It is currently May Wed 22, 2019 5:48 am
 Post subject: RCA 8U2 Type C
PostPosted: Mar Fri 15, 2019 11:20 am
I have an opportunity to buy this tomorrow. It was brought back to the US from South Africa where it used their ac voltages. Is $100 reasonable? I know, I know...If I like it... :)
 Post subject: Re: RCA 8U2 Type C
PostPosted: Mar Fri 15, 2019 11:37 am
Should also work on 120 VAC, 60Hz.
PostPosted: Mar Fri 15, 2019 12:29 pm
Why not ? It looks good , you like it and it is not a radio you see every day.
Gl,
Henry
PostPosted: Mar Fri 15, 2019 12:45 pm
If it has the original finish and that grill cloth is original, I'd say it's well worth it. At least it's an upright R/P and not a side by side setup. Do you even have an electric 78 player in your collection? If not, maybe this is more of a justification to get this one. When will you ever come across another opportunity in acquiring a prewar R/P especially out in the South West?
Michael Feldt
www.indianaradios.com
PostPosted: Mar Fri 15, 2019 11:16 pm
I like it......l like it. Looks like the usual re-cap and rubber wire. Change the bus on top of the transformer and wall plug, there you go. Craig
PostPosted: Mar Sat 16, 2019 1:25 pm
pretty clean, and the cabinet is interesting!
Stromberg 1A chassis
KD2AZI
Post New Topic Post Reply  [ 6 posts ]  Moderator: sofaslug
Users browsing this forum: chaz and 4 guests
