It is currently Jun Tue 18, 2013 7:19 am
 Post subject: Beware of the Philco 47-1230...
PostPosted: May Sun 27, 2012 2:56 pm
After a gazillion hours troubleshooting this radio, it has now taken the number one spot as the most unfiriendly radio in history for servicing. The "front-end" is buried beneath a rube goldberg bandswitch, which means the only way to access the tubes underneath is to remove the bandswitch. Which, once you have removed the bandswitch [ a large task], the front end is disabled. This is one to stay away from. I am sure it is a great performer if you are lucky to "get" one that does not have a problem in this area, but so far I am batting 100% [ 2 out of 2], which tells me the chances of getting a good one are not good. Perhaps I should get training in laproscopic proceedues using fiber optics and micro-tweezers. This radio is equivalent to the dreaded bandswitch area on a SX-42, if not worse. Just a warning, though I am sure many 47-1230 units have failed with "easy" problems like IF transformers, etc. that would make them simple to troubleshoot. Actually, I am puzzled as to how they did the original assembly and checkout - must have been a bear.
John O.
"Apolitical and staying that way"
 Post subject: Re: Beware of the Philco 47-1230...
PostPosted: May Mon 28, 2012 10:48 pm
So what is it doing? A weak 7F8 can make the radio intermittent...went through that on a 48-482 a while back.
You can get the full blown Philco Service Bulletin for free here (you will need to download a DjVu file viewer
http://www.audiophool.cjb.net/Philco.html
Post New Topic Post Reply  [ 2 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: mlj4833 and 4 guests
