It is currently Mar Sun 29, 2020 1:34 am
Post New Topic Post Reply  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Philco 34?
PostPosted: May Wed 15, 2019 2:06 pm
Took a few tries, but we nailed it!
PostPosted: May Wed 15, 2019 3:26 pm
The entry for this model at RadioMuseum has no photo, but it does explain the difference between the 34 chassis and the 34A chassis. https://www.radiomuseum.org/r/philco_34b_2.html
The basic 34 chassis was set up for use with a wet ("storage") A-cell battery. This was like a car battery, lead acid chemistry, but used only one cell (a modern 12V car battery uses 6 cells strung together to make 12V). A single cell generates 2 volts, the tube filaments run on 2 volts, everybody's happy. There is a spot on the chassis for a ballast, but no ballast was provided, and instead a jumper was used to bypass the ballast socket.
The 34A was set up for use with a dry A-cell battery. This was like a lantern battery, zinc carbon chemistry. A single cell generates 1.5 volts, not quite enough to make the 2 volts tubes happy, so the dry A batteries used 2 cells and generated 3 volts. With a 2V radio, you needed to get rid of a volt somewhere. Philco provided the 1C1 ballast with your radio instead of the jumper; it would use up a volt by converting the energy to heat. It wasted 1/3rd of the energy stored in the battery, but the radio worked.
You could convert the chassis at home between 34 and 34A configuration simply by swapping in a jumper or a ballast, and changing the battery type.
-Rodney
PS. You can still buy 2V lead acid batteries that would make this radio happy. Need a charger too.
https://www.amazon.com/Cyclon-Enersys-H ... 0002ZR6N2/
PostPosted: May Fri 17, 2019 9:23 pm
JnTx wrote: The 32B, 97E and 144B have the same cabinet:
Philco 32B has its control knobs on the vertical strings (pinstripes)... :)
https://mcclellans.com/images/Philco32B ... /front.jpg
Post New Topic Post Reply  [ 23 posts ]  Moderator: sofaslug Go to page Previous  1, 2
Users browsing this forum: DaleMidori, Indiana Radios, Spivey, Tommgb, wped-tv and 13 guests
