It is currently May Sun 19, 2013 10:54 am
Post New Topic Post Reply  [ 47 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Need help aligning my Zenith -- I hate alignments
PostPosted: Jul Thu 05, 2012 5:38 pm
Yes this is a before picture, every single resistor and capacitor has been replaced, every one. I just haven't taken any new photos yet. Any ideas on trimmer "L"?
I'm assuming the coil on the back side of the chassis is the wave trap, right?
Vincent
PostPosted: Jul Thu 05, 2012 6:28 pm
Seems one of these is for obsolete police band which you can forget about, other one to peak SW at 16.5 MHZ which you should be able to achieve with most signal generators, or a high harmonic modulated. Unless these caps are filfthy or shorted best leave alone. If you decide to clean them, count turns accurately to close completely, open
PostPosted: Jul Thu 05, 2012 6:39 pm
The police trimmer is N which I have identified, I'll leave that be. All trimmers are accounted for above chassis and on rear except for "L" which is under the chassis. Trouble is that there are 4 trimmers under there and I don't know which one is "L" to adjust for 16500 SW.
The uppermost trimmer you see circled in the picture is the one I originally thought was "L" and fiddled with. I think I put it back to where it should be, I have it in the same position, but I'm not positive if it should be backed out or in one whole turn. Right now I think it's not too tight and not too loose, so I think that's the way it is :lol:, but again, not sure if that's "L" or not.
Vincent
PostPosted: Jul Thu 05, 2012 7:57 pm
If it was me, I would suggest going ahead and doing the police band alignment. I have noticed several times that the police band adjustments on various Zenith radios (8s661, for example) altered the BC band slightly. It only takes few minutes .
Brett
PostPosted: Jul Thu 05, 2012 8:18 pm
Yes best to align the police band.
PostPosted: Jul Thu 05, 2012 8:26 pm
radiopicker wrote:
:shock: You guys are gonna kill me. I did a second BCB alignment just to confirm and fine tune. I was happy with the location of my SSTRAN station on the dial. I got the IFs peaked but as far as "alignment" SSTRAN station comes in at 1060KC and weaker at 1500KC.
A) way off
B) Why is there a duplicate station (image)?
1500KC-1060KC=440KC, could this be the 455KC local IF frequency?
Radiola 17/100
Cossor 3468
S'tone 6130
S'berg 535M
GE 417A
T'tone D1952
Phil. 118H
Delmonico PB-741
PostPosted: Jul Thu 05, 2012 9:32 pm
Okay will do, might as well! Thanks for letting me know. Does anyone out there have a clue as to which trimmer is "L"? I don't know how to figure this out.
Vincent
Post New Topic Post Reply  [ 47 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1, 2, 3
Users browsing this forum: Exabot [Bot], Google [Bot] and 13 guests
cron
