Page 1 of 1
[ 13 posts ] |
| Author |
jamr005
Post subject: My Scott is popping corn Posted: Jun Wed 06, 2012 3:39 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 509 Location: Bloomington, IL USA
Just powered up my Phantom 19. It works great on AM across the entire band. And it works great on the 2 higher short wave bands, at least on the top half of the scale on each band.....but when I tune down below about half way on these SW bands I hear a popping sound that sounds like popcorn popping.
I bought it in recapped status but the replaced electrolytic caps in the power supply look old.
Any ideas?
Joe
| Top |
pred
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 3:54 am |
Joined: Jan Sun 24, 2010 10:52 pm Posts: 3780 Location: Phila Pa
Maybe there is dust in between the plates of the SW tuning caps?
| Top |
jamr005
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 4:00 am |
But AM uses the same tuning cap as SW bands and it works fine on AM?
| Top |
Nick D.
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 6:13 am |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6734 Location: "Amish Country", PA
What does it sound like in terms of speed/frequency?
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
oldmusicman
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 11:12 am |
| Member |
Joined: Jul Sun 31, 2011 6:19 pm Posts: 1787 Location: Kitchener Ontario Canada (left UK 2007)
You sure its not more like a motorboat sound ?
_________________ Zenith "The Quality Goes In Before The Name Goes On"
| Top |
Dennis Banker
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 1:06 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 718 Location: St. Louis, MO, USA
Actually, that's what they called it back in the day-"motorboating". It's a kind of feedback. It can be a low tone or put-put sound or a higher pitched whistle. It might be caused by poor filter capacitors, lack of tube shirlds, wiring that had been moved around. etc.
-Dennis
| Top |
Tube Radio
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 2:29 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7886 Location: Warner Robins, GA
Check all the previous work that was done and make sure none of tha parts used are those prone to failure.
| Top |
codefox
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 6:09 pm |
Shut it down. You probably have an arcing capacitor, less likely a defective tube.
| Top |
easyrider8
Post subject: Re: My Scott is popping corn Posted: Jun Wed 06, 2012 10:09 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6768 Location: Minnesota
This is usually caused by a bad filter electrolytic, you can jump them with a good one to check.
| Top |
aropper
Post subject: Re: My Scott is popping corn Posted: Jun Fri 08, 2012 6:34 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 576 Location: Massachussetts
What about single loud intermittent pops? I have this with my Scott 15 and cannot locate the source. At one time, I thought it was from a dirty tube pin but cleaning pins and sockets does not fix it.
| Top |
oldmusicman
Post subject: Re: My Scott is popping corn Posted: Jun Fri 08, 2012 6:45 pm |
| Member |
I used to get that on my Electrohome 6v6 amp, when i recapped it i didnt get the components in exactly the right spot, i had to go over it and move some wires around and i also covered some leads in heatshrink tubing, hasnt done it since. The motorboating sound tends to get faster if you increase the voloume, if this is the noise hes getting then its interference, he needs to go back and check all his leads and make sure they run properly. Im still learning myself but ive learnt lots from these guys, mind of information.
| Top |
Tube Radio
Post subject: Re: My Scott is popping corn Posted: Jun Fri 08, 2012 7:28 pm |
| Member |
Your Scott is popping corn? Where's the salt and melted butter
| Top |
Marcc
Post subject: Re: My Scott is popping corn Posted: Jun Fri 08, 2012 11:38 pm |
| Moderator |
Joined: Feb Sun 01, 2009 2:56 pm Posts: 3681 Location: Victoria, Australia
It may be an idea to give us a look at the caps that are currently in it. Why I say that is that I have recapped a few sets that have been done before, but in the era when paper was replaced by paper.
If it's only happening at the higher frequencies It has to be some thing common to them. Oscillator tubes normally fail at high frequency. This can also be (and often is) related to them switching in faulty components, or running low on voltage due to high resistors. Also check the tube shields, where fitted (or missing).
As said the "Putt Putt" is motorboating, which is feed back or other forms of destabilisation. "Snap Crackle & Pop" are more likely (when not back in their box) the realm of switches & Mica caps (often the ones with B+ on them).
Lead dress cannot be overlooked since it has been worked on.
Marc
| Top |
Users browsing this forum: AMChief, Google [Bot] and 4 guests |
