It is currently May Fri 24, 2013 8:34 am
 Post subject: Zenith 8S661 Tuning Cord
PostPosted: Sep Wed 03, 2003 5:39 am
Hi Ted,<P>The "cut" dimension is what you would measure if you cut the belt and measured the length of it stretched out straight.<P>Several people have used O-ring material cut to the proper length and superglued together. If you do this, the 9 1/4" dimension is what you would use to cut the new part.<P>If you use a diagonal cut, make it very minimal. I prefer a straight cut myself. The superglued joint isn't fond of being bent around a radius.<P>------------------<BR>73 de Leigh W3NLB
Post New Topic Post Reply  [ 3 posts ]  Moderators: Marcc, Norm Leal
