It is currently Jun Tue 18, 2013 10:32 pm
Post New Topic Post Reply  [ 47 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Amazing what a little Go-Jo can do!
PostPosted: May Fri 04, 2012 7:25 pm
Also try Murphy's Oil Soap and Lemon Oil.
PostPosted: May Fri 04, 2012 9:59 pm
NEVER, NEVER, NEVER put oil on wood cabinets.
The oil will never get completely dry so it will collect dust and dirt
and just build up.
A good hand rubbed wax finish is the ONLY way to go.
73, Ron w4ron
http://antiqueradiocharlotte.homestead.com
PostPosted: May Fri 04, 2012 10:12 pm
I've used the Olde English Scratch cover in the past with good results, but never the GoJo trick....until I read this post. Great results, thanks for the tip.
EDIT: The product I used was sold under the GOOP name, same results but a better (Orange) smell.
PostPosted: May Sat 05, 2012 5:34 am
I haven't had any luck finding it in our town! Was disappointed that Home Depot, Mills Fleet and Menards all had pumice but not non-pumice! I will try the little handyman stores next. :D
Lynn
PostPosted: May Sat 05, 2012 6:13 am
I'm new to restorations and haven’t done any cabinets yet, so I have a probably redundant question about the Go-jo.
But, I have a Philco 610 that has a decent original finish I want to preserve, but clean. This sounds like the way to go but in some of the photos already posted of the Go-Jo treatment it is such a dramatic change I have to ask is it taking off any finish or just cleaning it?
I don't want to change the existing finish or underlying stain. I do realize it will lighten it just from cleaning it to some degree, but there is such a dramatic lightning in some of the posted photos it almost looks to me like it took off some finish and lightened the staining?
Thanks, Tom B.
Tom B.
PostPosted: May Sun 06, 2012 10:34 pm
Go-Jo can usually be found at auto parts stores. I've bought mine at Auto Zone and Pep Boys. You also might be able to find it in the auto parts section at department stores. It was mainly what mechanics used to clean the nasty grease off their hands. The cheapest I've ever paid was $1.00, but usually it's a bit more. Tom
"A challenge to be met, rather than an obstacle to avoid." - Mr. Data
PostPosted: May Mon 07, 2012 6:24 am
Thanks, Tom B.
I'm guessing mine is one of the photos you're refering to.
This gramophone was covered in nicotine which had darkened to original finish on every surface of the exterior. The interior, like in the turntable compartment and the back of the doors, were still in great original condition and didn't even need cleaning.
Being a fairly heavy smoker, I couldn't smell nicotine on the cabinet until I started cleaning it, but as soon as I applied the cleaner, the smell of nicotine nearly knocked my head off.
After cleaning the exterior of the cabinet, it matched the good original interior finish really well, so no finish was removed or stain was lightened.
Shane
PostPosted: May Mon 07, 2012 2:48 pm
I've seen Goop at our local WalMart, in the automotive section. I'll have to give this a try soon.
PostPosted: May Tue 08, 2012 11:54 am
Yes,
That was one. It looks great, and I do see it cleaned it to look like what it is on the inside.
I am going to get some Go-Jo and use the "treatment".
Thanks for the reply.
Tom B.
Tom B.
PostPosted: May Sat 19, 2012 8:18 pm
Goop in the "hand lotion" shaped orange bottle is pumice-free, smells like oranges, and is great to use. Harbor Freight, some auto parts stores. When I find it I buy several bottles.
Reece
PostPosted: May Sun 20, 2012 2:17 am
Pumice (followed by Rotenstone) is a recommended procedure for rubbing out( lacquer, et al) finishes. I've had great success with that two step procedure. So, why is the Go Jo (or Goop) without pumice recommended? Is it because the referenced procedure is designed to just clean, and not abrade/flatten the surface? Just thought I'd seek a clarification.
BOB
PostPosted: May Sun 20, 2012 2:55 am
That's absolutely right, it's intended to clean and not abrade the finish.
73, Ron w4ron
PostPosted: May Sun 20, 2012 3:19 am
A friend, who reconditions used cars for resale, uses Go Jo (GOOP) for interior (dashboard's, etc) clean up. It works great fo that purpose.
BOB
PostPosted: May Sun 20, 2012 6:48 am
Lynn et al... I finally found the white Gojo (actually my wife did) among
the tools in Walmart here.
Question: Has anyone tried to refinish a cabinet after using Gojo on it?
Any problems?
Nelson
"Never get between electricity and where it wants to go." -Red Green
PostPosted: May Sun 20, 2012 11:33 am
Nelson in Winnipeg wrote:
Lynn et al... I finally found the white Gojo (actually my wife did) among the tools in Walmart here.
Any problems? Nelson
If you do the full "treatment" ending up with coats of wax, you'll
need to use mineral spirits to strip the wax off before you refinish.
Goop or GoJo won't leave anything on the finish, it's just a cleaner
that you wipe off with the dirt.
73, Ron w4ron
PostPosted: May Mon 21, 2012 2:05 am
Nobodys tried to "guess that radio" yet? From what i can tell it is a Philco 40-216?
"Music these days-It's just noise"
PostPosted: May Mon 21, 2012 11:46 pm
The pumice in ordinary hand cleaner is too harsh for refinishing purposes. Pumice or rottenstone used in rubbing down lacquer is very fine powder.
Reece
PostPosted: Jun Sun 03, 2012 5:18 pm
+1!
you can feel the grit in the hand cleaner. Not good for final polishing. :shock:
PostPosted: Jun Mon 04, 2012 8:10 pm
I think I just made a huge newbie error. I have one of the "bullhorn" RCA with the faux wood grain. Plastic cabinet I beleive. I started using the goop/gojo non pumice and it removed the wood grain. After further research, I dont see you guys using it on plastic/bakelite cabs. :(
It's a dog eat dog world and I'm wearing Milk Bone underwear.
PostPosted: Jun Mon 04, 2012 9:42 pm
I can't imagine why it took the wood grain off.
I don't do radios in bakelite or plastic cabinets hardly ever,
but I have used it on balelite and hard rubber panels on 20s
battery sets with no problem.
73, Ron w4ron
Post New Topic Post Reply  [ 47 posts ]  Moderator: Peter Go to page Previous  1, 2, 3  Next
Users browsing this forum: Google [Bot] and 0 guests
