It is currently Nov Sat 18, 2017 9:03 am
Post New Topic Post Reply  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: GE P-1810A project...
PostPosted: Jan Mon 02, 2017 4:12 am
Have one of these in the "pipeline" and wondered if anyone had the service info and would share it ?
From pics, it appears to have a tuned-RF amp stage and has 10 transistors.
Also would like to hear of anyone's experiences with these sets...
Seller claims it is dead---hopefully caps or something simple, but would like to have info "just in case" and to see how those 10 transistors are being utilized...
Thanks much !
 Post subject: Re: Anyone have service info for GE P-1810A to share ?
PostPosted: Jan Mon 02, 2017 4:49 am
Hey John, it was covered in Sams TSM 65 January 1966
Unfortunately I don't have it.
http://i.ebayimg.com/00/s/MTA2NlgxNjAw/z/uUUAAOSwNSxVUgiB/$_57.JPG
oh... Happy new year... :)
PostPosted: Jan Mon 02, 2017 2:58 pm
I'll be able to scan and post it this afternoon...
PostPosted: Jan Mon 02, 2017 4:57 pm
Thanks much Greg & Jim !
Wish all a Good 2017 !
PostPosted: Jan Mon 02, 2017 8:23 pm
You're welcome.
https://www.dropbox.com/sh/smnxk8a484ah ... lmyRa?dl=0
Enjoy!
PostPosted: Jan Mon 02, 2017 9:32 pm
Hey Jim,
Just downloaded the images---excellent hi-res scans ! Sure appreciate your effort---thanks again !
Neat to see the model page---actually had the P-1820A AM/FM version many years ago, but gave it away...
Kinda "chintzy" for GE to use two transistors as bias regulator diodes, but guess that was towards the end of the transistor-count "wars" and they wanted to make an impression...
Wonder if this will be of the same caliber performance-wise of other GE tuned-RF amp equipped sets of that era ?
 Post subject: Re: GE P-1810A project...
PostPosted: Jan Fri 06, 2017 3:16 am
Radio arrived today and not as good as it looked in Ebay pic---dents in grille and small dings in tuning knob bright like someone stabbed at it multiple times with ball-point pen...
And---someone had ripped the oscillator coil of off PCB (see below) !!! No inside pics in listing, but never expected this...
PostPosted: Jan Fri 06, 2017 3:43 am
Sometimes you eat the bar, and sometimes... well, he eats you.
:) Greg.
PostPosted: Jan Fri 06, 2017 5:31 am
Shouldn't be too difficult to harvest another osc coil from a junked Transistor set.
PostPosted: Jan Sat 07, 2017 2:29 am
Now need to find what cheap, undesirable GE sets use that same oscillator coil !
SAMS says the GE part number for it is: RT-1069
Anyone recognize that number ???
Thanks !
PostPosted: Jan Sat 07, 2017 3:55 am
John, what makes you think that it's any different than any other garden variety Transistor radio oscillator coil? I would just grab one from any Transistor donor and try it.
PostPosted: Jan Sat 07, 2017 11:50 pm
Mitch
PostPosted: Jan Sun 08, 2017 4:33 am
Thanks for the info, Mitch...
I had one new oscillator coil of same size with the pinout of the low & high impedance sections (either side of tap) of primary reversed. I tacked it in wiring as it should be and it barely worked---only able to receive the two strongest stations and couldn't even align them to proper locations on dial, so these are not all the same ! Maybe for the cheapo, handheld portables they made a zillion of...
Maybe, just maybe someone will have one of these radios in a junk-box...
Not doing well lately radio-wise---the T-81H was trashed by someone probably using an incorrect wall-wart...
PostPosted: Jan Sun 08, 2017 6:09 am
Hey John,
Go to the Archives and look at Elements of Radio servicing, I think it's chapter 14 dealing with oscillator coils. He discusses the procedures needed if an exact replacement isn't available. Even though the subjects are tube radios, the principles would be the same.
PostPosted: Jan Sun 08, 2017 4:46 pm
Hi John,
You could try modifying the osc coil that you have, you can not loose much.
Your problem seems to be that the "run of the mill" oscillator coils are for the small polyvaricon caps, and those have about 80pF - 90pF final capacitance at the oscillator section.
In your radio, judging from the oscillator padding capacitor, C8 390pF, it looks that the oscillator section in the variable cap has about 360pF final capacitance. That means about 180pF - 200pF final capacitance for the oscillator. (You could also just measure it, if you have the tools for that!)
For that capacitance the coil is too much, that is the reason the dial does not line up, and the sensitivity is off as the antenna and RF stages can not be tuned up for that osc coil.
The generic osc coils have 360uH inductance, from datasheets of osc coils and IF coils:
http://www.electronics-tutorials.com/filters/if-amplifier-transformers.htm
For 180pF you would only need about 140uH inductance.
With about 110 turns for 360uH, you would need only about 70 turns for 140uH.
You could try removing wire from the existing osc coil if you manage to disassemble it.
Usually the largest winding is on the outside, so just find the wire ending at the outside and remove the turns. The coils I played with it the winding was secured with bees wax, and despite the thin wire, I could remove turns. To tell the truth, that was only one turns, the wire end was broken in the coil!
I would not worry about the changed turn ratios, the oscillator circuit is quite tolerant to that.
If the wire removal turns into a "disaster", you could try to rewind it.
Here are my adventures:
http://antiqueradios.com/forums/viewtopic.php?f=4&t=197891&p=2226186&hilit=philips#p2226186
Good luck, Peter
PostPosted: Jan Sun 08, 2017 5:09 pm
Thanks Richard---have seen you refer to that resource before, might be interesting info...
And thanks much, Peter, for the detailed analysis and information ! Think I'll put this radio on hold for awhile to see if I can find the proper part, but will keep your post in mind. I don't have an LCR meter, but it would be a handy tool. I've repaired broken connections in these small coils, so guess I could try removing some turns if necessary...
PostPosted: Jan Sun 08, 2017 5:35 pm
Hi John,
Just another thought!
Instead of changing the oscillator coil, you could change the oscillator padding capacitor!
From quick calculations, try 120pF for C8.
You also might need to change (decrease) the value of C11.
This might affect the accuracy of the tracking, but I think it is worth a shot.
Peter
PostPosted: Jan Sun 08, 2017 5:51 pm
Thanks Peter !
PostPosted: Jan Sun 08, 2017 6:16 pm
I would bet it was a kid that snapped off the oscillator coil, although perhaps some adult broke it while trying to adjust it. In any case, I hope you can find a replacement.
PostPosted: Jan Mon 09, 2017 12:22 am
Hmm, interesting. If that's the case, then an osc coil from an AA5, many of which used tuners in the 350-405 mFd range, might work.
John, if you have a junked AA5 from which you could harvest the coil, you might try that.
Post New Topic Post Reply  [ 44 posts ]  Moderator: Dave Doughty Go to page 1, 2, 3  Next
