It is currently Oct Mon 26, 2020 8:47 pm
 Post subject: Loop Antenna & Different Radios
PostPosted: Sep Sat 15, 2018 3:44 pm
My Midwest B17 responds extremely well with loop antenna vs a long wire antenna where as my Wards 62-402 does not have much difference in-between a 30 foot wire or the loop with the wire antenna being a little better. Both radios have about same sensitivity. Why?
 Post subject: Re: Loop Antenna & Different Radios
PostPosted: Sep Sat 15, 2018 4:13 pm
Impedance matching.
There are two fundamental ways of getting a signal into the front end:
-Antenna transformer with a tuned secondary.
-Tuned loop (including the more modern ferrite core loop
Many of the early sets had a simple transformer input. What is interesting is that some used a low-impedance primary (step-up transformer), and others used a high-impedance primary (step-down). I started to research this, but could find very little on why to choose one over the other.
If you buy a modern "universal" antenna coil, it will normally have a high-impedance primary.
There were also early sets with loops. But the loop totally dominates in later designs, particularly the ubiquitous AA5s
The ideal way to setup a set with an external loop is to replace the antenna coil with the external loop. The downside of this is that the loop has to be matched to the existing tuning cap.
The simpler method is to use a "pickup coil" that is part of the external loop. The external loop is then just another transformer. Ideally, you would match the impedances between loop and the radio inout, but this is not always possible.
What is your experience with resonance and transformer equations, and complex algebra?
PostPosted: Sep Sat 15, 2018 4:26 pm
I had algebra in HS. Experience with algebra? About zero. I am keeping the Midwest & selling the Wards, so it does not matter as one console is enough. I was just curious.
PostPosted: Sep Sat 15, 2018 4:57 pm
Try placing the loops tuning condenser in series rather than parallel for the Wards.
PostPosted: Sep Sat 15, 2018 7:13 pm
Just wanted to know whether we should go down the math road.....;)
Understanding the differences between radio designs can be a bit daunting....some of it was trial and error in the test labs.
PostPosted: Sep Tue 18, 2018 2:33 am
How would I wire that?
PostPosted: Sep Tue 18, 2018 4:54 am
I've used both re-purposed AA5 loop antennas and ferrites.
With the AA5 loop: tune the main loop with a parallel 375 or 500 pf tuning capacitor and connect the 2 turn tap via 100 pf to the radio antenna input. Ground connected, too.
With the ferrite: tune the main winding as above. Connect the secondary to the radio also via 100 pf, antenna and ground.
In both cases, tune the radio, then peak the antenna... a two dialler. Loop and ferrite tuning is quite Hi-Q, easier with a slow motion drive. Signal (by AVC voltage) in my basement is about the same as 20 feet of wire in the ceiling, but the loop/ferrite seems to have a lower noise level.
Results vary, depending on the radio's RF coil, my sense is it's better with the lower impedance antenna inputs.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
Post New Topic Post Reply  [ 7 posts ]  Moderator: sofaslug
Users browsing this forum: JnTX, les_sikala and 43 guests
