| View previous topic :: View next topic |
| Author |
radiowizard Member
| Posted: Nov Tue 03, 2009 11:58 pm |
Digging thru a box-o-tubes, I found this: Gas Tetrode Tube Type BR-105050...It's by Raytheon, but the sticker is from Seeburg...is it a type of regulator?
RadioWizard _________________ Member of the VRWC since 1994. (Hint: It's NOT a radio club)
tubenutt Member
Joined: 01 Jan 1970 Posts: 2510 Location: Medford,Or USA
| Posted: Nov Wed 04, 2009 12:41 am |
The Raytheon BR was first made in 1932 doing duty as an auto radio rectifier in Motorola sets. A de-rated BH, if you will.
If you have a TV-7, I can give you the test set-up.
It was never a popular tube. _________________ Steve McDonald
radiowizard Member
| Posted: Nov Wed 04, 2009 1:27 am |
I have a Precision 910 tester, and a B&K 747B. If it was mostly for auto radios, wonder what Seeburg was doing with it? Didn't they only do jukeboxes, or did they do auto radios in the 30s?
RadioWizard _________________ Member of the VRWC since 1994. (Hint: It's NOT a radio club) |
Alan Douglas Member
Joined: 01 Jan 1970 Posts: 14982 Location: Pocasset, Cape Cod, MA
| Posted: Nov Wed 04, 2009 1:42 am |
| Can't be a BR, that's a rectifier not a tetrode. If it's Seeburg it's probably a thyratron controller for one of their juke boxes or wallboxes. Put "Seeburg" in the title and someone will notice it. |
Fredfixer Member
Joined: 21 Sep 2006 Posts: 94 Location: Youngstown, Ohio
| Posted: Nov Wed 04, 2009 1:45 am |
| radiowizard; If you have the description right--gas tetrode--the jukebox folks may have used it for relay control in one of their wallbox setups. regards, Fred |
radiowizard Member
| Posted: Nov Wed 04, 2009 2:36 am |
That is what is on the Seeburg label...Gas Tetrode...wonder what kind of gas is/was in it? Seems like there is a residue on the inside of the envelope. Mercury?
Tim Tress Member
Joined: 01 Jan 1970 Posts: 3319 Location: Beaver Falls, PA. USA
| Posted: Nov Wed 04, 2009 3:06 am |
The Seeburg jukeboxes which had a core memory used a 2050 thyratron as a relay control tube; a "live" memory location would be picked up by a pulse amplifier and trigger the 2050, which would activate the trip solenoid in the changer mechanism. Wall box models also used a 2050 as a stepping-relay driver.
I don't know if the tube in question is related to the 2050 in any way. _________________ Tim KA3JRT |
juke47 Member
| Posted: Nov Wed 04, 2009 11:53 am |
Seeburg also made at least one type of gun game called "Shoot The Bear". I know it used at least one uncommon tube. Perhaps it is this tube. I believe it was some sort of sensor tube. I have never owned (wish I did) or explored a "Shoot The Bear" so my knowledge is near zero.
David (juke47) |
deltysdal Member
Joined: 28 Nov 2008 Posts: 628 Location: Glyndon MN, 48 miles from Foxhome MN
| Posted: Nov Wed 04, 2009 2:06 pm |
I have the trashcan 1946 model and that is not one of my tubes. _________________ Yes, I can. |
MouseMaster Member
Joined: 01 May 2009 Posts: 268 Location: South River, NJ
| Posted: Nov Wed 04, 2009 9:53 pm |
| I own three Seeburg jukes, including one with the core storage unit (1955 V200). I hae not seen the tube you describe in any of my machines. Tim's description of the relay operation with the 2050 is on the mark. This is what my machine has. I can't say exactly what may have been in the wallboxes though, but I didn't think there were any tubes in them. |
radiowizard Member
| Posted: Nov Thu 05, 2009 2:08 am |
Maybe the sticker/number is strictly a Seeburg item placed over the Raytheon number. An earlier post here mentioned car radio...wouldn't those have used Loctals?
Tim Tress Member
| Posted: Nov Thu 05, 2009 2:11 am |
The early Seeburg wireless wall-boxes used with the 146/147/148 "trashcan" and hideaway models did use a pair of 6C4s in each wall box; one as an RF generator, and one diode-connected as a rectifier. When coins were inserted in the box, it enabled a motor-driven pulser, which outputted a stream of RF pulses which corresponded to the number of the record which was selected. A TRF receiver in the jukebox picked up the signal, which was carrier-current coupled to the AC line between the wall boxes and the jukebox. The detected pulses fired a 2050, which drove a stepping relay connected to the selection solenoids.
The whole thing is VERY close in design to the Philco Mystery Control, except that the Philco system used radiated RF pulses. _________________ Tim KA3JRT |
JukeBoxDenny Member
Joined: 01 Jan 1970 Posts: 1921 Location: Iron River Wi. 54847 (jukeboxdenny@yahoo.com)
