| Author |
wazz
Post subject: Nother tube Q: Why perforated plates? Posted: Jun Sat 02, 2012 11:57 pm |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2056 Location: Ohio
OK someone has to know, this has been puzzling me for a couple of days. I have seen several types of tubes, from ancient 30's types to subminis, with perforations in the plates. Regular rows of tiny holes all over, like a sieve. Or mom's strainer. What is the idea behind this oddity of construction?
| Top |
Jack Shirley
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 12:11 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8406 Location: SE USA
Improves air flow through the plate
_________________ The beatings will continue until the morale improves
| Top |
swanson
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 12:43 am |
The perforated plate that you see in tubes like the EF86,EBF89,or EF184 is actually a shield and not the plate.Don't know about the old 1930's tubes though. Regards, Swanson
| Top |
Alan Douglas
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 1:14 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23519 Location: Pocasset, Cape Cod, MA
The old ones (1930 or so) had wire cloth ("mesh") plates for better cooling of the grid. There was a Newark company making the stuff that advertised a lot, but it didn't do much, and tube makers learned how to coat grids to improve heat radiation, so the wire cloth fell out of use pretty quickly. It lasted longer on triodes with closely-spaced elements like the 27.
Audiophools go nuts over "mesh plates" since everyone knows that tubes that look different sound better.
| Top |
wazz
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 2:39 am |
| Member |
I was looking at a couple 6EJ7 types and you may be right, it may be a shield. As for the #34 tube in this old radio I got today. I cannot really tell for sure if it is a shield or a part of the anode. If it is a seperate internal element I would hope the diagram base drawing might show it as such to avoid confusion. Thanks for the info.
| Top |
Peter Bertini
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 2:58 am |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12208 Location: Somers, CT
Alan Douglas wrote: Audiophools go nuts over "mesh plates" since everyone knows that tubes that look different sound better. Everyone knows this. The tube sound is obviously more transparent.
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
threeneurons
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 3:26 am |
| Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 1784 Location: Los Angeles
Peter Bertini wrote: Alan Douglas wrote: Audiophools go nuts over "mesh plates"... Everyone knows this. The tube sound is obviously more transparent. That's because the mesh is more delicate at catching the electrons, so the sound is softer. Not like a solid plate, were the electrons are collected abruptly, giving a harsher sound ... duh ! How well do you think that will go over at a high end stereo forum ?
_________________ If the women don't find you handsome, they should at least find you handy ! - Red Green
| Top |
mescalero
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 3:59 am |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2801 Location: Dallas, TX - in the city but with bobcats and coyotes
That's music to my ears! Actually, black solid plates tend to ping when electrons strike. Grey plates just thud. Mesh plates can actually avoid the majority of electron strikes and thus you get less noise in the signal.
_________________ In a triode, no one can hear you screen.
| Top |
wazz
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 1:47 pm |
| Member |
They should have put a phosphor coating on the inside of the glass so you could see a neat little pattern of glowing dots where the lost electrons leak thru the holes. Fluxing with loud signals. I guess you will have to settle for an eye tube to get that excitement.
| Top |
Braithwaite
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 2:53 pm |
Joined: Nov Sun 04, 2007 6:01 am Posts: 1050 Location: Redding, CA
wazz wrote: They should have put a phosphor coating on the inside of the glass so you could see a neat little pattern of glowing dots where the lost electrons leak thru the holes. Fluxing with loud signals. I guess you will have to settle for an eye tube to get that excitement. Now that is a potentially cool idea for an audio application! The glow from the phosphor would be modulated by the grid as well as "screened" by the plate. The tube would visually throb with the music! If a manufacturer wanted to expand on this idea a bit, they could make the perforations in the plate interesting shapes such as musical notes. And in dual triodes having the sections operating on opposite channels, the glowing musical notes on the tube would throb to the sound of two audio channels! I wonder if the current manufacturers of tubes in Asia and Russia pick up on this thread. Norman
| Top |
wa8dof
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 4:47 pm |
| Member |
Joined: Dec Tue 28, 2010 6:28 pm Posts: 191 Location: Marquette MI
Guess I am just stupid, but I do not understand how holes can improve the airflow through the plate when there is not supposed to be any air in the tube to begin with.
Could someone enlighten me please?
_________________ WA8DOF@YAHOO.COM
| Top |
mescalero
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Sun 03, 2012 5:03 pm |
wa8dof wrote: Guess I am just stupid, but I do not understand how holes can improve the airflow through the plate when there is not supposed to be any air in the tube to begin with.
Dave Actually, you are not stupid at all. Quite the contrary. We've just been playing silly now that the real answer was given.
| Top |
markjd
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 1:22 am |
| Member |
Joined: Mar Tue 02, 2010 6:53 pm Posts: 297 Location: Virginia
Don't know if it corresponds to vacuum tubes, but in high-vacuum equipment (mass spectrometers, etc.) perforations improve how well the chamber pumps down.
| Top |
Burnt Fingers
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 3:08 am |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
Quote: Guess I am just stupid, but I do not understand how holes can improve the airflow through the plate when there is not supposed to be any air in the tube to begin with.
Dave Just put the anode cooler on the outside and blow a lot of air thru it. Carl
| Top |
BigBandsMan
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 3:25 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6032 Location: Raleigh NC USA
mescalero wrote: wa8dof wrote: Guess I am just stupid, but I do not understand how holes can improve the airflow through the plate when there is not supposed to be any air in the tube to begin with.
Dave Actually, you are not stupid at all. Quite the contrary. We've just been playing silly now that the real answer was given. +1 On the other hand, it's tragic that so many people actually BELIEVE such hogwash. If there can be an index for techno-illiteracy, that might be it. Some of these knotheads remind me of children playing with hand grenades. A wonder they haven't electrocuted themselves (or have they? I don't see all the news).  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
Jack Shirley
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 3:42 am |
| Member |
Maybe "air flow" was the wrong term. The infrared particles (heat) are swirling inside the tube. If you have an Android camera phone you can actually see the infrared components when viewing through the camera mode.
| Top |
codefox
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 7:20 am |
No, it was air conditioning, invented by IcedT. Never did figure out wh metal tubes didn't need glass bulbs.
| Top |
Alan Douglas
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 11:48 am |
Quote: A wonder they haven't electrocuted themselves (or have they? Unfortunately no. Remins me of the joke about the busload of lawyers going off a cliff. The tragedy was that it wasn't full.
| Top |
BigBandsMan
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 12:10 pm |
| Member |
L
| Top |
mescalero
Post subject: Re: Nother tube Q: Why perforated plates? Posted: Jun Mon 04, 2012 1:09 pm |
| Top |
Who is online |
Users browsing this forum: No registered users and 3 guests |
