It is currently Jun Wed 19, 2013 10:12 am
 Post subject: ID Volt Meter
PostPosted: May Sun 27, 2012 1:00 am
Anyone, can you tell me what test equip this meter came from? Top of meter has "SENIO VOLt OHMYST" bottom is "Radio Corp of America", Sorry see at http://s531.photobucket.com/albums/dd353/celetg/
Thanks, frank
 Post subject: Re: ID Volt Meter
PostPosted: May Sun 27, 2012 2:18 am
Probably one of these. There were several different models.
http://antiqueradio.org/RCAWV-97ASeniorVoltOhmyst.htm
The lucky ones realize the "Good Ole Days" while they are still in them!
AA5LP
PostPosted: May Sun 27, 2012 2:22 am
Well, it's obviously from an RCA Senior Voltohmyst VTVM. Looks to me to be from a WV-97 http://antiqueradio.org/RCAWV-97ASeniorVoltOhmyst.htm rather than a WV-98 http://www.radiomuseum.org/r/rca_senior_voltohmyst_wv_98c.html, but I'm no expert on them.
Best regards,
Steve
PostPosted: May Sun 27, 2012 2:44 am
Thanks, now for another question, is the senior meter the same as the meter movement on the junior? A forum member is looking for one for a jr, and I have one for the sr. This will be a difficult question.
Thanks, Frank
PostPosted: May Mon 28, 2012 2:28 pm
A quick check of the WV-77E Junior VoltOhmyst manual at BAMA shows it uses a 400 uA meter, RCA p/n 217925. A check of the WV-97A Senior VoltOhmyst manual from ebaman shows it uses a 200 uA meter, RCA p/n 59523.
PostPosted: May Mon 28, 2012 2:33 pm
On the other hand, a check of the WV-77C manual at ebaman shows it using a 200 uA meter, RCA p/n 213484. Does your Senior VoltOhmyst meter have any part number or indication of its sensistivity?
PostPosted: May Mon 28, 2012 7:40 pm
There is a piece of tape on it that says 250ua FS.
PostPosted: May Mon 28, 2012 10:25 pm
So it does! So I guess the question now is which model of WV-97 used a 250 uA meter movement? Just how many models of the WV-97 did RCA make? All I see on the web is WV-97A, but the manual for that says it's a 200 uA meter. Maybe the tape label is wrong?
PostPosted: May Mon 28, 2012 11:59 pm
That would be my guess, the person testing may not have had the proper equipment and/or ability to do so.
PostPosted: May Tue 29, 2012 2:07 am
Aside from the FS being different, the wv-77 meter and cabinet are considerably narrower than the later Sr., don't think it'll fit. If you're thinking about just putting the Sr's movement in the Jr's case, That would open up another barrel of snakes.
Users browsing this forum: Google Adsense [Bot] and 3 guests
