| Author |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Sun 05, 2012 7:35 pm |
Joined: Mar Mon 02, 2009 11:48 pm Posts: 2877 Location: 97381, USA
Here's where I'm at with reassembly. At first I looked at the pile of parts and had this sinking feeling. Then, using the pictures I took and the exploded view from the schematic I began to make some progress. Taking LOTS of digital pictures is a must. After you take a bunch, take even more. I always seem to miss that little part, spring or screw and wish I did take more.
| Attachments: |
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Sun 05, 2012 7:52 pm |
The reject before and after. I used white acrylic paint forced into the letters and wiped off the surface with a slightly damp paper towel.
| Attachments: |
| Top |
dberman51
Post subject: Re: Utah 7000 Phono restore Posted: Aug Sun 05, 2012 8:44 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2309 Location: Boston, MA USA
Incredible. It looked very rough but it's starting to look like brand-new.
-David
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Sun 05, 2012 9:09 pm |
Thank you David. I had this fit of depression last night when I looked at this and three other projects I have going all at once, sprawled all over my house. I don't know if it's like this for other members here, but I had to ask myself why I do this. It's certainly not profitible. It's messy and time consuming too. ARF puts it in perspective for me. Other members appreciate what goes into a project and if it's entertaining and educational for them, it gets me over the times when I question myself. Two days off work and it's time to clean up this mess!!
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Mon 06, 2012 5:04 am |
Here's a little design snafu--you can see a little brass tab I have an arrow to. This is supposed to be a spring that keeps part 58, the cam drive ratchet, pressed against part 69, the drive drum. Why they made it out of soft brass is beyond me since it takes a decent amount of pressure to keep it engaged when the drum swings back and drives the reject mechanism.
I bent it once and it's toast. Looks like I have to get creative here...
I think I can find a fine small spring about 3/8" long that I can epoxy where the current tab mounts. That should give the ratchet enough pressure to engage without too much drag. More on this tomorrow morning.
| Attachments: |
| Top |
Larry Hillis
Post subject: Re: Utah 7000 Phono restore Posted: Aug Mon 06, 2012 5:08 am |
| Moderator |
Joined: Apr Wed 09, 2008 3:37 am Posts: 9665 Location: Little Rock, Arkansas
Noisebox, that's going to be a gorgeous changer when you get done with it. What you have done so far looks very professional.
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Mon 06, 2012 5:12 am |
Thanks Larry. It's not really a complicated one. There are only three adjustments to make to get it aligned as well. I might just build a stand alone cabinet for it. I still don't have a player for my 78s
| Top |
Doug VanCleave
Post subject: Re: Utah 7000 Phono restore Posted: Aug Mon 06, 2012 10:49 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3523 Location: Berkley, Michigan
You have a good eye for detail. It's amazing how simple mechanisms once were. They are built for the adult male hand and easy to read and operate. It seems like everything built today is cheap, disposable, miniature and built for the hand and eyes of a child. I wonder what people will be collecting, and restoring 70 years from now. The only thing I know for sure is that it will be black plastic and reading glasses will be minatory to find the power switch.
_________________ That warm tube sound can usually be overcome by turning up the treble.
| Top |
Mr. Detrola
Post subject: Re: Utah 7000 Phono restore Posted: Aug Mon 06, 2012 2:51 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 18143 Location: Detroit, MI USA
Utah Radio Products was a subsidiary of Detrola at the time these changers were designed and manufactured. They made a few different models of changers, this was supposed to be the best one and is not seen as often as the others.
Quite a few radio manufacturers chose Utah changers as OEM for their radio-phono models. At least one of the Utah changers uses mostly stamped parts as opposed to castings and was specifically designed that way to make it less expensive to manufacture. There was an article about them in one of the trade magazines at the time they were introduced.
Some of the Utah changers were built at the Detrola factory in Detroit, according to my late friend Phil who was a manager there, others were built at a Utah facility in Huntington, Indiana.
_________________ Dennis
| Top |
dberman51
Post subject: Re: Utah 7000 Phono restore Posted: Aug Mon 06, 2012 2:59 pm |
Any relation to Utah speakers? BTW, Utah speakers is still around and still makes the 4-inch speaker of yore. I bought one a few months ago -- it looks exactly the same as it did 50 years ago except that the basket is now a dark blue, and the speaker has an 8-ohm voice coil rather than 4. Still has an Alnico V magnet, and is still made in USA.
-David
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 4:33 am |
Thanks for the compliment Doug. Your work inspires me. All of your sets have a nice glow to them. As you know, it takes a lot of time to give then the once over, but it pays off in the end with nice looking work that plays well.
Dennis, Thanks for the interesting history of this unit. The service manual has the name of The International Detrola Corporation on the front cover. I was wondering if there was a connection. With the exception of the little brass spring this thing is built for service and simplicity. I can see why they were popular. By the way, I grew up in Detroit in the '60s and '70s. Detrola was before my time but it was still a very exciting place to be in that era.
I'm wondering if this Utah is somehow related to Utah Lansing as well.
Back to work.... I went to the hardware store and sprung 60 cents for a spring. I got the softest one that would fit. I used JB quick weld epoxy and it seems to work fine now. I'm hoping the tension of the old one wasn't too critical but it'll show once I get it up and running if it isn't.
| Attachments: |
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 4:43 am |
The record shelf cover had a crack in it. I used some faucet screens and JB Weld quick epoxy to fix one side and reinforce the other. Now here's a case where I almost ruined this piece by dinking around too much. After the fix I polished it up with Novus and filled the numbers in with white paint as I did to the reject switch. Then I got this goofy idea in my head that it wasn't shiny enough so I sprayed it with clear acrylic..which made things start to look real bad. I think the solvent in the clear coat was attacking the plastic. Then, in a panic I tried to wipe it off and when that didn't work I started using lacquer thinner on it. One bad move after another!! Needless to say I spent at least an hour scraping and sanding it smooth again with the major loss being the numbers aren't as sharp as I would like the. Moral of the story--leave well enough alone!
| Attachments: |
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 4:52 am |
| Top |
Larry Hillis
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 5:03 am |
| Moderator |
Very, very nice. I have a changer I want to send you!!!!
| Top |
Doug VanCleave
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 9:27 am |
Hubba-Hubba.
| Top |
Larry Hillis
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 9:44 am |
| Moderator |
Noisebox, the more I look at the finished changer, the more I think a black flocked platter would look much better. Your tonearm and record support arm are black, so why not have a black flocked platter? Just my .02 on your finished changer.
| Top |
azenithnut
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 12:11 pm |
| Member |
Joined: Jan Mon 18, 2010 2:13 am Posts: 4391 Location: Dayton Ohio
Absolutely beautiful work! It looks wonderful! I too have done similar things as far as the record shelf. I remember one time cleaning up an old CB which had a clear plastic lens for "ON THE AIR" and "BUSY" lamps. I decided to clean it with Acetone. OH! I learned my lesson right there!  Acetone and plastic DO NOT MIX! I spent hours sanding, buffing and polishing that lens back to usable condition. It didn't look bad in the end, but it was a lot of extra labor I could have avoided. As they say, experience is the best teacher! -Steve
_________________ Radio Interests -Zenith -Sparton -Pre-War FM Consoles and floor models, the bigger, the better!
| Top |
Doug VanCleave
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 2:37 pm |
Larry Hillis wrote: Noisebox, the more I look at the finished changer, the more I think a black flocked platter would look much better. Your tonearm and record support arm are black, so why not have a black flocked platter? Just my .02 on your finished changer. I can't believe how close it looks to the original. Black is elegant but shows the lint.
| Top |
Larry Hillis
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 3:07 pm |
| Moderator |
The VM-made changer on my RCA Victor 3-HES-5 had a thick. plush almost black flocked platter that was absolutely fabulous. Doug, I never saw any lint on it, but my eyes don't see as sharply as your Nikon digital camera sees things.
| Top |
noisebox
Post subject: Re: Utah 7000 Phono restore Posted: Aug Tue 07, 2012 3:48 pm |
Larry, I usually go for what was there originally. Now, if there was a similar model with black I might consider it but i'm kind of a stickler for factory stock wherever possible. Here's the Philco D-10 changer I did. Total tear down and refinish. It's in my 46-1226
| Attachments: |
| Top |
Who is online |
Users browsing this forum: ryanswafford and 2 guests |
