It is currently Feb Sat 16, 2019 2:58 am
 Post subject: Worst Philco Block Repair Technique
PostPosted: Jan Tue 02, 2018 12:38 am
Starting to recap a Philco 630 and found two terrible block repairs. Two terminals were CUT OFF of each block and the new caps tied on in the air without any support! Terminals were still attached to the components.
Dale
http://www.dalesantiqueradio.com/
 Post subject: Re: Worst Philco Block Repair Technique
PostPosted: Jan Tue 02, 2018 1:10 am
Only two???
Terry
PostPosted: Jan Tue 02, 2018 1:17 am
He left the grounds.
Dale
PostPosted: Jan Tue 02, 2018 1:32 am
The same guy must have worked on the Philco 60 that I just finished. Same technique.
Russ
A place for everything, everything in it's place. I just don't remember where all those places are.
PostPosted: Jan Tue 02, 2018 1:37 am
Same guy was in a Philco 80 I am starting on. Components flying through the air all over the place.
PostPosted: Jan Tue 02, 2018 2:36 am
Those blocks are a pain but make for a nice clean re-stuff job when done properly.
Consider me a straw in your haystack of success.
PostPosted: Jan Tue 02, 2018 4:26 am
It is just hard to match to the schematic with airborne components.
Dale
PostPosted: Jan Tue 02, 2018 4:02 pm
And the sets worked for probably 25-40 years with these repairs... No real doubt, were good enough...
PostPosted: Jan Wed 03, 2018 1:01 am
It must be a pretty common technique, even though I hate it, but I have seen it done that way in almost every Philco I have worked on. I suppose the Philco blocks were not readily available to anyone but a Philco dealer/service tech. Capacitor sizes of the Day were too large to restuff the blocks. Leaving them hanging with out tieing down is just poor practice, though. I have seen enough of that done too. :x
Chris
N9WHH
PostPosted: Jan Wed 03, 2018 1:09 am
If speed and money are all that count, then he did it the right way. Sure looks ugly, however!
Tom K6VL
PostPosted: Jan Wed 03, 2018 1:39 am
If you are fortunate enough to have unmolested blocks, it's not THAT hard to de-pot the blocks if done carefully. Could be done in an old toaster oven no longer used for food while watching closely. I have un-potted capacitor and transformer blocks in wax and tar on a gas grille, again, watching very carefully. If you are married, and your spouse doesn't share your enthusiasm for the hobby, don't try it in the kitchen oven LOL. :)
"There Is Nothing Finer Than A Stromberg-Carlson"
PostPosted: Jan Wed 03, 2018 4:51 am
Early repairmen did not have the luxury of miniature radial lead caps that could be easily inserted into a cleaned out shell.
PostPosted: Jan Wed 03, 2018 5:56 am
He could have drilled thru the rivets on the block and then added the caps externally. Did not have to clip the terminals.
Dale
PostPosted: Jan Thu 04, 2018 3:38 am
They were paid to repair, not restore, back when those sets were daily players in homes. A lot of early repair work would be considered shoddy and lazy today.
PostPosted: Jan Thu 04, 2018 1:20 pm
Unless the sloppy work has been done with modern components, I would not be too critical of the repairs.
Fixing a chassis to earn your daily bread is something quite different than doing it as a hobby where time is not so demanding.
Joseph
Post New Topic Post Reply  [ 15 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: AJJ, calmark, ptc42@juno.com and 13 guests
