It is currently Mar Wed 20, 2019 6:13 pm
Post New Topic Post Reply  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: Vintage power supplies for battery operated radios
PostPosted: Jul Sun 03, 2016 8:34 am
Here is a photo of the Electro Model P Sam
PostPosted: Jul Sun 03, 2016 8:39 am
here is the inside
PostPosted: Jul Fri 29, 2016 11:00 pm
Courtesy of bandersen on this forum, the following schematic, for the model "P" appears to be identical to the "Electro Model P".
http://www.nostalgiaair.org/pagesbymode ... 019582.pdf
cheers
PostPosted: Jul Sat 30, 2016 12:06 am
Thanks John
PostPosted: Jul Sat 30, 2016 2:52 am
Hi John,
Thanks very much for posting that link to to what appears to be the Electro Model "P" schematic. Although I have an original operating manual for the Electro Model "P", which includes hookup instructions and diagrams and a parts list (with prices!), it does not include a schematic. I have searched hard and long for this schematic for several years. And lo and behold, it is right there in Riders! :D I have an original set of Riders myself, but never would have thought to search under Spiegel. 8)
Poston
PostPosted: Jul Sat 30, 2016 3:21 am
Thanks guys, but it was BANDERSON who found it for us. Credit where due.
cheers
PostPosted: Jul Sat 30, 2016 8:35 am
Thanks Banderson
PostPosted: Aug Mon 01, 2016 8:21 pm
Maybe these will fit the category. First up, Philco Socket Power AB-460.
File comment: Philco Socket Power, 4 volts "A" and various "B" voltages.
File comment: Philco insides.
File comment: Full wave electrolytic rectifiers (jumped with diodes)
Increase knob adjusts Det. and 90V voltages. Charges the 4 volt battery when switched OFF; Switches 4 volt battery to A posts when turned ON.
Copper oxide rectifier in 4 volt charge circuit; funny, works fine with a 6 volt battery, too.
Snap-in resistor sets voltage for detector circuit.
Looks like something from Dr. Frankenstein's lab. What fun.
ACME Super BC Type 25 B and C power supply.
File comment: Type BH tube and wiring connections.
File comment: Original Ratheon BH tube fired up; purple haze.
Both of these work but I don't leave them on too long. (Condenser cops---I know, I know---).
PostPosted: Feb Fri 15, 2019 1:27 am
I recently "acquired" an Electro Model 'FH' Battery Eliminator from I believe the mid 1930's. Would anyone have a Schematic for one of these 'earlier' Battery Eliminators? It is quite a bit LARGER than the later model 'P' & 'S' eliminators. Unfortunately there is NO schematic included inside this particular unit. Thank you in advance for any provided assistance!!!
Want DeForest Crosley Advertising ~ 1935!
Marconi; Stromberg Carlson
CKTA 1570 AM "Drive"
PostPosted: Feb Mon 18, 2019 7:13 am
I would think that quite a suitable supply could be made by using the transformer out of an old tube tester (Dick Smith Electronics used to sell them new here in the States), a few voltage regulator IC's and some zener diodes.
FrankB
WB7ELC
"The average family has 2.5 children. Where is the other .5 child?"
PostPosted: Feb Mon 18, 2019 1:22 pm
That probably would work, but this thread is about orignal power supplies, and it's goal is to try to accumulate information on original power supplies in one thread.
Please don't hijack the thread with homebrew stuff? There's a forum for that.
cheers
PostPosted: Feb Wed 20, 2019 12:44 am
Thank you John for pointing out the purpose of this thread! I had a look at "Riders - Spiegel" & although the newer Model Electro Eliminators are included, I located nothing on the Model 'FH' unit. If you come across anything, please advise. Once again, thank you!
PostPosted: Feb Wed 20, 2019 7:02 pm
I have a Grebe socket power unit, which was apparently a factory accessory for the Synchrophase 7 to turn it into an AC7. It's pretty straightforward and good-looking, but according to the Riders schematic for the AC7, it provides filament voltages of 1.5v (for 5 26 tubes), 2.5v (for a 27 tube), and 5.0v (for a 71A tube) as straight AC. Only high voltage is rectified and filtered.
So my question is, is this thing worth checking out and fixing up (as needed), to power other battery sets? In other words, can I use AC filament voltage on 01As in three-dialers?
Post New Topic Post Reply  [ 33 posts ]  Moderator: sofaslug Go to page Previous  1, 2
Users browsing this forum: davros, FSEradnut70, radiotechnician and 27 guests
