
No tube tester data but I can tell you something about BH. Plates are on pins #1 and #4, cathode pin #2. This is different from most rectifiers. It's a gas rectifier similar to 0Z4 but 4 pin base. Voltage drop is 90 volts.
You could put positive voltage on pin #1 and draw current, through a resistor, from pin #2. Since the tube has a high voltage drop need more than 100 volts. If you get current the BH is usable.
_________________ Norm
| Top |
