Page 1 of 1
[ 11 posts ] |
| Author |
Preston Smith
Post subject: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Fri 20, 2012 1:14 am |
| Member |
Joined: Nov Mon 14, 2011 4:39 pm Posts: 179 Location: Eureka, Pa
Greetings Folks!
I need to buy some wire for my repair bench. Ideally, 50 Ft of different colors of 20AWG with plastic (not nylon) coating and some 18 AWG with cloth coating.
Where's a great place to buy wire at a very low price and shipping?
Thanks!
_________________ Preston Smith Eureka, Pa Trans-Oceanics: G500, H500, Y600, A600 Royal 94 Inter-Oceanic
| Top |
Ed Kraushar
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Fri 20, 2012 7:47 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2025 Location: Campbellford, Ontario, Canada.
| Top |
Peter Bertini
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Fri 20, 2012 8:19 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12449 Location: Somers, CT
If you are going to be basing the wire on price....
the cheapest source I've found for PVC insulated stranded wire in different colors is to reclaim the wire from old control cables. You can try local scrap dealers, etc. The wire is good quality, but it is a bit of work to remove the outer covering on the cables, and you may have to guess at the working voltage.
Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
Preston Smith
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Sat 21, 2012 12:08 am |
| Member |
Thanks Guys!
Radiodaze only sells 22AWG. Any concerns about using 22AWG in place of 20AWG?
| Top |
Rockbert
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Sat 21, 2012 12:46 am |
Joined: May Mon 07, 2012 10:04 pm Posts: 59 Location: California
Free air ampacity for 20AWG=11A, 22AWG=7A. It's lower for bundled wires or other conditions. So it might be ok to substitute, depends what you're using it for.
| Top |
Peter Bertini
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Sat 21, 2012 2:58 am |
| Moderator |
I'd be leary in parallel filament voltage feeds, especially if the tube socket wiring is daisy chained. The voltage drop on the lighter AWG wire might have to much resistance and cause a voltage drop, especially at the last tube being fed filament voltage. It would be even more critical for early sets using 2.5 volt tubes because of the increased current draw.
to be safe:
Never go with a lighter gauge than was used originally for the filament wiring.
Pete
| Top |
Unusualdesigner
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Sat 21, 2012 4:30 am |
| Member |
Joined: May Sun 08, 2011 10:45 pm Posts: 2941 Location: Southern Calif
Troll thrift shops and or Goodwill stores for the old 25 conductor parallel printer cables. You can find them as long as 25 foot. Lots of wire inside <g>
_________________ It's easier to make a steam powered lobster trap than a lobster powered steam trap
| Top |
FrankB
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Sat 21, 2012 6:24 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2169 Location: Olympia WA USA
Whatever wire you find, be sure to look at the voltage rating on it. Most of the new stuff I see has a max of 300V  , whereas many old radios can run up to 600V. Typically I just by the 600V wire.
_________________ FrankB WB7ELC Member: TCA "I know that all that is wrong with it is one little part".
| Top |
Preston Smith
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Sun 22, 2012 3:52 pm |
| Member |
Thanks Frank - good advice on the voltage requirements.
Doesn't anyone here buy 20 AWG wire and have a recommendation?
| Top |
Stan Ski
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Mon 23, 2012 11:50 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7100 Location: Clinton Twp. Mi.
Just bought some 20 gauge rolls from All electronics.com. Prices seem pretty decent. Check out there site Stan Ski
| Top |
Preston Smith
Post subject: Re: 20 AWG Wire (Plastic) and 18 AWG (Cloth) - lowest price? Posted: Jul Tue 24, 2012 4:25 am |
| Member |
Excellent! Thanks Stan!
| Top |
Users browsing this forum: hawaii.ken and 2 guests |
