| Author |
Ken G
Post subject: Radio shack destroys nice radio ..but i FIXED it Posted: May Wed 23, 2012 2:16 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14580 Location: ID 83301
A customer brought me a mint condition Sony CRF 160 multiband radio . He was using it on batterys . He took it to retard shack to see if they had a power cord for it . This older radio has a 4 pin socket for the cord . Sony did this alot because they provided a 12 volt cord that fit the same hole . You guessed it . The moron at rodeo shack grabbed any old power cord and then applied 125VAC directly on the 12VDC pins ..... POOF . They then sent the radio to another retard shack to get it fixed . They sent it back unfixed . They also charged this guy 84$ for the estimate and shipping . I took the radio apart today to find stuff fried on both the amp and the tuner board . Resistors blasted in half , transistors shorted and possible amplifier output transformer . I dont think this is fixable . First off this would take alot of time and i have to charge people . The amplifier board is easy to get to but the only bad thing here is that possible transformer . 3 leads . From center tap in now reads 7K to one side and 95 ohms to the other . The tuner board is stuck in there to be bomb proof . It has a row of pushbuttons all over it and 50 wires all under stuff . 125vac went all the way through the 12vdc B+ chain It makes me sick to see this mint radio now garbage Anyone have a real beat up 160 ?
| Top |
Salval
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 2:58 am |
| Member |
That really sucks. I'll keep an eye out the next time I meander through the local flea malls.
| Top |
Brett_Buck
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 3:11 am |
Joined: Aug Wed 24, 2011 4:35 am Posts: 1272 Location: Sunnyvale CA
Ken G wrote: A customer brought me a mint condition Sony CRF 160 multiband radio . He was using it on batterys . He took it to retard shack to see if they had a power cord for it . This older radio has a 4 pin socket for the cord . Sony did this alot because they provided a 12 volt cord that fit the same hole .
You guessed it . The moron at rodeo shack grabbed any old power cord and then applied 125VAC directly on the 12VDC pins ..... POOF . They then sent the radio to another retard shack to get it fixed . They sent it back unfixed . They also charged this guy 84$ for the estimate and shipping . Hmm, they blew up his radio, then charged him for telling him they couldn't fix it? Nice. I am surprised that they had a 4-pin connector cord, or that they still claim to repair radios. Brett
| Top |
RepairTech
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 3:14 am |
| Member |
Joined: Jan Sun 24, 2010 7:59 am Posts: 6171 Location: Pro Tech, Philadelphia Pa.
I suppose those colledge grads working at rat shack don't know anything past cellphones.
_________________ "Accept the fact that some days you are the pigeon, and some days you are the statue."
| Top |
cl350rr
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 3:28 am |
| Member |
Joined: Oct Sat 15, 2011 12:19 am Posts: 656 Location: Virginia Beach
it has been about 15 years since I got any useful electronic advise from someone working in a radio shack. I had to actuallly explain fuse holders to a worker there a few months back
_________________ Currently (and still) on the bench: NC120/RAO-2
That's good morning, wedgie style
| Top |
Brett_Buck
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 4:01 am |
RepairTech wrote: I suppose those colledge grads working at rat shack don't know anything past cellphones. I don't think there are a lot of college graduates working at RS. All I see are McDonalds rejects. Brett
| Top |
N7ZAL
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 4:26 am |
| Member |
Joined: Jul Wed 21, 2010 11:04 pm Posts: 2438 Location: Roaming the West
Quote: Hmm, they blew up his radio, then charged him for telling him they couldn't fix it? Might be able to get some compensation from the local or regional manager. Of course the kid would be "let go." Probably gets a better job in the medical field
_________________ LAter, 73's Bill N7ZAL http://www.westernwoodartist.com http://www.southwestwoodcrafts.com
| Top |
Brian Stroud
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 4:42 am |
Joined: May Mon 07, 2012 4:01 am Posts: 293 Location: Rome, PA
Ken G wrote: A customer brought me a mint condition Sony CRF 160 multiband radio . He was using it on batterys . He took it to retard shack to see if they had a power cord for it . This older radio has a 4 pin socket for the cord . Sony did this alot because they provided a 12 volt cord that fit the same hole . You guessed it . The moron at rodeo shack grabbed any old power cord and then applied 125VAC directly on the 12VDC pins ..... POOF . They then sent the radio to another retard shack to get it fixed . They sent it back unfixed . They also charged this guy 84$ for the estimate and shipping . I took the radio apart today to find stuff fried on both the amp and the tuner board . Resistors blasted in half , transistors shorted and possible amplifier output transformer . I dont think this is fixable . First off this would take alot of time and i have to charge people . The amplifier board is easy to get to but the only bad thing here is that possible transformer . 3 leads . From center tap in now reads 7K to one side and 95 ohms to the other . The tuner board is stuck in there to be bomb proof . It has a row of pushbuttons all over it and 50 wires all under stuff . 125vac went all the way through the 12vdc B+ chain It makes me sick to see this mint radio now garbage Anyone have a real beat up 160 ? Unbelievable.  If it were me I'd want to take someone's head and use it as a soccer ball.
| Top |
gtc
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 5:11 am |
| Member |
And the owner actually paid the $84 demanded by RS for destroying his radio?
_________________ The older I get, the better I was.
| Top |
Nick D.
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 5:16 am |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6734 Location: "Amish Country", PA
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
RepairTech
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 5:43 am |
| Member |
Brett_Buck wrote: RepairTech wrote: I suppose those colledge grads working at rat shack don't know anything past cellphones. I don't think there are a lot of college graduates working at RS. All I see are McDonalds rejects. Brett But I betcha they can text on a cellphone better than the average person!
| Top |
PBPP
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 6:40 am |
Joined: Jun Tue 21, 2011 8:27 pm Posts: 2077 Location: Virginia
RepairTech wrote: I suppose those colledge grads working at rat shack don't know anything past cellphones.  LOL. - You still bitching about college grads? - Insecure or something? ? ~ Mitch ~
| Top |
Nick D.
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 6:44 am |
| Member |
Yeah, RT.... in a couple of years, I'm going to be taking such remarks personally.
| Top |
Joseph Newton
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 7:11 am |
| Member |
Joined: Aug Fri 13, 2010 5:29 am Posts: 1216 Location: Spencer,IN
The smartest person at my rat shack is a 21 year old blonde girl(at least she knew what solder was). I actually saw one of the "men" their inhaling can air at the register, of course I live in a college town so this type of employee is common.
Did I mention how they bombarded me about upgrading my 6 year old phone? I literally walked out during his lecture.
| Top |
FrankB
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 9:08 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2117 Location: Olympia WA USA
Have the radio owner contact Tandy Corp HQ in Ft. Worth TX and ask for the CEO's office, and ask for the CEO. Typically you will get one of their assistants who are great to work with. They will, at least in my own experience, go the extra mile to take care of you, unlike the RS retail stores.
_________________ FrankB WB7ELC Member: TCA "I know that all that is wrong with it is one little part".
| Top |
gtc
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 10:28 am |
| Member |
FrankB wrote: Have the radio owner contact Tandy Corp HQ in Ft. Worth TX and ask for the CEO's office, and ask for the CEO. Typically you will get one of their assistants who are great to work with. They will, at least in my own experience, go the extra mile to take care of you, unlike the RS retail stores. Agree with this suggestion. The owner can't just meekly cop this unjust crap from RS. At the very least they owe him the $84 back.
| Top |
fifties
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 11:20 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8757 Location: SoCal, 91387
gtc wrote: The owner can't just meekly cop this unjust crap from RS. At the very least they owe him the $84 back. They not only owe him the 84 bux back, but either an actual repair on the receiver so it works correctly, or an equal replacement. That would be the only way to "make him whole" again, and should be what he requests when contacting the honcho at Tandy Corp. And the character who fried it being let go? Absolutely, and maybe next time he will be more careful with a customer's item brought in for an accessory. Ken, tell your customer he's got to be bold with them. He's been harmed, and deserves restitution.
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
zenith82
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 11:37 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3612 Location: Baltimore, MD
Joseph Newton wrote: I actually saw one of the "men" their inhaling can air at the register. That speaks volumes and I can't say I'm surprised. Exactly why I never deal with RS anymore.
_________________ Tom
PM me for my email address
| Top |
Tube Radio
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 1:44 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7879 Location: Warner Robins, GA
That canned air is usually R134A which is harmful.
Seriously though the people at Radio Shack need to give him his $84.00 back and a radio just like he had or an equal equivalent in function and performance.
Had it been me I would have refused to pay the $84.00 and told them they would be hearing from my lawyer if they didn't replace my radio.
Normally when I walk into a Radio Shack I already know what I need and where to find it. What Radio shack needs in each store is one person to run the registers and handle most of the stuff then have one person who went to electronics school specifically for the parts and kits they have.
| Top |
wazz
Post subject: Re: Radio shack destroys nice radio Posted: May Wed 23, 2012 2:08 pm |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2059 Location: Ohio
So where do you think an "electronics school graduate" and RS management will meet on a salary? That might be the reason they don't have a staff of EE's or something, working there anymore. Nobody goes to school for electronics anymore, anyway, except for mil. training. They all go to school to learn computers, and of course, probably have a surface understanding of how to connect up the "hardware". They don't give a *** what all those little bitty components inside are, and they are too tiny to see anyway. You don't fix those anymore!
| Top |
