Antique Radio Forums :: View topic - Found. A new/old Hammarlund. It's now working great.
Forums :: Resources :: Features :: Photo Gallery :: Vintage Radio Shows :: Archives :: Books :: Value Guide :: Wiki  Support This Site: Contributors
Radio Showroom
 Forum Rules/FAQ   Posting Photos   Search     Register   Profile   Log in to check your private messages   Log in
Found. A new/old Hammarlund. It's now working great. Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Communications Receivers
View previous topic :: View next topic
Curt Reed
Posted: Nov Sat 07, 2009 11:27 pm  Reply with quote
OK, but I am getting totally lost here. The filaments do not have DC voltage on them, they run of AC.
Curt
Curt, N7AH
View user's profile Send private message Send e-mail
KC4VWU
Posted: Nov Sun 08, 2009 1:18 am  Reply with quote
Cathode and one side of the filamet are tied togeather. Measure DC from there and chassis ground. I would probably unsolder the lead from rectifier cathode to the input choke and measure it again if it reads low the first time around. Also, measure B+ at the output of the last filter choke and see what you have there.
Phil
badrestorer
Posted: Nov Sun 08, 2009 1:29 am  Reply with quote
Rectifier voltages. Seeing is believing. The schematic calls for a 5U4G, but it's been substituted with a 5R4GY.
Pin 2 (one end of filament), 5.20vac:
Pin 8 (opposite end of filament), .10vac:
DC voltage on the filament. Pin 2...12.60vdc:
DC voltage on the filament (opposite end of filament). Pin 8...12.95vdc
Power transformer secondary. Center tap to pin 4...299vac:
Power transformer secondary. Center tap to pin 6...298vac:
Across pins 4 & 6...596vac
They don't know the power of the radio side.
Curt Reed
Posted: Nov Sun 08, 2009 1:42 am  Reply with quote
Then I would say the rectifer tube has lost its emission.
Curt
Curt, N7AH
Burnt Fingers
Posted: Nov Sun 08, 2009 1:47 am  Reply with quote
Pull the tube and use a couple of SS diodes. Since the AC on the plates is fine, the tube isnt turning red and the transformer isnt groaning then there isnt much left.
Meanwhile PM me an address and I'll send a good 5U4 on Monday.
The diodes will let you at least work on the radio, alignment, etc. while waiting for the tube. Or you can just leave them there.
WAIT a minute, I just reread your post and Im getting confused....nothing new. You cant measure the DC between the filament pins as there is no ground reference. It has to be measured from Pin 8 to chassis ground.
Also check your meter to be sure its still working on DC.
badrestorer
Posted: Nov Sun 08, 2009 1:59 am  Reply with quote
Thank you for the tube offer, but I've already pulled Genoo's chain for one, and a few others.
Meanwhile, I've never subbed a tube with diodes before. I'm looking forward to doing it. Should be fun. I've got plenty of 1N5346B types. But I don't want to do it wrong and screw up the power transformer, so I'd appreciate it if someone would hold my hand and walk me through it. Once taught I'll not forget how it's done.
Shouldn't I be able to solder the diodes to the tube pins, up close to the base, then put the tube back in the socket? Just a thought.
Burnt Fingers
Posted: Nov Sun 08, 2009 2:42 am  Reply with quote
That is a 9.1V zener diode, no good for this.
Go to Rat Shack and buy four 1N4007's. You will wire two in series as two sepearte pairs. The banded end is the cathode and the other the anode. Wire the cathode of one to the anode of the other. Connect one pair with the anode to Pin 4 and cathode to Pin 8 and the other pair with anode to Pin 6 and anode to Pin 8. Leave the tube out.
badrestorer
Posted: Nov Sun 08, 2009 3:18 am  Reply with quote
Carl,
Of course they're zener diodes. I hate brain-farts. But I'm still confused. Do the cathodes of both sets of diodes get hooked to pin 8? Doesn't something have to be hooked to pin 2?
Also, won't two diodes do the job/ I do have two on hand.
Burnt Fingers
Posted: Nov Sun 08, 2009 3:36 am  Reply with quote
Nothing goes to pin 2 and both cathodes go directly to the filter cap and choke via Pin 8. Its a standard full wave rectifier circuit.
One 1N4007 in each leg is cutting it close but should work. Just keep a close watch on them while working on the set.
badrestorer
Posted: Nov Sun 08, 2009 4:28 am  Reply with quote
Thanks again, Carl. Too pooped to do it tonight. I'd make a mistake. Tomorrow morning it'll get the works. I sure hope this solves the problem.
badrestorer
Posted: Nov Sun 08, 2009 3:23 pm  Reply with quote
And here it is, folks. Many thanks to Carl for the diode idea and installation guidance. He was right on:
Two questions: To get reception, I have to keep the sensitivity maxed out. Is that normal for this unit?
Also, the antenna compensation adjustment (located below the S-meter window) works fine, but it spins it round and round. Shouldn't it have a stop tab or something?
Dave Doughty
Posted: Nov Sun 08, 2009 3:32 pm  Reply with quote
With the AVC on, you would usually set the sensitivity control at maximum. The antenna trimmer capacitor has no stops and will go around and around.
Glad you got the set working!
gvel
Posted: Nov Sun 08, 2009 3:44 pm  Reply with quote
Nice!
What are you using for a speaker? It's sounds great, in your video.
There's always next year!
WD8PHW
Uffda
Posted: Nov Sun 08, 2009 5:08 pm  Reply with quote
Nice work John. You sure are getting your moneys worth out of that camera.
-Phil
badrestorer
Posted: Nov Sun 08, 2009 5:40 pm  Reply with quote
gvel wrote:
Nice!
It's an 8-ohm speaker from a cheap stereo unit we had stored in our shed. Cheap, but works pretty good.
badrestorer
Posted: Nov Sun 08, 2009 5:46 pm  Reply with quote
-Phil
Phil,
This is just the beginning, my friend. I'm not about to let it sit around collecting dust. But I still have to improve the audio problem after upload to Youtube. The vids sound tinny with a slight echo. I don't like it that way. Could just be the compression Youtube does, but I think there's a way to somewhat compensate with the camera or its associated, albeit limited, editing software. I have to figure it all out.
I'll do it in my spare time. Rolling Eyes
Ross Hochstrasser
Posted: Nov Sun 08, 2009 5:50 pm  Reply with quote
HURRAY!! Congrats !! I had a feeling it wasn't a big problem. Keep going with it, you'll really like thei radio. If you need a NOS JAN 5U4 I have a few extras. Good Luck!! Ross
"If you throw it through the window,you have to fix the window too!"
Cats are living proof that God has a sense of humor!
Curt Reed
Posted: Nov Sun 08, 2009 5:53 pm  Reply with quote
It isn't often a rectifier tube looses all its emission like that without the filament opening up. The 5R4 is a tube that is rated at higher voltages, but less current than the 5U4 tube is. But still the HQ-129X would not draw enough current to harm the tube. I suspect that the tube was well used in something else before it was plugged into this set.
Curt
Curt, N7AH
KC4VWU
Posted: Nov Sun 08, 2009 9:07 pm  Reply with quote
Could the rectifier tubes have been so depleted that a really leaky filter cap or some heavy draw down line wouldn't make the tube run into meltdown mode? I've never ran into that but it sounds feasible? Especially at the DC output voltages he's getting there. I need some wisdom here to figure that one out.
Phil
Burnt Fingers
Posted: Nov Sun 08, 2009 10:28 pm  Reply with quote
Glad thats fixed John Laughing Ive been outside all day cutting trees and clearing brush.
Whats with the crystal filter switch?
Display posts from previous:
Post new topic   Reply to topic    Antique Radio Forums Forum Index -> Communications Receivers All times are GMT
Page 6 of 9
You cannot post in this forum
Only registered users can edit or delete their posts in this forum
