The office has us working from home these days and since we've been having a steady stream of donations at the museum there's lots of stuff to do. Probably won't be able to setup at any antique shows for awhile but in the meantime the "stockpile" grows. Some of these may become auction items for Radio Day. We are now approaching the 90+ mark on total sets now at the ready. Here are a few more to add.
1: This Crossly "10" model 1018 from 1938.
I really need someone to remind me to take before pics because the set looked like crap. This is after cleaning and waxing.
The set has had a pretty rough life. At some point something catastrophic must have occurred. The power transformer, output transformer, the RF can and speaker have all been replaced. Underneath were signs of stuff having blown up with soot and tar stains. Whoever did the work did a VERY sloppy job because after replacing the electrolytics the set just sat there and hummed.
I more or less had to re-work a lot of that work along with the general overhaul. I wish I'd taken before pics because there was some real silliness in there. The previous repairman had for whatever reason taken a flexible wire wound resistor, completely pulled it out and run it all the way from the speaker connection to the ground of tube 6K6. I replaced that with the large gold colored Dale resistor as seen in the left side. Crossly was a cheap manufacture and it showed. ALL of the main power resistors were waym wayyyy off and had to be replaced.
After that the set worked but the volume was low. The resistor that tied directly to the center tap of the Vol. pot was way off too- the one pictured here- and when replaced volume was restored.
The rubber friction wheel for the tuner mech was of course completely hardened up and the cord was slipping. I spent about an hour removing that and then installing a new spring and wrapping the cord around the bare shaft a few times to gain traction
So now it works. Always satisfying when something that was in such bad shape is made to work like new again
2: This great big Grundig. This was donated along with some American sets. ALL of the tubes were gone. Luckily we have a huge supply of tubes- even the weird ones this one uses though most were American equivalents.
Initially the volume control was frozen solid. On these German sets the ONLY way to free them up is by using raw, unbridled heat.. from a blow torch. I'll heat the crap out of the shaft and apply oil until it starts to boil. This takes 2-3 attempts before it will eventually break free. There was also considerable garbling in the audio. After a recap this all cleared up. Probably the smaller electrolytics that are attached to the output tubes or a coupling cap to those same tubes.
I used an orbital buffer and wax. The finish is immaculate. Very attractive radio IMHO...
3:Weird little Motorola.
I usually dislike working on these little portables. But this one was a nice challenge. Initially there was zero B+. I then saw that a multi-section power resistor coming off the rectifier was open. As easily seen by the deformation of the left side here.
After replacing that section and testing it I found out why it'd done that in the first place. Powering it up immediately resulted in the telltale nasty smell of shorted out selenium rectifier. So I put it out in the yard for the "stink" to dissipate. Replacing it with a modern diode solved the issue.
4: KInd of a ho-hum, not very exciting RCA with AM and FM.
A real rat's nest of a chassis. But despite that after a recap both bands work great
5:Custom Zenith.
We had 4-5 of these donated recently. All but this one had really nice cases. The case on this had a ruined bakelite finish probably from being scrubbed and cleaned. Not much you can do about that. Plus-missing Buyers at our shows like the bright colors. So this one got a custom job.
I spent some quality time on this one. Full re-cap, replaced a weak 12AU7 and gave it an alignment. FM works as well as any modern set
