It is currently Jun Thu 20, 2013 1:42 pm
 Post subject: Turntable concrete plinth
PostPosted: Jul Mon 02, 2012 8:23 pm
Hi All,
A while ago I was looking for a better Dual turntable for a console. Thanks to another ARF member I ended up with a nice Dual 1009. Just after I bought it but before it arrived in the mail. A Dual 1019 I was really looking for became available closer to home. So I had to get that one too.
So now what to do with a Dual without a plinth? I am not a good wood worker so I decided to make a concrete plinth.
Here are some pictures of the process. It turned out quite nice. I used the cutout in the wooden console as a template and made some adjustments as making holes in concrete is difficult. In future I would make the centre form out of smaller pieces butted together and screwed to make removal easier. Total cost: $6 for a bag of concrete, scrap 3/4" plywood and a few hours of labour.
When I poured the concrete it was 32C outside so I covered it with plastic to stop it drying out to fast. Should have waited until it had set a bit more. That caused a bit of unevenness in the base. It will sit on a small piece of recessed wood so the unevenness is not too critical, as it will be levelled using adjustable legs. (still have to get those)
Here it is.
 Post subject: Re: Turntable concrete plinth
PostPosted: Jul Tue 03, 2012 4:10 am
Sorry, but, it looks like a Dual on a brick... ugly.
Overkill too.
I never saw a heavy-assed Dual in need of such "support".
Audiophools stuff. :roll:
PostPosted: Jul Tue 03, 2012 9:44 am
Overkill too.
Yep, not everyones cup of tea but I like it. Thats all that matters! :D
PostPosted: Jul Tue 03, 2012 11:37 am
That puppy won't be transmitting any vibrations in the floor thru the system, that's for sure! Always neat to see good old American ingenuity at work!
PostPosted: Jul Tue 03, 2012 5:54 pm
And I was worried I was spending too much time over at Audiokarma and Vinylengine. :shock: I'm with ReapirTech on this one. To each his own I guess.
PostPosted: Jul Tue 03, 2012 6:18 pm
The trouble is - these Duals are quite heavy units to start with.
Having a heavy steel deck AND a heavy cast aluminum platter.
I've owned several Duals though the years and know well they're quite immune to external vibration.
A mounting "plinth" of brick or even solid cast steel isn't worth the time or effort.
It won't make a difference.
If ANY transmitted vibration is to be worried about at all, it's the airborn bass transmitted to the record surface itself.
And if that's a worry, the OP can busy himself with making a concrete box to fit over the whole chassis, but it would make record-changing a big messy bother.
So WHY bother?........ just turn the music down, and save your hearing. :roll:
PostPosted: Jul Tue 03, 2012 6:49 pm
I think it looks rather cool
DIGITAL CIRCUITS ARE MADE WITH ANALOG PARTS
PostPosted: Jul Tue 03, 2012 7:04 pm
Know what is a bigger waste of time then making a concrete plinth?...complaining about someone making a concrete plinth... :lol:
dneprrider, I think it looks kinda cool...not my cup of tea but looks better finished then I thought it would. I bet it is a heck of a conversation piece when folks come over. Without stuff like this on the forum, this because a very boring place. Keep up the interesting work!
T
http://s160.photobucket.com/albums/t167 ... onographs/
PostPosted: Jul Tue 03, 2012 7:42 pm
T
Variety is the spice of life. My Father is bringing a nice slab of Purpleheart wood (that he got many years ago when working in Guyana) over this summer, and together we'll make another plinth out of that wood. Now that should look really nice too. It's fun to build things and perhaps give an idea or two to others to try and be a bit creative. I like to display and use my electronics so this is just another way to keep things from becoming stale around the house.
PostPosted: Jul Tue 03, 2012 8:22 pm
I think this can be a very lucrative idea...
For the nuts that buy gold plated, oxygen free copper line cords for $1000
this could be the ticket to make money, might have to insert steel rebar in the cement though...for strength
Maybe inbed the cement in plastic or something exotic
Of course, make up a good line of BS
Red up on some audio magazines, see what the latest buzz words are
PostPosted: Jul Tue 03, 2012 11:57 pm
Kenwood made a neat turntable in the 70's or 80's with a man-made marble plinth, so why not? Personally, I would have added color to the concrete to make it more attractive, but to each their own. It could still be painted whatever color you want it to be, I suppose. Nice job!
-John S.
We miss you guys!
PostPosted: Jul Wed 04, 2012 3:55 am
I will just add that I would paint the Concrete so it doesn't look like it belongs in the tool shed.
PostPosted: Jul Wed 04, 2012 4:22 pm
I'd probably tile it with mirror tiles, like a disco ball 8)
You had an idea & successfully followed it through, so for that I congratulate you. And at least it didn't cost you 100's of $$ like the marble & granite pliths I've seen sell for Garrard 301's.
Overkill or not, I think it's great to experiment, and if you have the time & materials, then why not?
Shane
PostPosted: Jul Wed 04, 2012 6:48 pm
I've got a late 70's Sansui SR-929 direct drive quartz locked turntable. The base is a concrete resin mix, finished in ebony gloss black. It weighs in at around 38 lbs.
Mort Denison
PostPosted: Jul Wed 04, 2012 7:47 pm
That is nice. Now I think I will make another in black concrete and see how it turns out.
PostPosted: Jul Wed 04, 2012 10:39 pm
Awesome! That is definitely an industrial look that would look great in a loft with brick walls. Nice job! Of course I would paint it to match my decor!
:wink:
LOVE & LIGHT!
*MaryAntoinette*
You can take the Girl out of Brooklyn...
PostPosted: Jul Wed 04, 2012 11:24 pm
Edison made at least a couple of Diamond Disc machines out of concrete as test cases.
I have a real lite 78 turntable that picked up vibrations from the floor (wood).
I got a thick piece of granite made the size of the table it is on and, problem solved.
Looks great.
Jerry F Bacon-Dallas,Tx
Post New Topic Post Reply  [ 17 posts ]  Moderator: Larry Hillis
