Page 1 of 1
[ 9 posts ] |
| Author |
superzeeman
Post subject: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 5:19 am |
| Member |
Joined: May Sun 13, 2012 2:30 pm Posts: 277 Location: Mapleton, Mn
| Top |
gary rabbitt
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 6:04 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13103 Location: Tennessee,USA
I cain't see it, I just cain't! Like to see photos of the clean set. You will need to either build a battery setup or a power supply. Guys have used a series of 9v batteries for the HV, and D cells for the filaments. http://www.antiqueradios.com/forums/vie ... 6&t=186610
_________________ Gary Rabbitt
| Top |
superzeeman
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 1:38 pm |
| Member |
Here are some pics Gary. All I had to do was polish with Meguiers Plastx and it shines like a new radio.
_________________ It's a dog eat dog world and I'm wearing Milk Bone underwear.
| Top |
lagert
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 1:57 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1168 Location: Jim Thorpe, Pa., USA
| Top |
wazz
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 2:37 pm |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2062 Location: Ohio
Does anyone actually use them with the vibrator and a battery? I have a set that I need to get working, but it has room inside for a fairly good sized 6V gel cell or the like, and those are easy enough to charge up. If it is a set you do not use constantly, that seems reasonable. Mine does not work but I can hear the vibrator humming. Not that loud or noticeable. I figured I might try using it with either a 6V power pack that can put out a few Amps or the battery, to keep it original versus going to the expense of some conversion. Anyone?
| Top |
Usually Lurking
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 5:29 pm |
Joined: Jan Tue 16, 2007 7:02 am Posts: 630 Location: Lexington, KY USA
This set appears to be a 1.5V / 90V dry battery set. No vibrator.
I think if I had a vibrator "farm" set, I would keep it original, and run it off 6VDC. The vibrator hum is part of the fun. Might even be worth getting a repro Model A battery to sit on the floor. Add a vintage charger with a Tungar bulb, and I'd be all set.
Ted
| Top |
wazz
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 8:30 pm |
| Member |
This set has a cloth wire cord terminated with two big battery clips. The vibrator is just audible next to the radio but would be drowned out easily if you turned up to a normal volume. There is enough room next to the chassis behind the speaker to hide a decent sized gel battery and that is what I wanted to pursue. So I could have a AM/SW radio that is nuke and power loss resistant! And looks neat.
| Top |
Usually Lurking
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 10:57 pm |
wazz, > Post subject: Re: Zenith 4K422 Farm Set > This set has a cloth wire cord terminated with two big battery clips. Are you sure? NA schematic for 4K422 shows four battery tubes, no vibrator, no big battery clips: http://www.nostalgiaair.org/Resources/download.asp?FN=\M0024861.pdf Wouldn't be first time NA got things scrambled. Ted
| Top |
radiopicker
Post subject: Re: Zenith 4K422 Farm Set Posted: Jun Fri 22, 2012 11:42 pm |
| Member |
Joined: Aug Thu 18, 2011 4:48 am Posts: 2506 Location: Stamford, NY
That's BEAU-T-FUL!!!!!!! Nice find.
_________________ Vincent
| Top |
Who is online |
Users browsing this forum: arbilab and 7 guests |
