Page 1 of 1
[ 11 posts ] |
| Author |
Peter Bertini
Post subject: Tektronix 2235A triggering issues Posted: Jun Sun 10, 2012 11:19 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12238 Location: Somers, CT
I just noted that my old 465 scope is running circles around my 2235A for internal triggering stability. I never liked that new plastic POS compared to my old reliable 465. Are there any common issues with the 2235A triggering circuit: parts that fail or alignment, that might be applicable here? It will sync up, but it is very touchy and not stable. The 465 locks in like a rock. Pretty sure all the controls are set up correctly, double checked that first  Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
Peter Bertini
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Tue 12, 2012 2:37 am |
| Moderator |
Where did all the Tek scope guys go?? I reseated some of the cable connectors and that seems to have corrected a lot of the problems. I still feel the 465 has a better triggered sweep, and that bothers me.
Pete
| Top |
Mikeinkcmo
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Tue 12, 2012 5:35 am |
I never used a 2235, so I can't compare the two, but the 465/75 triggers were, I thought, pretty good. The Trigger Specs for the two models are very similar. Are you talking about a significant measurable difference or more nuance? Funny, even in the "newer" equipment its still the mechanical stuff still causes problems.
If you want experts, The Tek Yahoo board, as you know, is the place to go.
| Top |
Peter Bertini
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Tue 12, 2012 2:20 pm |
| Moderator |
I was trying to lock onto a modulation waveform from a signal generator. It was extremely difficult to get the scope to lock on the pattern. It would sweep, but not lock and when I could get it to lock the pattern had a lot of jitter. The 465 locked right up and the triggering was rock solid over a wide range. Right now it seems to working as it should. And it figures that this is the only item on the bench that I don't have the service manuals for!!
We had a few Tek guys on here, but they've noticeably absent.
Pete
| Top |
mescalero
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Tue 12, 2012 5:02 pm |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2809 Location: Dallas, TX - in the city but with bobcats and coyotes
Is "HF reject" available on the trigger qualifier?
_________________ In a triode, no one can hear you screen.
| Top |
Peter Bertini
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Tue 12, 2012 5:16 pm |
| Moderator |
HF and LF Reject. None of which did much when it was acting up.
| Top |
Mikeinkcmo
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Wed 13, 2012 4:35 am |
A little clarification on my earlier post.
When I said "the two models" I was referring to 465/75, and, the 2235.
FWIW, The Ops manual is on BAMA and includes the specs sheet.
| Top |
tinwhisker
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Thu 14, 2012 5:27 am |
Joined: Feb Sun 17, 2008 11:36 pm Posts: 1336 Location: Dayton, Ohio
Try triggering the scope externally off of the modulation signal. (400 Hz?)
Charlie
| Top |
Peter Bertini
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Thu 14, 2012 4:14 pm |
| Moderator |
tinwhisker wrote: Try triggering the scope externally off of the modulation signal. (400 Hz?)
Charlie Fixed for now, but that was the next step. Without the manual or a flow chart it is kind of hard to do component level repairs--but I see vendors selling complete boards pretty cheaply. Pete
| Top |
dholland
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Fri 15, 2012 1:36 am |
Joined: Mar Thu 12, 2009 2:20 am Posts: 795 Location: Dayton, OH
I dunno if it helps much...
I've a 2246, AFAICT, roughly the same generation of 'scope, but I don't know how much is similar between the two.
I didn't have much problem getting a stable display feeding an 1.2Mhz signal AM modulated at 400 Hz & 1Khz from the 8640b straight through (terminated) to the scope.
Little more difficult when I 100% modulated the signal, but still not difficult.
The Holdoff control was more useful than the Trigger level getting it at 100% modulation.
<shrug> Like I said, don't know if its much help.
If you want to chase down a service manual, Dave over at ArtekMedia looked to have a scan available, I've had good dealings with him.
David
| Top |
tinwhisker
Post subject: Re: Tektronix 2235A triggering issues Posted: Jun Fri 15, 2012 4:40 am |
The scope TRIG LEVEL control doesn't really know if the R.F. carrier is modulated or not. To "freeze" the modulated carrier, to display a stationary modulated display, trigger off of the modulating signal.
Charlie
| Top |
Page 1 of 1
[ 11 posts ] |
