It is currently Feb Tue 18, 2020 7:36 am
 Post subject: Atwater Kent model 33 to K101 power supply
PostPosted: Sep Wed 11, 2019 9:10 pm
this might be a dumb question but here we go. The wiring diagram for an Atwater model 33 for battery use shows various jumpers between the batteries. Since the K101 is three separate supplies should i put the jumpers on it like the battery diagram depicts? dont want to do smoke test. Thanks in advance!
 Post subject: Re: Atwater Kent model 33 to K101 power supply
PostPosted: Sep Wed 11, 2019 10:09 pm
You will need to connect the B-, A-, and C+ together and to the common lead from the radio. Other than that, just connect the three B+ voltages, A+, and C- to the correct wires.
Jay
PostPosted: Sep Wed 11, 2019 11:15 pm
On the K101 run a jumper from C+ to A-. Then a jumper from B- to A-. Then connect harness black A- to the A- on the K101.
Then hook up the A+. Test to be sure the filaments light up.
Next, the 22, 67, 90, and C- 4. Be sure to id the wires with a meter, not colors; you will find the colors all faded.
Jeff
PostPosted: Sep Thu 12, 2019 4:54 am
much appreciated. Thanks!
Post New Topic Post Reply  [ 4 posts ]  Moderator: sofaslug
Users browsing this forum: kurt1618 and 12 guests
