Page 1 of 1
[ 13 posts ] |
Author |
Don Cavey
Post subject: Fusistor Question Posted: Dec Fri 07, 2007 1:55 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13164 Location: Fernandina Beach, FL
I seem to remember my dad working on TVs and there were what he called Fusistors. Kinda like a sand resistor but a fuse as well. Is that what they really were, a resistor with a fuse? If so, can't you just replace it with a resistor of the correct value with a fuse in series with it?
Or, are they still available? I never really understood what they were for...
_________________ Don
Top |
Curt Reed
Post subject: Posted: Dec Fri 07, 2007 2:09 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 34326 Location: Sandpoint, IDAHO 83864
Don- I have often wondered about this myself. Back in the days when I was working on TV sets, I was told two things about them. One guy said they were a resistor that simply changed its value when it got hot to limit the current, and would resume their cold value when they cooled down. The other guy said they were a resistor with a fine wire that acted like a fuse and when they blew, they were done for.
So I am curious too. Maybe two of us can learn something here!
Curt
_________________ Curt, N7AH
Top |
Rich, W3HWJ
Post subject: Posted: Dec Fri 07, 2007 2:34 am |
Joined: May Tue 30, 2006 4:46 pm Posts: 9207 Location: Santa Rosa, CA
When I worked in a TV service shop in the late 60s, I seem to remember large sand-type resistors that were called "fusible" resistors. They were generally under 50 ohms and rated at 5 or 10 watts.
They were usually used in series-string, transformerless TVs that often had a voltage doubler B+, made with selenium rectifiers.
I believe the main purpose was to reduce surge current when the filter caps first charged up, but also to act as a fuse if the set drew too much current for a significant period of time.
Top |
Randy Bassham
Post subject: Posted: Dec Fri 07, 2007 3:12 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3350 Location: Poplar Bluff, MO USA
The fusible resistors I'm familiar with had lugs crimped on the wires and plugged into a small terminal strip so they were easy and quick to replace. IIRC the common values were 4.7, 5.6, and 6.8 ohms, we usually just used whatever ones we had on hand.
_________________ However beautiful the strategy, you should occasionally look at the results. Winston Churchill
Top |
Mr. Detrola
Post subject: Posted: Dec Fri 07, 2007 3:21 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 26284 Location: Detroit, MI USA
Definitely a one-time thing. Sometimes you get lucky and NOS stuff from closed up shops or distributors turns up at swap meets or on eBay.
However, there's no problem replacing with a wirewound resistor of exact value in series with a fuse.
_________________ Dennis
Top |
Bruce Hagen
Post subject: Posted: Dec Fri 07, 2007 3:25 am |
Joined: Jun Thu 15, 2006 1:21 am Posts: 4683 Location: NE Ohio
And they got real hot and smelled when one of our co-ops would put in a 150 ohm or so piece in the Philco portables. Look the same, are the same they thought.
_________________ Bruce
Top |
Mr. Detrola
Post subject: Posted: Dec Fri 07, 2007 3:35 am |
Worst case I ever saw was when someone replaced one in an old metal cased Admiral portable with a wirewound resistor of the right value, but very much higher wattage. One day the rectifier shorted dead, putting the resistor directly across the power line in series with the electrolytic. After a very short time, the resistor was glowing bright orange and really smelled bad. Still can't figure why the electrolytic didn't explode, it certainly should have. It was bad though......
Top |
Big Harry
Post subject: Posted: Dec Fri 07, 2007 2:58 pm |
Joined: Nov Wed 07, 2007 12:44 am Posts: 1810 Location: Hawthorne, Ca
I still use those things in late 50's and 60's vintage car radios. They are used in the emitter circuit of the output transistor, usually something between .33 and .68 ohms. Fortunately a local radio supply house still has some of the fusible resistors in stock. Harry
Top |
Mike Toon
Post subject: Posted: Dec Fri 07, 2007 5:31 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7642 Location: Beautiful Downtown Burbank CA
In the 50s I had a small B&W TV in my room that just died. I went with my dad to the TV shop where the guy fixed it while we waited. I could see him plug something in. Dad was outraged by the repair bill.
It died again a month later so I opened it up, saw that new plug-in fusable resistor and rode my bike to that shop for a replacement. The service guy recognized me and gave me a "better one" for a buck.
Dad was amazed a kid could repair a TV for a dollar.
Top |
stromberg6
Post subject: Posted: Dec Sat 08, 2007 1:35 am |
Joined: Apr Mon 24, 2006 1:05 am Posts: 2289 Location: Ellington CT
Under the "Workman" brand a number of smallish fusable resistors were sold, and were color-coded. The units were plastic, as opposed to "cement", small, rectangular, and had two angled "legs" at the bottom. I never ran into a TV that used these, but saw a large display at my regular parts jobber in the '70s. Maybe for inexpensive to moderately priced B/W sets?
Kevin
_________________ "There Is Nothing Finer Than A Stromberg-Carlson"
Top |
Mr. Detrola
Post subject: Posted: Dec Sat 08, 2007 5:01 am |
Those rectangular plastic colored fuses are Belfuses, and were used in many brands and models of TV's, both B&W and color. The socket and plug-in fuse tabs were designed so one could not use a drastically higher value of fuse than the original, it simply wouldn't plug into the socket. Of course the concept was to match the color, so you would have the correct value. But within a certain very limited range, other colors would plug in.
The original Belfuses were described as "chemical fuses" and left a white powder residue when they blew, but IIRC some of the aftermarket replacements like the Workman line may have just had a conventional fuse element.
Top |
Cdoose
Post subject: Posted: Dec Sat 08, 2007 6:13 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1974 Location: Hinsdale, IL, USA
Zenith used belfuses (maroon, light green, and white were the most popular) on all the color tv tube chassis's from the mid to late 60s to the chromacolor II chassis in 74. They had a circuit breaker in the CC II chassis.
I think I have a few left in the basement.
Chuck D. KB9UMF
Top |
Don Cavey
Post subject: Posted: Dec Sat 08, 2007 2:43 pm |
Member |
Thanks for all of the replies. Now that you say it, I remember some of them having ends on the wires that would plug into a socket for easy replacement.
Well, I guess they can be replaced with a wire wound resistor with a fuse in series. Now, if one can only find the specs of it, that would help. Did Sams only have a part number or the values.
Top |
Users browsing this forum: Joshuasig and 8 guests |
