It is currently Jun Wed 19, 2013 1:40 am
Post New Topic Post Reply  [ 440 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22  Next
 Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic)
PostPosted: Apr Mon 16, 2012 9:57 pm
Blustar1 wrote:
Bill: You could use a hand wound toroid for L3 like I did, but it's hardly worth the effort and expense.
Most builders of these Tx don't want to hassle with winding coils...
PostPosted: Apr Tue 17, 2012 3:29 pm
I'll just make it an option
KB3QNN 73
PostPosted: Apr Tue 17, 2012 11:55 pm
Bill: For L3 (470uH), I used a FT-82-61 Ferrite Toroid which I purchased from Amidon. This required exactly 70.875" of #27 magnet wire wound 82 turns and allowing for 1.125" lead lengths.
PostPosted: Apr Wed 18, 2012 3:10 am
As I sit here listening to Nick Carter, Master Detective, on my Stromberg-Carlson 535M it occurs to me I have never thanked 35Z5 and all the folks who helped me through my construction process building this great little xmitter. Sooo, THANK YOU!!
kb3wbb
My radio files free download page:
http://www.enter.net/~rocketeer/radio/radio2.html
PostPosted: Apr Wed 18, 2012 4:56 am
bill hamre wrote:
Bluestar,
Give me the spec that worked and I'll start supplying toroid as L3. Core #, wire size, number of turns.
Bill
Suggestion, it might be cheaper to use a molded 470uH choke for L3. A lot of modern
equipment uses them for resonant LC circuits. They have pretty decent Q.
Pete
PostPosted: Apr Wed 18, 2012 7:09 pm
Blustar1: thanks for the toroid specs
Pete: I'll stock what you suggest for L3, have you a source and parts #?
KB3QNN 73
PostPosted: Apr Wed 18, 2012 11:34 pm
Bill, I'd feel better if someone tried one first before you invest funds in
a bunch of them.
You get molded 470uH chokes on eBay, free shipping for cheap prices.
http://www.ebay.com/itm/10-x-1-2W-470uH ... 0530156745
For 99 cents for ten, shipped, it is worth a shot.
Pete
PostPosted: May Tue 01, 2012 4:22 pm
Halfway there on #2. I need one 7 pin tube socket and a 12CS6 tube yet. I'm hoping to find what I need at Kutztown in a couple of weeks.
Here's a quick rough mockup of the front panel. That will be an ammeter in the upper left.
kb3wbb
PostPosted: May Tue 01, 2012 4:59 pm
Very nice work there.
What piece of test equipment was originally in that case?
That is similar to what I did with my 6GY6 two tube broadcaster. I used an old automotive tester for my chassis.
I plan to add at least one meter to measure 6GY6 cathode current.
PostPosted: May Tue 01, 2012 7:50 pm
It's the case from an old EICO model 950, like this (not mine).
kb3wbb
PostPosted: May Tue 01, 2012 8:00 pm
Very nice.
PostPosted: May Sun 13, 2012 4:59 pm
Impressive, and very creative! What a neat job!
PostPosted: May Sun 13, 2012 10:06 pm
Back from Kutztown with the tubes and parts I still needed so it's time to finish up this puppy.
kb3wbb
PostPosted: May Fri 25, 2012 3:07 pm
Finished, up and running. Ignore the ammeter, it's a bad unit that's in there basically for looks.
kb3wbb
PostPosted: May Fri 25, 2012 4:13 pm
DYN O MITE. Drool! It looks totally commercially made.
Dale
PostPosted: May Fri 25, 2012 4:58 pm
Sacre bleu! It looks totally awesome! Nice job!
PostPosted: May Fri 25, 2012 7:26 pm
Agreed, that's nice construction...
Since the meter is bad, sick a toothpick in the movement jamming it at around 2A, that'll have em talking...
PostPosted: May Fri 25, 2012 9:37 pm
:D , yep, that'll work. Reminds me of back when computers were running at 100Mhz (486). I installed a digital display on the front of mine and hard-wired it to display 400Mhz. It drove people nuts trying to figure out what proc I was running. :wink:
kb3wbb
PostPosted: May Sat 26, 2012 12:24 am
I did something similar with my 300 MHz Celeron machine overclocked to 475 Mhz, except it was also a BP6 DUAL PROCESSOR (gasp, wow) so the 'speed' display was jumpered for a 'technically valid' 950, which raised a few eyebrows because there were no 950 MHz processors at the time.
I've still got that machine in service.
PostPosted: May Sat 26, 2012 6:01 am
Would be nice if computer cases still had a display for the processor speed.
Users browsing this forum: jdivito, threeneurons and 4 guests
