It is currently Dec Mon 16, 2019 6:04 am
 Post subject: New Arrival - Philco Special Services 53-656
PostPosted: Jun Sat 15, 2019 4:43 pm
Just arrived well packed, double boxed!
Getting ready for the variac now.
Look at that honking ferrrite bar!
chemical formula for aluminum sulfate
free image hosting
 Post subject: Re: New Arrival - Philco Special Services 53-656
PostPosted: Jun Sat 15, 2019 5:58 pm
I have the AM only version. It's a very sensitive radio and great for DX. You will probably have to replace the mica caps in the IF transformers.
Jay
PostPosted: Jun Sat 15, 2019 6:48 pm
Thanks!
On variac now!
PostPosted: Jun Sun 16, 2019 3:41 pm
Jay
Well, it turns out you were right on the money.
Powered up, and the set seems to have a terminal case of silver mica disease.
I understand this is not an easy fix if you are a skilled tech, which I am not, nor a cheap fix to have it sent out.
I rolled the dice on this one.
Oh, well...
PostPosted: Jun Sun 16, 2019 4:11 pm
Put it aside for now, with a note to remind you what the symptoms are.
Even the sick radios can look good while they wait for the cure of whatever ails them. 8)
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Jun Sun 16, 2019 9:20 pm
Agreed!
This is a nice khaki colored set, designed for the tropics!
I noticed when I fiddled with the band switch, I was able to get a station.
Sprayed some Radio Shack non residue contact cleaner into it, and worked the switch. Will wait a while and see if there is any improvement.
Post New Topic Post Reply  [ 6 posts ]  Moderator: sofaslug
Users browsing this forum: Toots, wireless 12 and 13 guests
