Page 1 of 1
[ 16 posts ] |
| Author |
LDighera
Post subject: Help on MWTCo Wavemeter Restoration Posted: Apr Sun 15, 2012 4:05 pm |
Joined: Feb Sun 01, 2009 3:31 pm Posts: 10 Location: Southern California
I have recently acquired a Marconi Wireless Telegraph Co. wavemeter sold as circa 1912 (photos attached). My research has yielded absolutely nothing about this instrument. Jim Kreuzer says he has one like it on display in the Titanic diorama, and that they were made in both England and America, and that it is English circa 1912 - 1914. I've been told by an associate in GB that the little arrows scratched on the knob and panel are typical of WW-I wireless (began on 28 July 1914 and lasted until 11 November 1918). If correct, that might place it a little more recent than 1912. I am keen to find: * A photograph of the proper crystal detector (currently replaced with a Formo), so that I may fabricate an authentic replacement * The wavemeter's model number * Any other historic information about this type of wavemeter. Many thanks for any assistance you may be able to offer.
| Attachments: |
File comment: Marconi's WTCo 1912 wavemeter
Marconi's WTCo 1912 wavemeter batt compr 20_enh_P4123059.JPG [ 146.84 KiB | Viewed 696 times ]
Marconi's WTCo 1912 wavemeter switchr 20_enh_P4123057.JPG [ 159.6 KiB | Viewed 696 times ]
Marconi's WTCo 1912 wavemeter panelr 20_enh_P4123092.JPG [ 156.08 KiB | Viewed 696 times ]
Marconi's WTCo 1912 wavemeter plate 20_enh_P4123093.JPG [ 160.76 KiB | Viewed 696 times ]
Marconi's WTCo 1912 wavemeter open 20_enh_P4123083.JPG [ 150.71 KiB | Viewed 696 times ]
| Top |
Alan Douglas
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: Apr Sun 15, 2012 10:57 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23524 Location: Pocasset, Cape Cod, MA
Is that crystal supposed to be there at all? I have a couple of British wavemeters and they use lamps as indicators.
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: Apr Mon 16, 2012 2:36 am |
Thank you for your response Alan.  Without any historical information, it's difficult to know much about the original detector. I'm thinking glow lamps may be more appropriate for CW than spark transmissions, as an operator wouldn't be able to hear CW transmissions in headphones without a BFO or modulated carrier. There are some clues however. There is a hole in the panel partially visible under the detector stand (not the cup), so something else was likely mounted there at one time. A three-position tap switch is mounted on the right hand corner of the panel. The legend is: 'B', [nothing], and 'M'. My guess is, that the 'B' position connected the battery to the buzzer circuit, or if the original detector was Carborundum, it may have turned on the detector bias voltage. The unmarked position may have selected the panel mounted detector, or been the battery off position. And the 'M' position may have been for selecting a magnetic detector attached through one of the two pair of binding posts. The other pair of binding posts may have been for headphones. Without tracing the wiring, it's difficult to be sure.  Plodding forward with research today, I did learn a little more. I found a photograph of a similar 'Marconi's Wireless Telegraph Co. Wavemeter 1906-1916' (photos attached). It appears to have a Carborundum detector, but it doesn't look original. There are other significant differences too. I also found some of J. A. Fleming's early writings that may provide a little additional insight: Wireless Telegraphy for Marine Inter-Communication June 10, 1910 Wavemeter--A wavemeter is provided to enable the transmitting circuit to be correctly adjusted to the international waves of 300 and 600 metres. It consists of an inductance coil with a fixed number of turns connected to an adjustable condenser. Across the condenser is shunted a high resistance asymmetrical crystal in series with a double-head telephone. The condenser is adjusted until signals are loudest in the telephone. A table affixed to the lid of the wavemeter gives the wavelength corresponding to each condenser reading. The range of the standard apparatus is 200 to 800 metres. See also: Thermionic Tubes In Radio Telegraphy And Telephony; John Scott Taggart CHAPTER XII. VACUUM TUBE OSCILLATORS, WAVE-METERS, CAPACITY METERS. AND OTHER MEASURING INSTRUMENTS. Pages: 336 - 339 So the mystery continues.... Thanks again for any additional sagacious information you may be able to provide.
| Attachments: |
File comment: "Marconi's Wireless Telegraph Co. Ltd. London Wavemeter No. 59180"
Marconi's Wireless Telegraph Co. Ltd. London Wavemeter No. 59180.jpg [ 72.9 KiB | Viewed 678 times ]
Marconi's Wireless Telegraph Co. Ltd. London Wavemeter No. 59180 7.jpg [ 72.58 KiB | Viewed 678 times ]
Marconi's Wireless Telegraph Co. Ltd. London Wavemeter No. 59180 6.jpg [ 76.13 KiB | Viewed 678 times ]
Marconi's Wireless Telegraph Co. Ltd. London Wavemeter No. 59180 5.jpg [ 74.14 KiB | Viewed 678 times ]
Marconi's Wireless Telegraph Co. Ltd. London Wavemeter No. 59180 3.jpg [ 80.68 KiB | Viewed 678 times ]
Marconi's Wireless Telegraph Co. Ltd. London Wavemeter No. 59180 2.jpg [ 68.38 KiB | Viewed 678 times ]
| Top |
Alan Douglas
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: Apr Mon 16, 2012 4:54 pm |
This extract from Rupert Stanley's 1914 Text Book on Wireless Telegraphy" may be relevant. Attachment:
Edit: I hadn't noticed that the illustration was of a Telefunken model or I'd have edited it out.
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: Apr Tue 17, 2012 4:52 am |
Anan, thank you very much for your insightful and most relevant input. And thank you also for referencing Text Book On Wireless Telegraphy, By Rupert Stanley. Lot's of interesting information in that august tome. Given the crystal detector in the photograph of Wavemeter No. 59180 above (not mine), with the two vertical clips, and also the instructions on my wavemeter's card (attached), it would seem that the Carborundum crystal detector mentioned in the text you kindly provided operates un-biased, and may indeed be the original design. I hadn't expected that at all. I was expecting something turned from brass. It's certainly easy enough to fabricate that sort of crystal holder from sheet steel, or more likely stainless. (Incidentally, Wavemeter No. 59180 is rumored to be one used by professor Robert Jack who broadcast New Zealand's first radio program November 17, 1921.) However, with a serial number 10,385 higher than mine, and it's arcane added roller-switch, the detector of Wavemeter No. 59180 may not be exactly representative of the original one fitted presumably at Marconi's New Street works on my wavemeter. And there are still the issues of date of manufacture and model number. So, while the mystery continues, I believe our collaboration is beginning to make some progress toward solving it. Thank you again for your most welcome and kind help.
| Attachments: |
File comment: Marconi's WTCo 1912 wavemeter card
Marconi's WTCo 1912 wavemeter card 20_enh_P4123070.JPG [ 219.87 KiB | Viewed 644 times ]
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: Apr Wed 25, 2012 9:10 pm |
| Top |
w0eom
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Thu 24, 2012 11:56 pm |
I once had a large wavemeter collection which included one like that shown with the earphones on the left. The two clips, which held a piece of carborundum were typical. The mineral and holder shown in one wm between the clips is from a WW 1 marconi military set. i would just copy the clips.
will Jensby
| Top |
majoco
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Fri 25, 2012 2:11 am |
| Member |
Joined: Mar Mon 17, 2008 5:05 am Posts: 3277 Location: Palmerston North, New Zealand
The little arrows engraved on the panel and the knob used to mean that the item was originally used by the Government.
_________________ Cheers - Marty ZL2MC
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Fri 25, 2012 3:36 pm |
Thank you for the information, Will.
I had reached the same conclusion that you did about the two-vertical-steel-strip type of crystal detector mount. And then on closer examination, I found two pair of original mounting holes in the panel where each end of the original crystal holder had been originally fitted. (I made a very rough sketch of the original mounting hole pattern above.) It's pretty clear that each leg of the two-vertical-steel-strip type of crystal detector attached to the panel with but a single screw. So at this point I'm at a loss to find any examples of MWTCo wavemeter crystal mounts from this era that used a total of four screws to attach to the panel.
If historical accuracy is important in restoring this example of one of the first pieces of electronic apparatus ever made, then I think I owe it further research.
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Fri 25, 2012 4:43 pm |
majoco wrote: The little arrows engraved on the panel and the knob used to mean that the item was originally used by the Government. Thank you for helping to clarify that. I received a response on the Antique Wireless Association mailing list from Bill Burns who kindly provided this link: http://en.wikipedia.org/wiki/Broad_arrow#Use_for_British_Government_property. Here's what it says: Quote: The Board of Ordnance in 1597, its principal duties being to supply guns, ammunition, stores and equipment to the King's Navy, used the broad arrow to signify at first objects purchased from the monarch's money and later to indicate government property since at least the 17th century. The broad arrow frequently appeared on military boxes and equipment ... With the demise of the Board in 1855, the War Department and today's Ministry of Defense continued to use the mark. So it would appear that the broad arrow marks are not indicative of the age of this piece.
| Top |
K7KSW
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Fri 25, 2012 11:18 pm |
Joined: May Fri 25, 2012 7:54 pm Posts: 3 Location: Northern California
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Wed 30, 2012 5:08 pm |
Larry, thank you for the information and insight you have kindly provided. Very much appreciated. Your Marconi Wireless Telegraph Co of America wavemeter is in remarkably fine condition. You are fortunate indeed to posess such a remarkably preserved museum quality piece. There are several other MWTCo wavemeters shown in the Marconi 1996 Centenary catalog reproduction. There is also an instruction leaflet (French) for a 1906 MWTCo wavemeter on the Museum of the History of Science, Oxford web site. You can search their vast collection with large images too. The photograph of the wavemeter you provided with the 2-1/4" spaced holes is similar to the one in the photographs I'll attach to this message. At least the holes are similarly spaced. I've been thinking some more about the four detector holder mounting holes issue. And, given the design of the two vertical strip crystal holder, it is entirely possible that the additional holes may have been provided for adjustment purposes to accommodate larger or smaller chunks of galena or Carborundum. (I presume Carborundum was originally used, as it would seem that a cat's whisker might be required for galena.) Now with the information you provided about the strips being made or brass and possibly nickel plated, I may be able to fabricate a replica crystal holder. Without wanting to impose, it would be good to know the dimensions and thickness of the strips. I'll have to agree with you about never seeing two identical early Marconi wavemeters. Curious.
| Attachments: |
File comment: Marconi Condenser
| Top |
Alan Douglas
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Wed 30, 2012 5:22 pm |
Marconi I'm pretty sure never used galena, and I believe always used adjustable bias with carborundum. I'm out of range of reference material here at work, but cerusite rings a bell as Marconi's favored detector when bias wasn't available.
Of course owners could use whatever they liked, and Marconi ship operators could carry their own pet minerals with them, for use as soon as they were out of sight of supervisors.
| Top |
K7KSW
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: May Thu 31, 2012 11:19 pm |
Larry, Thank you for the link to the early Marconi catalog -- I was not aware of that. I see that on page 44 is a description of carborundum crystals where it says for wavemeters there are "picked crystals" not in cups. As wavemeters are used in close proximity to transmitters being tested, high sensitivity is not needed so biasing the carborundum seems unnecessary. I was aware of the MHS Oxford website and have visited there many times.
The wavemeter you show with the widely spaced holes has a detector on the other side so those holes must be for something else. However, on my wavemeter with those widely spaced holes, there is no other place for a detector. Since Marconi made so many wavemeter variations I have wondered if they ever made ones without a detector but only having a buzzer for use in checking receivers. For the early Marconi stations the TX and RX locations were spaced 10-20 miles apart, e.g Bolinas and Marshalls, CA (where many original buildings are still standing). So it may not be be completely unreasonable to have a dedicated wavemeter at the RX site.
Dimensions of the brass detector clips on my other wavemeter are: 0.020" thick, 0.460" wide, 1.12" high, base 0.40" long. The 45 degree bevel at the top is 0.13" along the bevel. I'm glad to provide this info.
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration Posted: Jun Sun 03, 2012 7:39 pm |
Alan Douglas wrote: Marconi I'm pretty sure never used galena, and I believe always used adjustable bias with carborundum. I'm out of range of reference material here at work, but cerusite rings a bell as Marconi's favored detector when bias wasn't available. Of course owners could use whatever they liked, and Marconi ship operators could carry their own pet minerals with them, for use as soon as they were out of sight of supervisors. Thank you for that interesting bit of information, Alan. The desire to use galena, which requires a cat's whisker, as a detector by the owner of this wavemeter does indeed appear to have motivated the detector modification. That, coupled with the information you provided about Marconi and cerusite, almost ligitmizes the historic modification as evidence of rebellion against Marconi dogma.  It appears that Marconi didn't use galena in his detectors, preferring carborundum and cerusite instead, the latter not requiring a bias voltage. <http://books.google.com/books?id=kyUyAQAAMAAJ&vq=cerusite&dq=cerusite%20marconi&pg=RA2-PA55#v=snippet&q=cerusite&f=false> So, it would appear that the previous owner of the wavemeter sought to work around Marconi's galena prohibition, perhaps sometime in the 1920s, by fitting the Formo galena detector. It just amazes me how so much can be accomplished by a knowledgeable and sincere community of like-minded "brother's of the spark" so to speak. Thank you very much for your help. Further research: http://books.google.com/books?id=PkTOAA ... ni&f=falsehttp://books.google.com/books?id=Ck9IGg ... ni&f=falsehttp://books.google.com/books?id=kyUyAQ ... ni&f=falsehttp://books.google.com/books?id=qv1B0W ... ni&f=falsehttp://www.ebooksread.com/authors-eng/e ... -hci.shtmlhttp://www.ebooksread.com/authors-eng/r ... -hci.shtmlhttp://books.google.com/books?id=IMUUAA ... ni&f=falsehttp://dictionary.reference.com/browse/cerusitehttp://franklin-sterlinghill.com/palache/cerusite.stm Cerusite forms clear white or gray crystals encrusting galena. It was found as a scarce alteration product of galena at Sterling Hill. The measured crystals, collected there in 1905, are prismatic parallel to the brachyaxis (figure 63), with a richly developed zone of brachydomes. Others are twinned in the ordinary cerusite habits. http://dictionary.reference.com/browse/galena
| Top |
LDighera
Post subject: Re: Help on MWTCo Wavemeter Restoration: MYSTERY SOLVED! Posted: Jun Sun 03, 2012 7:50 pm |
Mike Feher has kindly provided photographs of his wavemeter's detector (Mike owns the Professor Jack wavemeter mentioned above), and this explanation of the four holes used to mount the two-vertical-strip crystal holder: Quote: "I took mine apart to see if it had one hole or two and, indeed it does have two for each side of the strip. One is to thread the crystal support arm into, and, the other is to solder to a tab coming from the arm. I took a few pictures which are attached." So, one panel mounting hole was used to attache the vertical strip to the panel, and the other to permit a tab on the foot of the vertical strip to penetrate the panel, so that a connecting wire might be soldered to it. Brilliant! Mystery Solved! It's not evident at all from observing the crystal mounting strips from the top that they have a solder tab that penetrates the panel. Presumably ADDITIONAL QUESTIONS: In my ceaseless quest for ever more information about this wavemeter, I have asked these additional questions of Mike Feher: 1. Does your wave meter have what appear to be galvanized steel battery holder straps attached to the bottom board? Mine has two (with associated end-stops/contacts at each battery position?), one rounded hoop that appears that it was intended for a single cell with its longitudinal axis parallel with the front, and another wider strap that looks like it may have held a battery of 4 cells in place with their longitudinal axes perpendicular to the front. (Photographs attached) It's also possible that the single hoop may have held one of those turned-wooden "bottles" that contained spare crystals, as the contents of that hoop would have been accessible through the buzzer door. The curious thing is, that there don't appear to be any wired battery contacts associated with these hoops or anywhere else for that matter. [Three photographs below] 2. Can you sketch a schematic of the circuit? Mine has been modified, and it would be good to know how it may have been originally wired. Does the three position switch with the 'M' and 'B' markings apply a bias voltage to the crystal when placed in the 'M' position. I presume the 'B' position energizes the buzzer.
| Attachments: |
File comment: Dighera wavemeter battery? holders
Marconi's WTCo 1912 wavemeter batt compr_enh_800_P1010121.gif [ 156.86 KiB | Viewed 408 times ]
Marconi's WTCo 1912 wavemeter batt compr_enh_800_P1010120.gif [ 219.22 KiB | Viewed 408 times ]
Marconi's WTCo 1912 wavemeter batt compr_enh_800_P1010116.gif [ 190.46 KiB | Viewed 408 times ]
File comment: Feher/Jack wavemeter crystal mount under panel detail
File comment: Feher/Jack wavemeter crystal mount panel top detail
| Top |
Users browsing this forum: No registered users and 5 guests |
