robert1 wrote:
<font>quote:</font><HR>Originally posted by Ken Miller:<BR><B>Excellent point about getting rid of the moisture, Brian. The question is can I get away with running a largely exposed high voltage winding long enough to get the moisture out? Might I be better off baking the transformer in an oven (maybe at something like 150 degrees F)? It gets pretty darn hot in my attic in the summertime - maybe I should stow this one in the attic for a while and swap another onto the chassis. I have 4 chassis and I intend to get two of them working. The other two are for parts. When summer gets here I could pull the transformer out of the attic and encapsulate it then.<P></B><HR>
<P>about placing it in the attic-to dry it out...will not work. the humidity is high during the summer months. the best way to dry that transformer out is to just operate it in intervals starting from 10 miniutes on..10 miniutes off, gradually increasing the amount of time it is on. this method usually takes about half of a day, but it does dry it out.<BR><P>------------------<BR>
