Antique Radio Forums :: View topic - Easy to build capacitor checker A must for checking parts .
Forums :: Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives :: Books :: Value Guide :: Wiki  Support This Site: Contributors
Radio Showroom
 Forum Rules/FAQ   Posting Photos   Search     Register   Profile   Log in to check your private messages   Log in
Easy to build capacitor checker A must for checking parts . Goto page Previous  1, 2
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Hints & Kinks
View previous topic :: View next topic
Michael Simos
Posted: May Mon 18, 2009 3:46 am  Reply with quote
I recently built one of these testers. It works great and I've found it very useful as I work on a lot of vintage guitar amps and Leslie amps where the owners get upset if you recap the "tonestack". This way I simply unsolder one lead off the tagboards and check for leakage.
It also confirmed what I've always suspected--virtually every paper and wax cap leaks like a sieve as well as just about every Sprague "Black Beauty". Thank you all for a great circuit and a very, very, useful piece of test equipment.
View user's profile Send private message Visit poster's website
Norm Leal
Posted: May Mon 18, 2009 4:17 am  Reply with quote
Hi
I built something like this only using a meter instead of neon lamp. You can just about read capacitor value by how far the meter deflects. With a good cap meter drops back to zero. A leaky cap continues to give a reading.
Mike Toon
Posted: May Mon 18, 2009 7:15 pm  Reply with quote
Not to hijack but....I see you have a description on the outside of the box. Can't tell you how many times I've picked up a project with a plug on one end and wires coming out the other and have to take it apart to find out what I built. I now use a silver Sharpie on those black boxes.
View user's profile Send private message Send e-mail
amptramp
Posted: Jul Thu 23, 2009 2:20 pm  Reply with quote
I added something similar to my Heathkit VTVM several years ago. I added a tip jack on the back (there is sufficient space in the circular cutout on the back around the line cord to add small components) and connected it to the internal +70 VDC supply. I connected a test lead with an alligator clip to it and clipped the capacitor to this lead and the volts probe and measured the voltage on the DC volts scale.
The meter would deflect up to +70 briefly then decay back down. Since the input resistance is known (11 megohms), I could translate the meter reading directly into leakage current.
Some capacitors would decay down to zero or so close to zero that I could not see any deflection even on the lowest (1.5 volt) scale. Some capacitors hovered near ground but never quite made it. And shorted capacitors read +70 volts continuously.
KyMike
Posted: Aug Wed 12, 2009 3:18 pm  Reply with quote
In the variable voltage tester circuit #2, why is the voltage adjusting pot connected across the ac line instead of in series?
Curt Reed
Posted: Aug Wed 12, 2009 3:20 pm  Reply with quote
Because you want a voltage divider. Otherwise with nothing hooked to it, there would be full voltage at the terminals at all times, as there is no current being drawn to create a voltage drop.
Curt
Curt, N7AH
KyMike
Posted: Aug Wed 12, 2009 3:26 pm  Reply with quote
Ok, just curious. Thanks.
Homer1952
Posted: Aug Sun 30, 2009 2:47 pm  Reply with quote
This looks like the ticket for me. I am rebuilding an old Sherwood tuner & am wondering about all the small caps. I did not see any comments about in/out of circuit testing. Must you disconnect at least one leg of the cap from the circuit? Thanx- Bob
Homer1952
Posted: Aug Sun 30, 2009 4:12 pm  Reply with quote
Thoughtless question. It will be circuit dependent.
Renslipevol
Posted: Nov Mon 02, 2009 8:28 pm  Reply with quote
Very nice thread! I have to build myself one.
Makes me wonder how many megaohms it would be before the neon light starts to break down. The neon bulbs I was looking at online don't show what the current is at breakdown; just design current.
I would have to be more than 59.999 Mohms for me to make it, my fluke can getem, although it won't test them at 300v Laughing
Display posts from previous:
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Hints & Kinks All times are GMT
Page 2 of 2
You cannot post in this forum
Only registered users can edit or delete their posts in this forum
