It is currently Jun Tue 18, 2013 10:51 pm
 Post subject: White vinegar
PostPosted: Jun Fri 15, 2012 7:04 pm
I was wondering if white vinegar has any uses for a radio restorer? I was thinking along the lines of maybe using it as a degreaser, or used on sticky pushbutton assemblies?
 Post subject: Re: White vinegar
PostPosted: Jun Fri 15, 2012 7:27 pm
I am more inclined to use tetrachloroethylene based cleaners for those applications - Just keep it off anything plastic. But nothing beats white vinegar for something an alkaline battery has leaked on. It is a good cleaner wherever a slightly acid cleaner is indicated. I do always neutralize with a baking soda solution afterwards.
Ron Mc/
PostPosted: Jun Sat 16, 2012 2:58 am
I don't use it in electronics work, but I do have several decorator lamps that use tap water and small pumps. They need periodic maintenance, and white vinegar works well in removing the mineral deposits left behind by the tap water.
PostPosted: Jun Sat 16, 2012 6:50 am
White Vinegar and hot water = best glass cleaner.
PostPosted: Jun Sat 16, 2012 7:04 am
http://www.versatilevinegar.org/usesandtips.html
PostPosted: Jun Sun 17, 2012 2:27 am
+1.
L
PostPosted: Jun Mon 18, 2012 4:21 am
*hot DISTILLED water :wink:
PostPosted: Jun Mon 18, 2012 10:23 pm
This radio restorer puts it on his french fries......
.....Dennis.....
Live Long and Prosper
PostPosted: Jun Wed 20, 2012 12:47 am
What's the problem with red wine vinegar? Or balsamic? 1/2 :)
Dave Wise
PostPosted: Jun Wed 20, 2012 3:58 am
Ok, please get back on topic people.
Chuck Schwark,
The Philco Repair Bench
Schematic Photocopy Service
www.philcorepairbench.com
PostPosted: Jun Wed 20, 2012 7:11 pm
I've heard of a mixture of white vinegar,turpentine and Linseed oil makes a superb wooden radio cabinet cleaner.I just forgot the portions. Any help?
John.
PostPosted: Jun Wed 20, 2012 8:25 pm
John.
Homemade Furniture Cleaner and Polish
Mix equal parts linseed oil, white vinegar and turpentine in a glass or metal container.
Stir well to blend the ingredients with a wood stirrer.
Dip a soft cloth lightly into the polish. Rub the polish onto the furniture. Allow the polish to remain on the surface for two to three minutes.
Rub the excess polish off the furniture with a new soft, lint-free cloth.
Read more: How to Clean Furniture With Linseed Oil | eHow.com http://www.ehow.com/how_7731310_clean-f ... z1yMZxYqzA
PostPosted: Jun Wed 20, 2012 10:41 pm
Chuck, I asked in a jokey voice, but I really do seriously hope for an answer. Does it have to be white? If so, what's wrong with the other kinds? That seems perfectly on-topic for a "White Vinegar" thread.
Dave Wise
As a matter of fact, I have used balsamic vinegar to neutralize alkaline battery leakage, in my GR 1650-A Impedance Bridge. It worked very well. It was just what I had on hand at the time, and I haven't detected any ill effects due to its not being white.
PostPosted: Jun Thu 21, 2012 3:07 am
Dave,
White vinegar is "pure," without coloring or malted grains that add color to it. Some vinegars have other things.
Read label to be sure.
Wasn't jumping on you, just "nudging" the thread a little. :)
Chuck
Chuck Schwark,
PostPosted: Jun Thu 21, 2012 6:42 pm
I see. Since I rinsed the area thoroughly in water afterward, I don't expect any problems from those tasty adulterants.
But if I'd had white on hand, I'd've used it.
PostPosted: Jun Fri 22, 2012 2:23 am
You should be just fine then Dave.
C2H4O2
Chuck Schwark,
PostPosted: Jun Fri 22, 2012 7:08 pm
Yep - apply C2H4O2 to the workpiece, then C2H5OH to the technician. :)
Dave Wise
How did you get the suffixes to display right?
PostPosted: Jun Fri 22, 2012 8:26 pm
With font size and bold.
My favorite mix of atoms: C2H5OH
with dissolved phenols and wood resins......taken medicinally, of course.
8)
And now I have drifted off topic! Returning to the Vinegar topic now.....
:lol:
Chuck Schwark,
PostPosted: Jun Sat 23, 2012 8:21 pm
There was a thrad somewhere where someone immersed a nasty variable capacitor in White Vinegar and let it sit overnight. Rinse , dry, relube. Beautiful. I'n going to try this next time I get a grimy one.
PostPosted: Jun Sat 23, 2012 9:31 pm
Just don't use Coca Cola instead; it may dissolve it. :wink:
Post New Topic Post Reply  [ 21 posts ]  Moderator: Chuck Schwark Go to page 1, 2  Next
