It is currently May Fri 25, 2018 1:50 pm
Post New Topic Post Reply  [ 48 posts ]  Go to page 1, 2, 3  Next
 Post subject: My AA5 Homebrew / Trainer
PostPosted: Nov Sun 06, 2016 11:35 pm
I have been working on old radios for over 4 years, and although I have learned a lot (much of that from ARF) I wanted to get a better understanding of components and how they function in a radio circuit.
To help my learning, have started to build an AA5 radio/trainer. The idea is to have a simple working superhet radio that I can change components on and experiment with. I do not expect the radio to be great performer, nor win any awards for beauty :D
I first laid out a diagram on paper of where I would locate components. My designs changed several times after experimenting with different chassis and mounting techniques. Ultimately, I came up with what you see in the photos below. My first step was to lay out the tubes, power switch and lamp, then assemble and check the filament string.
After having done that, I added components to make the B+. I admit to being a bit nervous when I powered it on, and very happy when it came on with a measurement of 157 VDC.
I will update this thread with more photos and comments as I continue.
Russ
File comment: Tubes, switch, and lamp only.
File comment: B+ Added
A place for everything, everything in it's place. I just don't remember where all those places are.
 Post subject: Re: My AA5 Homebrew / Trainer
PostPosted: Nov Mon 07, 2016 1:11 am
What a nifty project!
I look forward to following your experiment.
*** Wanted: Hallicrafters S-76 ***
Chuck K4CCW
PostPosted: Nov Mon 07, 2016 2:43 am
Russ,
This is a great idea, as even someone who would be considered fairly experienced will be able to view circuit dynamics in what could be considered 'block diagram form'. Definitely a great way to brush up on theory!
Please make and upload a video (series, maybe?) demonstrating the results, trials and tribulations of working the bugs out of the initial version of the build, and the lessons learned during circuit modification.
Tim
After 5:00 PM Slip brains through slot in door
PostPosted: Nov Mon 07, 2016 2:45 am
+1!
PostPosted: Nov Mon 07, 2016 4:43 am
Pretty neat! You could also stick in a fuse or two.
PostPosted: Nov Mon 07, 2016 6:01 am
Looking good! In the future you can use octal relay socket to make swapping out components easier to experiment with.
Sal
Need capacitors, resistors and other parts--> http://www.tuberadios.com/capacitors
PostPosted: Nov Mon 07, 2016 6:18 am
Sal
Still time to do it, Mouser has them http://www.mouser.com/search/ProductDet ... ey70-464-1
Diode Don, all problems rectified.
Someone with less knowledge than I had been in there before ....
PostPosted: Nov Mon 07, 2016 6:48 am
Even cheaper: http://www.ebay.com/itm/New-8-Round-Pin ... Sw6n5Xq0NF
PostPosted: Nov Mon 07, 2016 8:20 am
BikenSwim wrote:
Sal
Nice socket.
But why were these made for use with relays?
Why couldn't the relay just plug into any regular octal socket and be wired up like a tube?
What am I missing?
PostPosted: Nov Mon 07, 2016 3:25 pm
BikenSwim wrote:
Sal
Nice socket.
What am I missing?
Socketed relays are often used in machine control cabinets and such. They are usually surface mounted and then point to point wired.
PostPosted: Nov Mon 07, 2016 5:36 pm
What am I missing?
For industrial use they make up wiring harnesses with crimp spade connectors to connect to the socket screw terminals. Making a change is easier than unsoldering and resoldering and so is replacement of the socket. The other standard is to use DIN rails rather than surface mount directly.
For a prototype project this makes good sense to me because you can break a connection, take a reading and then reconnect the wire with very little effort. I could even see putting all resistors and capacitors on terminal strips with screw terminals for similar reasons.
Kind of like a Radio Shack electronics 10 in 1 lab...... except with very hot components and lethal voltages! :-)
Very cool project! My only suggestion would be to skip the AA5 and go to a basic superhet with 12v filament string. This would make swapping and experimenting with different tubes easier. It also removes the 110v line from your tubes.
Rick
AB5ON
Forest Gumping through life
PostPosted: Nov Mon 07, 2016 6:58 pm
Very cool! A home-built RCA Dynamic Demonstrator, for a small fraction of the cost. I would love to have the same sort of setup to simulate common radio faults to the members of our antique radio club that are just getting started in the hobby. I look forward to seeing the results of your progress!
- Joe
"There are 10 types of people: Those who understand binary and those who don't."
PostPosted: Nov Mon 07, 2016 9:59 pm
Interesting thought, but he would get more learning mileage using an AA5 type of circuit, with it's normal tube lineup.
Perhaps adding a power transformer would offer reasonable shock protection?
PostPosted: Nov Mon 07, 2016 10:16 pm
A center-tapped 12.6 volt transformer would allow trying any mix of 6 or 12 volt tubes on hand.
There is a 12L6 version of the 50L6, and 12X5 rectifier for example. An isolation transformer for B+ and you would be able to try anything. eBay has cheap Chinese eye tubes for 7 pin miniature sockets, and all kinds of small digital panel meters.
PostPosted: Nov Tue 08, 2016 1:46 am
When working on a AA5 I still refer to this when I am stumped.
That's not a wedding ring Barney, it's a radar unit so they know what we are thinking and doing all the time. Fred Flintstone
PostPosted: Nov Tue 08, 2016 2:19 am
That's a great idea, but please use an isolation transformer with this.
PostPosted: Nov Tue 08, 2016 3:05 am
Sal
Interesting thought! I tried a few ideas before I settled on the one shown, including putting the tubes upside down underneath the board so the sockets would be up. Really no different than tipping a chassis over I suppose.
In any case the octal relay base is a cool idea, though I think at this point I will leave things as they are. I will need to find a way of making temporary connections for component swapping.
Russ
PostPosted: Nov Tue 08, 2016 3:08 am
Wow! That is very cool, I bet there were many of those made for training back in the day. Probably not too many left.
Russ
PostPosted: Nov Tue 08, 2016 3:10 am
Yup absolutely! I may take Number 6's advice and install a fuse also.
Russ
PostPosted: Nov Tue 08, 2016 3:28 am
BikenSwim wrote:
Sal
Nice socket.
What am I missing?
The convenience of screw terminals to change things and experiment. Like this one I did when experimenting with octal battery tubes.
Not exactly pretty but it worked.
For 9 and 7 pin I made these up from old scrap terminal PC boards.
Users browsing this forum: johnnyreece and 4 guests
