Page 1 of 1
[ 14 posts ] |
Author |
Mark D
Post subject: 6EU7 tube Posted: Mar Mon 01, 2010 6:41 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7613 Location: Litchfield Minnesota USA
I'm wondering how many have equipment that uses this audio tube. I recall that it was developed expressly as a higher quality replacement for the 12AX7. The purpose was for better hum and noise characteristics in audio equipment. Today, the 12AX7 survives and is still in production, but the 6EU7 is obsoleete, yet readily available NOS.
I have one 1960's preamplifier that uses six of these tubes. The sound is great. I've never been able to run a comparison between this tube and the 12AX7, however.
So I'm wondering... Does anyone have equipment that uses the 6EU7? Or, has anyone ever converted a 12AX7 preamp, for instance, to 6EU7?
Note: Conversion is fairly simple IF the 12AX7 is being run with filaments paralleled and using 6 volt supply. Other than the filament, the tubes are essentially electronically identical.
Also, is anyone aware of vintage equipment that uses this tube?
The one item I know of is the Preamplifier I've had since new, a Heathkit AA-141-A My main beef, a small one, with this preamp is the lack of inputs.
Mark D.
Top |
BigBandsMan
Post subject: Posted: Mar Mon 01, 2010 7:10 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6552 Location: Raleigh NC USA
The trouble with the 6EU7 was this. In fulfilling its stated purpose (reduced hum and noise), it was in direct competition with the 7025. And unlike the 6EU7, the 7025 was a direct substitute for the 12AX7 in ALL cases.
This put it at least two laps ahead of the 6EU7 in marketability. For example, owners of older 12AX7 gear could plug-and-play the new low-noise tubes. No time, bother and expense wasted on conversion.
_________________ It don't make a go if it ain't got that GLOW!
Top |
battradio@
Post subject: Posted: Mar Mon 01, 2010 9:47 pm |
Member |
Joined: Jul Fri 18, 2008 10:02 am Posts: 2024 Location: near ST Louis Mo 62002
The 6EU7 was an effort by RCA to sell tubes , it made them and others had to buy the rights to make them , the patent on the 12AX7 had expired
_________________ Mark
Top |
Don Cavey
Post subject: Posted: Mar Mon 01, 2010 9:49 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13167 Location: Fernandina Beach, FL
BigBandsMan wrote: The trouble with the 6EU7 was this. ...No time, bother and expense wasted on conversion.
Guess that pretty much sums it up! The basing is entirely different with the 6EU7 with the filament being pins 1 & 2. So that throws it out as a drop in sub. Another orphan is the 12DW7/7247. It is a dissimilar dual triode. One triode section a 12AU7 and the other triode section is a 12AX7. Scott used them in the high end tuner and I think that the EICO ST-70 amplifier used them as well. They can be expensive if the seller thinks he has something. Or, sometimes they slip through the cracks, just like the 6EU7...
_________________ Don
Top |
Mark D
Post subject: Posted: Mar Mon 01, 2010 10:01 pm |
Yes, the pinout was different with the 6EU7, but I never considered rewiring a tube socket to be a big deal. I can understand where the average "tube roller" wouldn't have a clue about that, though.
So now I understand why the 6EU7 doesn't see much use, but still, can anyone come up with other equipment that does use it? If not, that would tell me that total sales of this tube must have been like, maybe 11?  I've always been impressed with the life performance of the 6EU7, but it's probably not really much better than the better 12AX7's, although I have read a number of forum posts on various audio forums from people with hum trouble... Probably ground related, not tube, in most cases.
Mark D.
Top |
BigBandsMan
Post subject: Posted: Mar Mon 01, 2010 11:38 pm |
Member |
Don, I have an old buddy who tears his hair out over 12DW7's. It seems that his favorite Ampeg amp uses those tubes, and he can't ever find enough spares to suit him.
Top |
jukeboxman
Post subject: Posted: Mar Tue 02, 2010 1:00 am |
Member |
Joined: Jun Tue 17, 2008 4:52 am Posts: 520 Location: Virginia
Hi Guys, i do know that seeburg used this tube in a few of its late 50s early 60s amps as a preamp tube, the ay160 seeburg i know used 2 of them.
Gary
Top |
Tom Bavis
Post subject: Posted: Mar Tue 02, 2010 2:40 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4942 Location: Rochester NY USA
Several of the Magnavox console amps used the 6EU7. Bogen used in in some of the Challenger series amps, maybe others. Stromberg used it in the ASR-220 amp, but no others I know of. I have some Mullard made ones, RCAs, maybe Sylvania?
Top |
Tim Tress
Post subject: Posted: Mar Tue 02, 2010 2:45 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7660 Location: Beaver Falls, PA. USA
VM used the 6EU7 in their 730 tape recorder, from around 1962.
_________________ Tim KA3JRT
Top |
Big Harry
Post subject: Posted: Mar Tue 02, 2010 4:37 pm |
Joined: Nov Wed 07, 2007 12:44 am Posts: 1810 Location: Hawthorne, Ca
I have 2 Heathkit AA151 integtated amps that use 6EU7's and I know that Magnavox used them too. Harry
Top |
BPlus
Post subject: Posted: Mar Tue 02, 2010 4:59 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1048 Location: NW WA
My Gibson GA1RVT and VM 1450 amps use them. I've seen them in a couple of other pieces of audio gear.
-Steve W.
Top |
RepairTech
Post subject: Posted: Mar Tue 02, 2010 5:54 pm |
Member |
Joined: Jan Sun 24, 2010 7:59 am Posts: 6171 Location: Pro Tech, Philadelphia Pa.
My Magnavox 9304 amp from an old console uses 2 6EU7's, as does a host of other Maggie amps.
Indeed they are becoming hard to find, but I've got a dozen or so of them (NOS) so my amp should keep going till I drop.
From what I know though, the difference between the 6EU7 and the 12AX7 isn't really that much, and in most cases the conversion is painless.
_________________ "Accept the fact that some days you are the pigeon, and some days you are the statue."
Top |
rfenergy
Post subject: Posted: Mar Tue 02, 2010 11:23 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 486 Location: Saskatoon,Sk.,Canada
The 6EU7 was a very common tube in Gibson guitar amplifiers.I had several customers who requested I rewire the sockets to accept 12AX7s because the 6EU7 is getting hard to find.I never had a problem doing the modification.
Jim
Top |
gadget73
Post subject: Posted: Mar Wed 03, 2010 12:16 am |
Joined: Mar Tue 04, 2008 8:28 pm Posts: 3532 Location: New Jersey
Listening to a Magnavox 9302 right now with a pair of 6EU7 tubes in it. The ones in this one are original, but tested fine. Thats one great thing about low level signal tubes, they don't really wear out.
_________________ Saving vintage electronics, one dumpster at a time.
Top |
Page 1 of 1
[ 14 posts ] |
Users browsing this forum: No registered users and 2 guests |
