It is currently May Sun 27, 2018 10:36 pm
 Post subject: Metrodyne Super Six
PostPosted: Jan Tue 05, 2010 2:36 am
Looking for any information on a Metrodyne Super Six.
PostPosted: Jan Tue 05, 2010 2:51 am
What do you want to know?
It's a battery set made in 1926.
There's a photo of one in the gallery.
73, Ron w4ron
PostPosted: Jan Tue 05, 2010 5:03 pm
I have one, itsd a very nice looking radio. I would like to see ads for it, and schematics, tube list. It looks to have a pair of audio output tubes, so would like to know if they used 112's or 71's.
PostPosted: Jan Tue 05, 2010 5:17 pm
Silent Key
If it were a battery operated set, I think it would have used the 112A for an output tube, if not an 01A. The 71A takes considerably higher bias and plate voltages and were used in the early AC sets, but I am sure there were exceptions.
Curt
Curt, N7AH
PostPosted: Jan Tue 05, 2010 6:12 pm
B+ is 135v that lead me to think it might be 71A's. The output tubes are in parallel. I looked at the one in the gallary and mine has a tube socket between the transformers, the one in the photo doesn't.
PostPosted: Jan Tue 05, 2010 6:25 pm
PostPosted: Jan Tue 05, 2010 6:54 pm
Silent Key
I am under the understanding that when "power tubes" became available along about 1926 or so, there was a mad rush for set owners to buy them up to get more volume out of their sets. Not all were successful, as the higher voltages and currents sometimes would burn out a speaker that had the voice coil in series with the B+ to the plate of the output tube.
Also, with most sets, it really did not make any difference whether the output tube was changed to a 112A or a 71A. Mainly depended on your finances, as with the 71A, the added expense of the batteries would have to be taken into consideration.
I have swapped between a 112A and a 71A in several of the older battery sets using the same B+ and C- voltages and could not tell a lick of difference between the two tube types in the output. I think where the 71A shines, is when you use higher bias and plate voltages on it that would not set well with the 112A.
Curt
Curt, N7AH
PostPosted: Jan Tue 05, 2010 6:58 pm
Any one have any info on a Columbia Senior Six?
PostPosted: Jan Tue 05, 2010 9:11 pm
It looks like the one in the photo gallery has a super five chassis with a super six panel.
This is a TRF receiver; it shouldn't be too hard to trace out the circuit.
PostPosted: Jan Wed 06, 2010 12:04 am
Ckt traced out, but as I have said before, I like to know what tubes it was designed to use, and with a schematic I can tell if someone has changed things. It is working now. Just like to know more about my radios. Now its time to clean it up and put on a shelf.
PostPosted: Jan Wed 06, 2010 12:28 am
It uses 01A tubes, maybe 71A in output,
but 01A will work just fine.
73, Ron w4ron
Post New Topic Post Reply  [ 11 posts ]  Moderator: sofaslug
Users browsing this forum: Google Adsense [Bot], s-petersen, VntgRads and 20 guests
