It is currently May Sun 26, 2013 10:14 am
 Post subject: Tuning noise
PostPosted: Jun Sat 30, 2012 3:36 am
I just recapped a radio and it plays very well and tunes very nice until I hit the 1500kc area and it "scratches" a bit then you can move on to the end of the range. it does not happen anywhere else on the dial, just there. Im thinking a bent plate?
It's a dog eat dog world and I'm wearing Milk Bone underwear.
 Post subject: Re: Tuning noise
PostPosted: Jun Sat 30, 2012 3:41 am
Could be. Have you examined the condenser plates?
If you can't tell by eye... you can turn off the radio and connect a DMM across the tuning condenser and set it for a continuity-beep.
Then slowly tune the plates and see IF AND where it is when it beeps. Then you can gently separate the plates till the beeping stops.
PostPosted: Jun Sat 30, 2012 3:53 am
Not to sound like a newbie, but I am, what is a DMM?
PostPosted: Jun Sat 30, 2012 4:01 am
Any kind of an ohmmeter.
PostPosted: Jun Sat 30, 2012 4:03 am
Ok, gotcha. I just broke mine, so I need to go get one anyway,
PostPosted: Jun Sat 30, 2012 4:18 am
How did you break it? It may be repairable.
The beatings will continue until the morale improves
PostPosted: Jun Sat 30, 2012 4:35 am
DMM means Digital Multi-Meter
PostPosted: Jun Sat 30, 2012 5:49 am
Maybe a bent plate, maybe some conductive crud in the plates, maybe some intermittent connection with the "fingers" that connect the shaft of the tuning cap electrically.
Brett
PostPosted: Jun Sat 30, 2012 5:59 pm
You can find out which plate is scraping with a piece of paper. If it binds, that's the one. Ususally on one end of the stack.
PostPosted: Jun Sat 30, 2012 6:35 pm
Great Tip with the paper!
Post New Topic Post Reply  [ 10 posts ]  Moderators: Marcc, Norm Leal
