radioalfa wrote:
Today I replaced the antenna with one from an AA5, and after a little tweaking of the trimmer, I have very good reception across the band without having an additional wire added.
I don't know what radio the old antenna was from, but clearly not the best match for my radio.
Russ
In cases like this a cheat tool(inductance meter) is helpful... Can measure working antenna, then add or subtract as necessary to match to your useage... As you've found not all are same... Of course it can be done without meter, just gives a accurate starting direction...
BTW, great work, nice project you've built...
