| View previous topic :: View next topic |
| Author |
HuggyBear Member
Joined: 01 Jan 1970 Posts: 6464 Location: Warren, MI, USA 48093-6744 N42.50973 W83.02633
| Posted: Aug Sat 19, 2006 3:00 pm |
I have an Airline 14BR-735A It has one tube on the schematic (a 6T7G) labeled "Gas Gate" What does this do? It is a duodiode/triode, similar to an *SQ7 or a 6Q7/12Q7 (same 7V basing) - and it also has a 12SQ7 as a detector / first audio.
This Gas Gate is using the diodes and triode, the triode grid is grounded, plate and cathode are connected together and connected to the cathode of the 12SQ7. The diode plates are active and connected to other places, almost like this whole stage affects the bias on the 12SQ7.
What is this supposed to do? _________________
Tom Albrecht Member
Joined: 01 Jan 1970 Posts: 6116 Location: San Jose, CA USA
| Posted: Aug Sat 19, 2006 3:35 pm |
I can't figure this one out. What is the grid of the gas gate doing connected to the chassis ground (not circuit common)? Otherwise it looks like the triode section of the 6T7 is disabled (both plate and cathode at circuit common).
Are the diode sections of the 6T7 functioning as some kind of audio limiter? The only thing I can see it doing is limiting positive-going audio peaks. Maybe that serves as a "static supressor" ? _________________ Tom K6VL |
TonyC Member
Joined: 01 Jan 1970 Posts: 2936 Location: Westminster, CO, USA
| Posted: Aug Sat 19, 2006 4:40 pm |
The diodes are forming separate AVC voltages for the IF and RF stages respectively. Not sure why the grid is tied to chassis. _________________ Tony Casorso |
Tom Albrecht Member
| Posted: Aug Sat 19, 2006 5:28 pm |
Hi Tony,
That helps a bit with understanding it, but I'm still scratching my head a bit. What is the advantage of having separate AVC lines? Perhaps the gain curves of the different stages need different voltages?
And where did the terminology "Gas Gate" come from? When I first saw that, I thought maybe it was a thyratron or something like that, and it might be a crazy squelch circuit. Studying the circuit and looking at the tube specs made clear that was not the case. _________________ Tom K6VL |
TonyC Member
| Posted: Aug Sat 19, 2006 6:34 pm |
Different gain curves for the tubes or a desire to adjust the gain of the IF and RF stages by different amounts. It also eliminates a path for stray coupling between the stages. The "gas gate" thing is new to me, but so is lots of this stuff . I was browsing and found a reference to gas gate in the google groups. They mentioned a Crosley 855. I looked at the schematic and it too uses AVC diodes separate from the detector diode but I didn't see the term "gas gate" on the schematic.
Edit: Maybe because the mixer is biased with cathode bias and the IF amp has a grounded cathode (I think, schematic is noisy), the grids needed to sit a different voltages. So, the need/desire for different bias schemes may have led to separate AVC. _________________ Tony Casorso |
HuggyBear Member
| Posted: Aug Sat 19, 2006 7:29 pm |
| TonyC wrote: | Different gain curves for the tubes or a desire to adjust the gain of the IF and RF stages by different amounts. It also eliminates a path for stray coupling between the stages. The "gas gate" thing is new to me, but so is lots of this stuff . I was browsing and found a reference to gas gate in the google groups. They mentioned a Crosley 855. I looked at the schematic and it too uses AVC diodes separate from the detector diode but I didn't see the term "gas gate" on the schematic.
Edit: Maybe because the mixer is biased with cathode bias and the IF amp has a grounded cathode (I think, schematic is noisy), the grids needed to sit a different voltages. So, the need/desire for different bias schemes may have led to separate AVC. |
I think the separate mixer & oscillator (and the gas gate) are kind of unusual for what is otherwise an AA5. I don't think it was just to inflate the tube count (7 tubes in this radio). I haven't worked on this radio yet, it was one of a group of five that I got for $5 at the Lansing MARC auction.
Any thoughts on how well it might work? _________________
HuggyBear Member
| Posted: Aug Sat 19, 2006 7:43 pm |
| Tom Albrecht wrote: |
And where did the terminology "Gas Gate" come from? When I first saw that, I thought maybe it was a thyratron or something like that, and it might be a crazy squelch circuit. Studying the circuit and looking at the tube specs made clear that was not the case. |
I had never heard of a 6T7, so I had to check, at first I was thinking it was a thyratron or something, nope, essentially the same as a 6Q7 with a 6v/150ma heater. Apparently a 6T7 can replace a 6Q7 in a parallel heater circuit, and a 6T7 could be used in a pinch in place of a 12Q7 in a series circuit.
I saw a similar circuit that used a 6J5 as a detector connected that way, with the plate and cathode tied together - but IIRC the plate/cathode were tied to the chassis/B- (same in this radio) and the grid was connected to the IF transformer as a diode plate in a *SQ7 would be. _________________
Ed Engelken Member
Joined: 01 Jan 1970 Posts: 670 Location: Canyon Lake, TX
| Posted: Aug Sat 19, 2006 8:31 pm |
The "gas gate" is a diode connected from the AVC line to ground to prevent the AVC from going positive if one of the AVC controlled tubes gets gassy. That is according to Ghirardi in "Modern Radio Servicing." The idea is that if a tube goes gassy and it's grid goes positive it will drive the other AVC controlled grids positive and increase the current drain to critical levels and damage other good tubes and perhaps the power transformer. The gas gate prevents the grids from going positive and, in theory, prevent damage.
My Crosley Model 855 has a gas gate using an extra 6H6. Looks like an interestsing way to boost the tube count!!
EDIT: The gas gate is explained in "Radio and Television Receiver Circuitry and Operation" by Ghirardi and Johnson, pages 184-185. _________________ http://www.gvtc.com/~edengel/TARC.htm |
HuggyBear Member
| Posted: Aug Sat 19, 2006 9:51 pm |
| Ed Engelken wrote: | The "gas gate" is a diode connected from the AVC line to ground to prevent the AVC from going positive if one of the AVC controlled tubes gets gassy. That is according to Ghirardi in "Modern Radio Servicing." The idea is that if a tube goes gassy and it's grid goes positive it will drive the other AVC controlled grids positive and increase the current drain to critical levels and damage other good tubes and perhaps the power transformer. The gas gate prevents the grids from going positive and, in theory, prevent damage.
EDIT: The gas gate is explained in "Radio and Television Receiver Circuitry and Operation" by Ghirardi and Johnson, pages 184-185. |
It's not like the old "18 transistor" radios where a bunch of them were just installed and soldered in with their leads connected doing nothing except raising the parts count, or the equally dubious Kadette radios with several ballast tubes. Now I see there IS a legitimate purpose for stage, although personally I see it as a solution for a problem that doesn't exist. They wouldn't have done that if Earl Muntz (or many other people) ran the company. _________________
TonyC Member
| Posted: Aug Sat 19, 2006 9:55 pm |
I believe that the grounded grid forms the "gas gate" diode as the other two diodes appear to be connected to generate AVC. _________________ Tony Casorso |
Tom Albrecht Member
| Posted: Aug Sat 19, 2006 11:47 pm |
I don't think they can generate AVC as they are connected. They conduct if the AVC line goes positive. That's where I got the funny idea that it might be some kind of "clamp" for static spikes.
I have heard of the AVC going positive, but have never seen it. _________________ Tom K6VL |
TonyC Member
| Posted: Aug Sun 20, 2006 12:28 am |
You're absolutely right Tom. I had my diodes backwards. _________________ Tony Casorso |
Tim Tress Member
Joined: 01 Jan 1970 Posts: 3462 Location: Beaver Falls, PA. USA
| Posted: Aug Sun 20, 2006 3:27 am |
There was an article on the gas gate in the AWA Journal, not too long ago.
Tim |
Guest
| Posted: Mar Tue 27, 2007 7:08 am |
| HuggyBear wrote: | I have an Airline 14BR-735A It has one tube on the schematic (a <b style="color:black;background-color:#a0ffff">6T7G</b>) labeled "Gas Gate" What does this do? It is a duodiode/triode, similar to an *SQ7 or a 6Q7/12Q7 (same 7V basing) - and it also has a 12SQ7 as a detector / first audio.
What is this supposed to do? |
jkaetzjr Member
Joined: 16 Jan 2007 Posts: 9275 Location: Hueytown, AL
| Posted: Mar Tue 27, 2007 3:32 pm |
| Comment on AVC going positive. This is by no means an uncommon phenomenon. Have seen it happen in older sets using "G" style tubes, "GT", but probably more common in miniature tubes that run hotter than the older types. Output tubes also can have grids that gradually go positive due to gas or control grid contamination. Happens a lot with 50 and 35L6s and 50B5s and 50B5s. Displays the same symptoms as a leaky coupling cap. Most AVC circuits use rather high value resistors that in effect are "grid return" resistors such that it doesn't take a lot of gas current to cause a positive AVC line. Frequently doesn't get noticed until you tune in a barn burner down the road at which point the RF/IF amps get overloaded enough to clip the modulation. TV sets also have the problem. Many years ago Philco made sets using 6CB6s in the IF with a very high grid return path. Once the tubes began to go gassy the pix would wash out completely due to overload in 30 minutes or so. There were many Philcos in which all 4 of the IF amps had to be replaced to make it work properly. Customer often tended to be skeptical when you began wholesale replacement of tubes in a set that was "working fine" until it quit suddenly! |
Curt Reed Moderator
Joined: 01 Jan 1970 Posts: 29406 Location: Sandpoint, IDAHO US of A
| Posted: Mar Tue 27, 2007 5:47 pm |
A lot of the older, more detailed tube manuals list the maximum grid resistance value for a lot of tubes. I have run across sets where the manufacturer did not pay any attention to this at all. Of course, tubes were cheap and available at the time, but it still makes a person wonder at times.
Curt _________________ Curt, N7AH
(Connoisseur of the cold 807) CW forever! |
Terry Judkins Member
Joined: 01 Jan 1970 Posts: 2364 Location: Powder Springs,Ga. USA
| Posted: Mar Tue 27, 2007 7:55 pm |
Philco included a 'gas gate' in many of their radios. Here is a snippit from the 39-30 schematic. Note the two diodes in the 75 clamp the AVC line to zero volts maximum (can't go positive). The plate of the 37 is used to develop the AVC voltage and the grid of the 37 is a detector.
 _________________ Terry, K4TLJ
There is no distinctly Native American criminal class....save Congress.
-Mark Twain |
jkaetzjr Member
| Posted: Mar Tue 27, 2007 8:05 pm |
| Guess the gas gate is worthwhile to keep tube currents from getting out of hand especially in sets that don't use cathode resistors in the RF/IF stages but overload distortion overload can still be present on strong stations. Something is better than nothing, particularly if it doesn't cost anything extra! |
Norm Leal Moderator
Joined: 01 Jan 1970 Posts: 22500 Location: Livermore, CA
| Posted: Mar Tue 27, 2007 10:00 pm |
Notice this schematic has a 750K grid resistor for the 41 tube. Max grid resistor should be 500K. This is a case like Curt mentioned.
Using a higher value grid resistor gives a little higher gain and requires a smaller coupling cap for a specific frequency response. Too high a value resistor and grid can go positive after some use.
Neat idea clamping the AVC line so a gassy tube can't make it go positive. Even though the radio may operate still a good idea to replace a gassy tube. _________________ Norm |
